Air con stays open and not working ,beeps once every 20 sec or so
  • 109 Answers
Way too vague.....
Posted on Nov 16, 2014
2 Suggested Answers
  • 18 Answers
SOURCE: air con fan motor hot and wont blow cold air but heater works
capacitor or motor.
Posted on Dec 03, 2012
Panasonic air con - when you turn the air con on it runs for about 3 mins and then the timer light flashes. Air con will not work.
• Once abnormality has occurred during operation, the unit
will stop its operation, and Timer LEDs blink.
• Although Timer LED goes off when power supply is turned
off, if the unit is operated under a breakdown condition, the
LED will light up again.
• In operation after breakdown repair, the Timer LED will no
more blink. The last error code (abnormality) will be stored in
IC memory.
• To make a diagnosis:
1. Timer LED start to blink and the unit automatically
stops the operation.
2. Press the CHECK button on the remote controller
continuously for 5 seconds.
3. "- -" will be displayed on the remote controller display.
Note: Display only for "- -". (No transmitting signal, no
receiving sound and no Power LED blinking.)
4. Press the "TIMER" or button on the remote
controller. The code "H00" (no abnormality) will be
displayed and signal will be transmitted to the main
unit.
5. Every press of the button (up or down) will increase
abnormality numbers and transmit abnormality code
signal to the main unit.
6. When the latest abnormality code on the main unit
and code transmitted from the remote controller are
matched, power LED will light up for 30 seconds and
a beep sound (continuously for 4 seconds) will be
heard. If no codes are matched, power LED will light
up for 0.5 seconds and no sound will be heard.
7. The breakdown diagnosis mode will be canceled by
pressing the CHECK button continuously for 5 sec-
onds or without any operation the remote control for
30 seconds.
8. The LED will be off if the unit is turned off or the
RESET button on the main unit is pressed.
When you have the error code, we can work out what to do next.
Mar 27, 2015 | Panasonic Heating & Cooling
Harman radio 07 flhtc radio lights up no screen works ok except for beeps. i get three beeps about every 20 sec.
Radio has gone into a temp uncalibrated mode (beep) probably as a result of liquid damage (no display)
Contact Iron Cross Audio for details.
www.ironcrossaudio.com
Jul 20, 2012 | Harley Davidson 426290 AM/FM Radio
Help have onix split system air con and remote not working and it s the only way to turn it on have tried every where to get one model no is TEM-84CHSBE heat unbearable in summer nth qld aust.
Auto-restart Presetting:
The appliance is preset as no auto-restart function by manufacture. If Auto-restart function is needed, follow the
step below to activate this function:
1) Make sure the Air-con's power is off:
2) Press down and hold the Emergency button (ON/OFF )on the indoor unit then electrify.
3) Keep pressing the Emergency button for over 10 seconds until three short beeps are heard.
The Auto-restart function is then activated. To cancel the Auto-restart function, repeat above procedure until four
Remarks: When remote controller is out of work, open the panel and you can see emergency button there, see the
The emergency button for 50, 70, 90 series is at the top right, see " ON/OFF " button there.
Auto-restart set:
the appliance is preset as no auto-restart function by manufacturer. If Auto-restart function is needed, follow the
below step to activate this function:
1) Make sure the Air-con's power is off .
2) Press down and hold the Emergency button (ON/OFF )on the indoor unit then electrify .
3) Keep pressing the Emergency button for over 10 seconds until three short beeps are heard, then Auto-restart
function is activated. To cancel the Auto-restart function, repeat above procedure until four short beeps are heard.
Oct 31, 2011 | Heating & Cooling
I have an celestial air con unit model KFR-70GW/K it is blowing air refresh out but will not turn on to air con with the remote... help
Check temp setting minimum -3 degree than your room temp and also in cool mode. If while settings there any beep sound? If not transmission problem between remote and PCB. Replace batteries and check once again. If beep sound comes and no start, check compressor is working and also with proper gas pressure. Thanks.
Jan 22, 2011 | Heating & Cooling
Screen stace dark, motherboard beep 20 sec long beep then
there may be problem with your RAM or processor
please check the on your friends pc
May 06, 2010 | Computers & Internet
Turn off service light saab 93 2008
hold down clear .it will beep once .still continue to hold down for about 8 more secs and it will beep again then you should be good it will make you happy saving that money from going to the dealership for them dto do this exact same thing and charge you about $75 for pressing abutton for about 20 secs in total.
Jul 14, 2009 | 2008 Saab 9-3
My hdd beeps can i fix or data recov poss
When it beeps it means there is a motor failure.
Data can usually be recovered but is expensive.
The disk need to be opened in a facility called "clean room" if you open an hard drive in a normal environment, the smaller dust in the air will ruin the data inside forever.
This kind of service costs no less than $800.
See an example here:
Recovering data from hard disk drives with motor failure ...
Oct 10, 2008 | LaCie (300728U) 250 GB Hard Drive
Heater/air con
The heater resister switch has gone. You need to strip out the box and put a new switch in which costs around £20
Jul 29, 2008 | 2002 Ford SVT Focus
Motorola RAZR V3 - Backlight
Try removing the battery for a few seconds then restart the phone. Other than that, it could be a defective switch on the phone that detects when it's closed. If it answers / hangsup when the opened or closed... the switch is good.
Geno
Mar 04, 2008 | Motorola Mobility RAZR V3
Heating & Cooling Logo
29 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Mack Baxter
