1988 Nissan d21 hardbody pickup. Exhaust was welded on with battery connected now nothing works. Fuse block has power to top half but nothing on the lower fuses. The fusible links at the battery seem to be sending power thru and the ecu is showing codes in this order (red and green blink at the same time): 1 blink-pause 2 blinks-pause 3 blinks-pause 4 blinks-pause 5 blinks-pause Repeat. .... what's blown and where is it? How do I fix this? Opened the ecu and nothing appears to be discolored, blown, and no electrical smells.
  • 109 Answers
Need a new brain, sounds like the used a arc welder or mig welder instead of gas
Posted on Nov 16, 2014
94 nissan pick up truck wiring
images for 94 nissan pick up truck wiring
Nissan Hardbody Pickup Truck Factory Service Manuals
www.nicoclub.com/.../nissan-hardbody-pickup-truck-factory-service-ma...
Jan 1, 2000 - The Nissan D21 series pickup trucks, also known as the NissanHardbody, were ... Please select your year to access the Factory Service Manual: ...1991 - coming soon... 1992 - coming soon... 1993 - coming soon... 1994
Oct 25, 2015 | Nissan Pickup Cars & Trucks
Break and battery light stays on all the time
sold all over earth, what country> we cant guess this....
don't break the brakes....!!!
my guess, you meant the
brake lamps are on keys in pocket. and the battery lamp is dash(charge) glows, keys in pocket. right?
and battery cable kills all this illegal states above. sure.
86 nissan PU.
720 PU>? Datsun>?
or D21 Nissan ( 1986 Dat-SUNS became NISSANS. in USA)
Model years 1986.5 (second half) and later were called Nissan Hardbody Trucks, chassis code D21.
D21 are called HARD BODY trucks. mid year changes.
so???? which is yours.
as you might not ,know , the models are wired diffrent by different exact models and country.
long ago , i had the 86 with the VG30 V6...
so i will roll the dice and answer for
D21
ok?
things off stay on, 101
bad wiring, hacked in wiring, radios,alarms and other things.
all can cause this..... its old and is common on old cars.
but if wiring is not hacked, (id see that in 10seconds in person)
no hacks.
gas engine car not diesel.
USA 86 body
brakes
Im looking now at the schematic and this car has a hot at all times
brake lamp switch. (foot pedal switch)
SO only a bad switch can cause this.... period
now the dash charge (battery ) light stuck on.
my online source ,has the alternator system missing.
so can not comment.
the lamp gets its power from the key switch
if the key switch fails , all warning lanps glow not just the
charge.(battery)
so its not that
my best guess is wiring errors, that put power the the cluster
key off. id bet that is it .
wiring errors to the ignition output is side, key switched power is failing.
Jul 14, 2014 | 1986 Nissan Pickup 4WD 1986
Heater switch quit working
Hello. Check the fuse for the heater.
Apr 14, 2014 | 1991 Nissan D21 Hardbody Pickup Gray...
1988 Nissan D21 Z24 Pickup 2wd that surges and backfires upon hard acceleration
Hi SARAH,CHECK THE SPLIT PART IN THE EXHAUST MANIFOLD,IT MAY BE CRACKED,CAN'T BE FIXED,HAS TO BE REPLACE,I HAVE A 85 4X4 NISSAN,HAPPEN TO MINE,THEY HAVE A HISTORY.
Sep 28, 2013 | Nissan Pickup Cars & Trucks
Toyota pickup squeals when AC is turned on
It sounds like a loose fan or serpentine belt. You will need to apply more tension on the bely in order to stop the squealing.
Jun 26, 2013 | 1A Auto Parts 1996 Nissan D21 Hardbody...
How do the accessory fuse look for the 1986 pickup
i dont understand your question but if its the ones in interior fuse panel they are flat and have a wire in shape of a z inside them .If wire is broken replace fuse. Best of luck i own 1986 nissan hardbody d21 4x4
Feb 21, 2011 | 1986 Nissan Pickup 4WD 1986
How to find timing on 1988 nissan d21 2.4l
look at your catalyst sticker under the hood. it will tell you where before top dead center your piston should be before combustion.
Apr 16, 2010 | 1989 Nissan Hardbody King
96 nissan hardbody smock check
amına koyduğumun oğLu tamirciye götürsene !
Oct 28, 2008 | 1996 Nissan Pickup
Televison & Video Logo
366 people viewed this question
Top Televison & Video Experts
Electro Med Services...
