Question about Innova Equus 30203 OBDII CarScan Confirming Diagnostic Code Reader
<!-- from fixya rte -->What does a confirmation code mean - Innova Equus 30203 OBDII CarScan Confirming Diagnostic Code Reader
What does a confirmed code mean.states p0403 confirmed cel light stays on after replacing part
Did you reset the light after the part replacement? If you reset the light, the should read that the light is off (or show 'no codes') before the engine is started. If the light comes back on right away, with the same code, then replacing the part did not correct the problem.
A confirmed code simply means that the problem actually exists. For many codes, the first occurrence will not turn on the light. But if the situation happens again within a specific interval, it confirms the code and lights the light. Many scanners can also see the 'pending' codes (the first occurrence).
May 01, 2017 | Cars & Trucks
Unlock codes hp wildcoins wildcoins
put unlock code in the software don't put confirmation code
Jun 30, 2013 | Video Game Consoles & Games
I forgot my confirmation code for office 2007
if by confirmation code you mean activation code then you can get one direct from microsoft. on the microsoft site you click 'support', then 'activation'. the easiest way is to let the website scan your computer. After the scan, the activation code will be downloaded to your computer. after activation you can get regular downloads and updates automatically from microsoft. the microsoft website is:
www.microsoft.com
Nov 02, 2011 | Microsoft Office Professional 2007 Full...
What does the codes p1131 mean
Hi, I'm pretty sure the code is MAF code( Mass Air Flow Sensor). I will have to comeback to you to confirm this is what the code means. I myself drive a 2002 Ford Explorer XLT.
Aug 25, 2011 | 2002 Ford Explorer
I cannot open my facebook account facebook says please go to your email pankajaryan084@gmail.com to confirm your account but there is no confirmation email in my inbox.Only on confirmation email is...
Hi Pankaj,
This means that the email that you are checking is an older one , you need to wait for the new email to come to you , so that you can enter the new verification code and then it should work fine.
Hope this helps ...:) Let me know in case you have any queries.
Aug 03, 2011 | Facebook Social Network
Error code 11 on a Rinnai energysaver 556FTR
Rachel,
The 11 code means Missed Ignition. This is a broad error code. It just means the stove did not light when it was supposed to. I would check the fuel first to be sure the valve is on and you have gas. Next, try to start the stove with the room dark. Look into the window to confirm a sparking. This is the igniter. At the same time be sure the combustion motor is running. You should be able to hear it and feel the stove to confirm this. If the motor does not turn or the flue is blocked you will not get any gas to flow. Look outside to confirm the flue is not blocked.
Keep us posted,
Tom
May 29, 2010 | Rinnai EnergySaver 556 Air Conditioner
What is the confirmation code for microsoft word 2007?! Please anyone? Out there? That care's for other people? Thank you if yes. :(
You probably mean activation code.
The activation code is a proof that you have purchased your MS Word copy and allows you to update your trial version to the full one.
Mike
http://www.mswordhelp.com
May 10, 2010 | Microsoft Office Professional 2007 Full...
Confirmation code
I cannt use my facebook bcos of the confirmation code and i have been trying several time to use it but i donnot know the code pls i need ur help
Apr 28, 2010 | Facebook Social Network
Facebook confirmation
i can't open my facebook. it show that i didn't have the confirmed account. i'll try to enter the code, but i don't understand which code it means.
Jun 25, 2009 | Facebook Social Network
Innova Equus 30203 OBDII CarScan Confirming Diagnostic Code Reader Logo
42 people viewed this question
Top Innova Measuring Tools & Sensors Experts
ray gallant
Vuk B
Tom Chichester
Are you an Innova Measuring Tool and Sensor Expert? Answer questions, earn points and help others
