Question about Video Game Consoles & Games
How do I fix cd door, it wii not open? - Video Game Consoles & Games
    Problem Solver:
  • 8 Answers
What type of console?
Posted on Nov 26, 2014
Just got a new wii and it was working fine but now the controller has stopped working and the wii wont connect to the tv???? Can you help????
Hello!
First: Check to see if the batteries are good, easiest way to do this is try putting different batteries in that you know are good.
Second: If your batteries are not the problem, then first, open the memory card door (little door on the front of the console under the CD slot) and press the red button(or known as the sync button) and open the battery case and press the little red button(or known as the sync button) and it should reconnect.
Third: If the Wii is showing that your Wii Mote is connected but it isn't responding, make sure your Sensor bar is in a clearly visible location in front of or on top of the TV. Make sure that it is properly plugged into the Wii in back.
Fourth: If none of these resolved the issue it is likely that your Wii Mote is just flat out broken. If you just purchased your Wii I suggest contacting Nintendo to RMA (return) the Wii Mote for a new one.
May 30, 2011 | Nintendo Wii Console
The wii console wont read games. it tells you to turn console off and read manual
the laser eye inside that reads the games is dirty, you can use a cd disk that cleans the eye when cd is inserted,which you can get anywhere for a few bucks like walgreens,kmart,walmart,jewel,best buy to name a few, sometimes you need to have someone open the wii up, with a specical tool and clean the laser eye with a q tip and a very small amount of alcohol on the swab, I have fixed wii's this way many of times!!!
Jun 28, 2010 | Nintendo Wii Console
There is power on the console and both remotes and the wii fit board but it will not synchronise. i was told at our local Game store that i have to update the system by going on the internet. how do i do...
In the Wii fit board where the batteries are is a red button. On the WII console there is a flip door up front, by the CD drive and you open to insert the SD card and there is a red button inside.
Push both red buttons and your Wii fit board should synchronize with the console.
Mar 12, 2010 | Nintendo Wii Console
Some one forced 2 discs into the wii, know it
it needs to be opened and fix the cd holder
Jul 02, 2009 | Nintendo Wii Console
Console ejects my cd
Your disc is stuck in Wii Console, It needs to eject manually. You might check out Wii Fix Guide, that gives step by step information on Dis-Assembling with screenshots, even a novice can fix the disc eject problem with the help of this DIY Guide. It also gives information on fixing many Wii Related Problems, so its a kind of Wii Problems Reference Fix Guide
Jan 13, 2009 | Nintendo Wii Console
2nd Wii remote not working this is the 2nd one
press the sync button on both the wii and the wii remote through the batt door on the remote and the button behind a door like thing next to the disk slot the blue lights flash then press wii red sync button again while pointing remote two at the sensor this should bring it on line !!!!!
Jan 01, 2009 | Nintendo Wii Console
Eject
get a technician to look at it or take the wii apart yourself if you're brave enough to see if anything is jammed. nintendo may fix it if its a fault in a mechanism but otherwise you'll need to see a seperate technician
Sep 14, 2008 | Nintendo Wii Console
Wii remote
Wii Remote problem is one of the common problem of Nintendo Wii. You may check out the DIY Wii Fix Guide, that explains step by step to fix the problem without any technical knowledge. I hope this guide will solve your problem. It also gives information on fixing many Wii Related Problems, so its a kind of Wii Problems Reference Fix Guide.
May 18, 2008 | Nintendo Wii Console
Multiple cds inserted into Wii at same time
In CD's there is an emergency lock which you can open to come out the tray.
On the CD shutter you can see a very small hole in which you can only insert niddle or thin wire. Try to find out this.
  1. Make Power Off
  2. Take a hard thin wire or long niddle.
  3. Insert the niddle in the hole.
  4. Push it gently, press a lillbit harder when it stricks any thing inside.
If you notice that the door is opening then push more hard till you can pull the shutter out with your finger.
And dad don't be angry............:)) lol
If you don't find the emergency lock opener then you have only way to remove cover...
Thanks
Iqbal
Apr 06, 2008 | Nintendo Wii Console
Video Game Consoles & Games Logo
29 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
