Question about Brother SE400 Computerized Sewing and Embroidery Machine
I have a Brother se400 brand new today. When I turn it on it makes a rattling noise when the needle moves. I also have a Brother NV500 cassette threading system and when it starts it is very quiet. Th
I have a Brother se400 brand new today. When I turn it on it makes a rattling noise when the needle moves. I also have a Brother NV500 cassette threading system and when it starts it is very quiet. This rattles like something is loose inside. I have embroidered with it and have tested every stitch function all is well but this just doesn't sound normal. Would anyone possibly have an answer for this?? Thank you so much for any help or assistance. Best regards, Debi
    New Friend:
  • 185 Answers
Debbie the sound you are hearing is the needle width stepper motor initializing. This is normal. Do not be concern.
Posted on Nov 18, 2014
  • 46 Answers
SOURCE: Machine makes a loud noise and will not make stitches.
sounds like something is broken. best to get it checked out. take to the sewing machine doctor.
Posted on Oct 24, 2008
SOURCE: Thread tangles under throat plate while embroidering
Could the little hook that is stuck over the bobbin area be the thread cutter? My thread cutter gets stuck there and I have to turn my machine off and then try to use the cutter to reset it to its "resting" position.
Posted on Feb 04, 2009
  • 3 Answers
SOURCE: brother pe-150 starts to embroider then totally jams
needle might not be fully pushed up in shaft, or wrong size bobbin is used
Posted on Jun 11, 2009
  • 96 Answers
SOURCE: stitching loose. won't thread the fabric
try to rethread the machine all the way back to the spool of thread and check the top and bottom tensions on scrap of same fabric
Posted on Dec 13, 2009
  • 1116 Answers
SOURCE: Brother CS-6000i - the bobbin thread is not coming
Check list:
1 - Flat side of the needle is facing the back of the machine.
2 - Threaded machine with the presser foot up - always.
3 - Bobbin thread is feeding from the spool in the correct direction and through the proper guides.
Lower and raise the threaded needle, holding onto the end of the thread.
If this does not pull the bobbin thread up, the timing may need adjusting.
There is a graphic for doing this as sewusa.com or take it into the dealer for service.
Posted on Mar 10, 2010
My 1 year old Brother SE-400 bobbin is spinning and making lots of noise. I have cleaned all I can gain access to, and I have put in new needle and made sure it is tight. I have confirmed that the b
You have done well so far. Check the thread to make sure it is not too thick or thin. Also, that the bobbin is not over full. Also make sure it is threaded correctly. Check the manual as you do this. Otherwise, find your warranty and return to shop.
Oct 16, 2014 | Brother SE400 Computerized Sewing Machine
Thread not catching to bobbin
Hai, How many heads in your embroidery machine? As far as you should have brother embroidery machine's maintain and handling is smooth and carefully. Please check the timings. Otherwise ask your machine mechanic.
Mar 19, 2014 | Brother Se400 Computerized Embroidery &...
Needle bar frozen
Rather suspect the bar has bent, remove it and check for true
Dec 18, 2013 | Brother SE400 Computerized Sewing Machine
Needle position won't hange
When you turn the machine on does the needle bar initialize? I.e. Move to the left, then to center.
Nov 03, 2013 | Brother SE400 Computerized Sewing Machine
Needle falls out of my brother se400
you may want to have the needle holder check to see if it needs
to be replaced.
Feb 01, 2013 | Brother SE400 Computerized Sewing Machine
Nv500 brother machine maked a grinding sound and wont stitch it just gathers and knots can you sugest what it might be?
Something is bound up. Stop trying to sew. Turn off the machine.
Take off the foot, take out the needle, take off the bobbin cover, take of the needle/throat plate and check for the reason for your problem. Look for lint, threads caught up underneath and in between the parts.
Clear all that out and put it back together and attempt test seam.
Nov 19, 2012 | Sewing Machines
Brother SE400 Hand wheel is very tight and the needle will not go down
if the machine is brand new then it needs to go back & get another one
Mar 27, 2012 | Brother SE400 Computerized Sewing Machine
My brand new machine Brother PC 420 is making a clunking noise as the needle moves as if the timing may be off? What is this?
Make sure that your needle is inserted all of the way up, maybe even install a new one, just to be sure. Recheck your threading, with presser foot up, pull top thread, should pull smoothly, now put the presser foot down, pull again, should barely move. If, you are sewing on a bare table, try putting a bath towel under it. If, noise continues, return it and get a new one.
Nov 05, 2010 | Brother PC-420
Brother SE400 Computerized Sewing and Embroidery Machine Logo
222 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
