Question about Vizio 32" E320I-A0 LED-LCD Smart TV, Black
When connected to cable, get a no signal indicator
No signal indicator when I connect cable. Cable checksok
    Champion:
  • 209 Answers
You need to go into the TV menu, locate where choices for choosing incoming signals are, and choose the cable option, so the TV knows that it is receiving a cable signal, VS an antenna signal.
Posted on Nov 25, 2014
2 Suggested Answers
  • 4234 Answers
SOURCE: ive connected the vga cable and still get "NO SIGNAL" msg.
If the resolution of the source of the RGB signal is outside of the range of the set, you will get this mesage. The supported resolutions are listed in the owner's manual. Verify that you have a signal within that range. If you do, please post your source of the video here and we'll look further.
Thanks,
Dan
Posted on Mar 19, 2009
There is no signal on my emerson tv, how do i get one
1. You are not on the right input for the signaling device: Verify which input number (or type ie HDMI/component/video/Cable) your device is connecting to and tune to that input.
2. The signaling device is not powered on. Verify it is on and the cable is properly seated into device and TV.
3. The cable is bad. Try a different cable or use alternate type of connection.
4. The specific input port on the TV is bad. Move the connecting cable to a different port (ie from HDMI 1 to HDMI 2) and tune the TV to that input.
If you are using an Over the Air signal (OTA) with rabbit ears or and antenna use the TV menu to run an auto tuning scan of your local stations.
If you are using a tuning box (cable/satellite) over a coaxial connection check connections and tune the TV to CH 3 or CH 4 and check for picture. There may be a switch on the back of the box indicating CH 3 or CH 4.
Sep 18, 2017 | Emerson Televison & Video
What is dvi no signal
Digital video input no signal,on a monitor usually indicates that the video cable is not supplying a signal.Could be a faulty cable, or a bad connection from computer or the monitor...or a bad display driver / faulty video card.check connections ,try with different cable and monitor.
Feb 11, 2015 | Microsoft Windows Vista Ultimate Edition
How do i turn wifi off
Locate the Wireless LAN switch located on the front of your computer.
This could be located on the upper row on a laptop it will have the radiation look (((·)))
Make sure its pressed on or off whichever you need.
Move the switch to the right to turn on Wireless connections.
Right-click the network icon located on the system tray next to the clock.
You should see a list of available wireless networks.
Select the network you want to connect to and click "Dis Connect."
Motorola Surfboard Cable Modem User Guide
The user guide for your Motorola Surfboard cable modem can mean the difference between knowing how to locate and diagnose problems with your connection or staring angrily into a maze of blinking lights.
The user guide provides information on properly setting up your cable modem, understanding the indicator lights and troubleshooting problems before you have to call your Internet Service Provider.Connecting Your Modem
Your Motorola Surfboard cable modem must be connected to your home's coaxial cable connection.
Connect the coaxial cable from your cable outlet into the "Input" jack on your cable modem.
If your modem is wireless, it will connect to any computers and wireless devices in your home through the wireless signal sent from the modem.
Wired Internet connections require that you use an Ethernet cable to connect your cable modem to any supported computers and devices.
Understanding the Front Panel
The front panel of your modem is your key to understanding the status of your cable modem.
The front panel features "Power," "Send," "Receive," "Online" and "Link" lights, each of which displays information about your modem.
The "Power" button will display a solid green light when operating normally and will turn off when there is a problem with the power supply.
The "Send" and "Receive" lights will transmit a solid green or blue color when data is being normally transmitted through your modem and will blink when it the modem is scanning for an upstream or downstream connection.
A solid green "Online" light indicates that you are connected to your Internet Service Provider, while no light indicates that the Internet connection in your home is experiencing problems.
A yellow "Link" light indicates that a computer is connected to your modem with an Ethernet connection while a blue light indicates that a high-speed Ethernet connection is being utilized through the modem.
Configuring TCP/IP
The Transmission Control Protocol/Internet Protocol provides the basic foundation for establishing a local network and a connection to the Internet. The TCP/IP can be configured in the "Control Panel" of your Windows computer. Open the "Network and Sharing Center" from the control panel and double-click the "Manage network connections" option. Right-click the network connection displayed and select "Properties," then select Internet Protocol Version 4 and open the TCP/IP properties menu. Select "Obtain an IP address automatically" and "Obtain DNS Server address automatically" from the TCP/IP properties menu and click "Ok" to save your TCP/IP settings.
Troubleshooting
Many technical issues with your cable modem can be resolved by power cycling your modem and the computers and devices connected to it.
To power cycle your modem, unplug it from the power supply for 10 to 15 seconds and reconnect it to the power supply.
Restart all of your connected computers and devices while your modem is power cycling. Problems with the "Send" and "Receive" functions can be the result of a poor signal being sent to your cable modem. Tighten the coaxial cable connection to your modem and contact your internet service provider if problems persist.
http://www.motorola.com/staticfiles/Consumers/Products/Cable Modems and Gateways/SURFboard Cable Modem-SB6120/_Documents/Static Files/557621-001_SB6120_User Guide-US-EN.pdf
Nov 19, 2013 | Arris SURFboard Gateway SBG6580 DOCSIS 3.0...
What do if my lenovop pc showing only not connection ?
Check if your LAN-cable is plugged into computer and in the other end of cable to wall-outlet/adsl-modem/some router /switch
If the cable is connected is the indicator light on both ends.
Thunder and lightning could have a electrical surge in the internet grid?
Mar 27, 2012 | Lenovo Computers & Internet
Pixellation on most channels
The pixellation on cable channels usually indicating poor/weak cable signal. You may want to have the cable signal strength check out by the cable company, check your cable connection at the entrance of the house to make sure they are clean and tight, try connect and disconnecting them. You are not the cable company cable box are you? My had to be replaced twice by Comcast, they were running very hot.
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
Jul 04, 2010 | LG 42LC2D 42 in. LCD HDTV
Modem won't work thru splitter
actually modem will only send and recive signal through direct cable feed it will not work by spillter, but dont worry there is device avalible in the market which will help you to connect the modem directly and also act as a spillter too better go the shop from where you brought this modem and describe your needs they will help you.
Jun 08, 2010 | Arris SB5100 SURFboard DOCSIS 2.0 Cable...
No internet signal between router and desktop pc.
have you plugged everything in with the modem off and the router off?
have you tried unplugging the linksys for a sec then plug it back in?
also have you checked the pin connection on the plug on both the computer and the router?
what are the lights indicating?
Oct 14, 2008 | Computers & Internet
How to flash my dcm425 cable modem
Ive never heard of flashing a modem before. A router you can.
Who is your ISP provider? They can get you a new modem.
Sep 04, 2008 | RCA DCM425 DIGITAL CABLE MODEM (RCADCM425)
Vizio 32" E320I-A0 LED-LCD Smart TV, Black Logo
130 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
