Question about Car Audio & Video
We have a JVC MP3 player, model MX-KC68. THe power does not come on to the unit if I push the power botton. the power botton itself has a red light and the blue light of the Ipod comes on for a second
The power to the unit power does not come on. What can we do to fix it. The red botton of the standby botton is on and stays on. Ipod light comes on for a second. Radio and CD player do not come on at all.
  • Anonymous Jul 06, 2017
    Hi did you manage to fix the problem. I have the same problem
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 65 Answers
Trace your steps check all fuses and wires. sounds like you crossed a wire or popped a fuse.
Posted on Nov 26, 2014
pnevai
  • 48 Answers
SOURCE: JVC car radio/cd player wont switch on
As a sanity check run a temporary wire directly from the battery positive to the radio. Twist the red and yellow wires together and connect it to the wire from the battery. If this works either your red or yellow wire connection under the dash or to the harness is not hot like you think. Yellow usually goes to a constant 12 volt source (to keep radio memory) and the red wire to 12volts when the ignition is on. In some radios this is reversed. The test I mentioned will determin if the problem is in the wiring or the radio.
Posted on Jun 29, 2007
KaeZoo
  • 156 Answers
SOURCE: power will not stay on
Sounds like you're not getting voltage on the accessory power lead. This is the red wire at the back of the deck, and it supplies power whenever the key is switched on. It's possible that your vehicle's radio fuse is blown.
Posted on Aug 11, 2007
  • 4 Answers
SOURCE: Kenwood KDC-119 car stereo problem
There is a small hole at the bottom of the stereo face that will reset the system. I pushed a pen tip into the hole and it turned the stereo off. When I removed the pen, the system turned on and the CD ejected. Problem solved.
Posted on Jul 03, 2008
SOURCE: Hooking up an MP3 to Alpine CDA-9805 head unit
ok when you look at the front of your system there is a button that has a (F) on it press and hold tell stuff comes on the screen then just keep pressing it tell you get to AUX off you should get it from there hope this helps
Posted on Nov 06, 2008
SOURCE: I HAVE A JVC KD-G321 CAR RADIO/CD PLAYER
I had the same problem, the cd refused and radio plays good, with JVC KD G321. I have disconnected the switches behind the radio and also disconnected the antenne (do not forget the antenne) and it played the cd again.
Jan (my english is not so good, i hope my solution is better.
Posted on Sep 18, 2009
KR-V6050 I cannot get audio to work on radio, video or any other setting. Also the red standby light stays on all the time, even when the power switch is turned off. Alan
Check the input / output connections are in the correct places. The red standby will stay on when the unit is off showing that it is ready for use. To confirm, turn the power off at the wall. The red light should go out after a few seconds.
Nov 20, 2016 | Kenwood Kr-v6050 Audio Video Stereo...
When the the unit is power up it will come out of standby for a brief moment and return to standby mode and the red light stays on.
Capacitor issues in or around your power supply area.....they have been systemically linked to many Korean/Japanese brands manufactured like LG. Quality repair shop will get you up and going in a day or two depending on their queue....
Dec 17, 2010 | Televison & Video
Recently, when I take the ipod off the Zeppelin, I hear this strange sound, not a hum, but higher in pitch, from the speakers, and when the blue light starts flashing like it's in standby the sound warbles...
there are issues relating to the older models, until the power supply board ahs been replaced and the unit tested, it is hard to say, b and w are fixing units because of the known problems, so check with their service desk.
Nov 26, 2010 | B&W Bowers and Wilkins Zeppelin iPod Music...
Ps2 does not come off standby!
The problem is with your power flex and it needs to be changed. i advise that to avoid this occurrence you give your console time to rest.
Dec 23, 2009 | Sony PlayStation 2 Slimline Console
Power botton stay red
If the PSU is confirmed working, it is either something wrong with the microcontroller in the southbridge that controls the power on sequence, the linear regulator that powers it and/or the ROL board, or a short in the 5V standby (blown capacitor, transistor, etc).
The easy way to determine which one of these is the problem is to look at the light on the PSU, if when you plug it into the 360 it turns red briefly (or stays red), there is a short on the standby power (If the short was on the switched supply, the 360 would power up then flash 3 red lights with error 0001 or 0002, or power up for a split second then shut itself off). Also measuring the resistance from 5VSB to ground is a pretty sure fire way to tell
If the 5V standby power is NOT shorted, then the issue is either in the power button on the RF board (easily tested by powering up the box via another method), the southbridge, the the voltage regulator supplying it.
The two regualtors are U5B1 (3.3V) and U5B2 (1.8V). They are located on the top of the motherboard near the back, jsut to the left of the large screw hole in the center of the motherboard (near the fans). The large tab opposite the 2 smaller pins is the output of each regulator, so they should measure 3.3v and 1.8v respectively when the 360 is in standby (off but plugged in).
If those measure ok, then I'd say the southbridge is dead (that motherboard is nothing but a nice paperweight)
Dec 07, 2009 | Microsoft Xbox 360 Console
After turning ON the power/standby switch, the unit(receiver) display comes ON (green light) then after approx.4-5 seconds the display goes OFF and the unit defaults back to the standby mode (red light). I...
Is the red light flashing at first?
The unit may be going into protect mode. Lets hope it has done the job and the receiver has protected itself from failure.
Protect mode can result from speaker wires touching each other or the Amps2_bing.gif metal case. Check that first.
It can also be caused by unstable ohm loads if too many speakers2_bing.gif are connected to any of the outputs especially zone 2.
If you can remove all speaker wires and turn the unit back on. If it stays on, turn the volume down on the main zone and zone 2 if connected. Then reconnect speaker wires.
Nov 16, 2009 | Denon AVR-485 Receiver
The Power Light is Red
yeah, should stay red when unit is turned off, indicating there's power but it's doing nothing.
Per user manual:
Solid red - power off (standby mode)
blinking red - power off (now cooling)
blinking green - power on (preparing to light lamp)
solid green - power on
Mar 08, 2009 | Panasonic PT-40LC12 40" Rear Projection...
Red light comes on but the shuts off?
Mine did that and it really pised me of, sony told me to turn the power switch onthe back of the console on, when the stand by light comes on to push and hold the on button for at least 3 seconds until you hear a second set of beeps. This however didn`t work so I sent it back to Sony Australia and got it fixed up no worries.
Oct 11, 2008 | Sony Playstation 3 (PS3) Console
Car Audio & Video Logo
163 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
