I have a 2 wire system. W & B what colors are they attached to Indiglo 44255
    Master:
  • 602 Answers
For a 110 volt unit the white is wired to the neutral buss and black to power . For a 230 volt unit both wires are hot one to each side of incoming power at the load side if the relay.
Posted on Nov 17, 2014
Testimonial: "Thanks JCS. Sorry I do understand your answer. But my problem is the two wire going to the thermostat. there are at least 6 slots from yellow, Green, etc to red and Rw. which slots would a two wire system go to. Thanks in advance."
How do I connect wires by color code for reinstallation of something?
images for mower How do I connect wires by color code
Is the Positive or Negative Cable Attached First in a Lawn ...
homeguides.sfgate.com > ... > Real Estate Rental & Lease Basics
Attach the positive cable first when working on a lawn mower battery. Nearly all ridingmowers and many walk-behind mowers are equipped with a battery for ...
free wiring color codes Riding Mowers & Garden Tractors ...
www.fixya.com/...wiring_color_codes/riding_mowers_and_garden_tract...
Ask your free wiring color codes riding mower and garden tractor questions. ... ENDSDO NOT MATCH FEMALE ENDS ON COLOR CODE CONNECTIONS ...
Nov 26, 2015 | Garden
Timex Indiglo night light clock's stem for setting the alarm is missing
I'm afraid you can't because this is not a workshop, but have you tried a watch/clock repairer or jeweller who may have a part which will fit it, or look on ebay for one, either new or for spares. Also you don't state your location (e.g U.K. or USA) so hard to advise further. You could also contact timex directly (google timex contact us) but the address depends on your location.
Apr 06, 2014 | Timex t105w indiglo 7-color night light...
Electrc trailer brake wiring schematic
Not knowing the year or model makes this impossible to answer.
Dec 28, 2013 | RVs
INDIGLO WATCH WANT TO SET THE TIME FORWARD ONE HOUR.
Welcome to FixYa!
See instructions below on how to setup the time.
Thank you for using FixYa! Have a great day.
Jas247
May 03, 2011 | Timex Marathon Color INDIGLO 5E641 Wrist...
Old dimmer switch has 2 black wires, one is attached to another black wire & the other is attached to a white wire. The new dimmer switch, Pass & Seymour legrand R600-PIV has 3 wires, 2 black...
If the directions didn't give you specific connections, look at the color of the stranded wire inside the insulation. If one is gold and one silver, the gold goes to the black incoming, the silver to the white incoming, and the green is ALWAYS ground.
If both of your stranded wires from the dimmer switch are silver, either can be connected to the black and white. Green is always ground.
I hope this helps. If it does, I'd appreciate your vote. Thanks for visiting fixya.com
Handie andie
Apr 15, 2011 | Garden
Are instructions available online for how to set Timex Timex T025B Indiglo Color Changing Alarm Clock? Thanks for directing me!
I will advice you check manualsonline.com to search for the instruction manual of your Timex T025B Indiglo
Mar 30, 2011 | Timex Watches
When i turn on the chlorinator its comes on and then turns the power off to the whole unit
Please dragon, Be careful. If the chlorinator is not wired to the unit correctly you could ven have a
flash!! 1. Shut off the circuit breaker located on the house. Ir's located in
metal rectangular panel. Probably next to the elect meter.
2 Now that the power is off check the wiring where the chlor attaches to the pump.
The wires should be color coded. Black & red are always the hot leads, white & green are
neutral leads, Let me know........dansky66
Mar 26, 2011 | Intex Automatic Salt Water System for ...
Chrysler Part No. P56038933AB Radio Wire Color code
1982 to 2001 wiring harness color code Chrysler.
12V constant pink or pink/white stripe
12V accessory red/white stripe
Antenna/Amp turn on white
12V Illumination black/yellow stripe
Left front + dark green
Left front - brown/red stripe
Right front + purple
Right front - blue/red stripe
Left rear + brown/blue stripe
Left rear - brown/yellow stripe
Right rear + blue/ orange stripe
Right rear - blue/white stripe
there is no ground wire in the harness, the metal braided strap is the ground.
use a ring terminal,speed clip, and screw to attach the ground wire from new radio
when replacing infinity radios and speakers, there are 4 wires instead of 2 at the speaker plug. the large gauge blue and black wires are the power supply for the amp, the other 2 are signal wires from the deck and will match up to the wire color codes above. simply cap off the power and ground and use the other 2 for speaker leads.
One thing i hate to see is someone who just hacks off the plugs behind the radio because they are too cheap/lazy/dumb to buy a wire harness adapter for the nice new aftermarket deck they just bought. ive seen everything from masking tape to house wire nuts used to connect wires, and they never last.
there is only 1 reliable permanent way to connect wires together - SOLDER AND SHRINK WRAP!!! whether you're connecting wiring for a radio, fog lights,repairing a cut wire, etc solder those wires, you'll be glad you did when you never have a problem with that circuit again.
This is a listing for part #'s for dash kits wire harness adapters
all part numbers are metra unless otherwise noted
dash kit 99-6700, 99-6701 and 99-6500 will work for most cars
wire harness adapter 70-1817
reverse harness( to replace factory plug that have been cut off) 71-1817
speaker adapter plugs 72-6510, non amped 72-6513 when equiped w infinity system and bypassing fact amps
no antenna adapters are required until you hit 2002 model year.
beginning in 2005 chrysler switched to a high speed LAN system in all its cars and trucks. there is no longer a switched ignition lead in the harness.
Good Luck
Leadispenser
Aug 25, 2008 | Kenwood KDC-MP235 CD Player
Heating & Cooling Logo
27 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
