Question about Venstar T1700 Thermostat T1700
I have a venstar t1700 thermostat which required a 24v transformer, hooked the two wire to R and C. Thermostats lights up and functioning. I have two wires running to propane heater a red wire and whi
So close would love for this to work! Please let me know
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 484 Answers
R and C are the power terminals to the thermostat allowing it to run on 24 volts and not under battery power alone. Assuming that you used the R and C terminals from the propane heater to power the stat and NOT an external transformer, the W terminal on the thermostat then is connected to the W terminal on the propane heater. W energizes the heating control circuit when the thermostat calls for heat. The remaining portion of the control circuit should be prewired from the factory internal of the heater. If you do NOT have these terminals, more information is required for us to help you.
Posted on Nov 23, 2014
Have model md5tpa Pro-com wall heater. heater will not go out with thermostat, you have turn dial off.
If it worked before but won't work now, you could have a bad connection at one end or the other of the thermostat wire, no voltage from the 24v transformer, or a bad thermostat. Some thermostats use batteries in conjunction with 24v power. Check to see if yours does.
Dec 19, 2016 | Heating & Cooling
New thermostat requires "C" wire, my old one did not, where should I connect it to?
'C' is the standard abbreviation for Common...meaning the grounded side of the low voltage transformer inside the furnace or air handler. 'R ' is the 24v hot side and 'C 'is the 24v neutral side. Across the two, you will read 24volts.
Dec 07, 2015 | Heating & Cooling
How do you unlock it?
How to Over-ride the settings on your Honeywell Thermostat ...
? 0:58
https://www.youtube.com/watch?v=ofenS8mOJDs
Oct 18, 2010 - Uploaded by Sherlock Homes Austin
If you've just bought a new David Weekley Home at Mueller, youmay ... How do I "factory reset" the th8320zw honeywell thermostat? ... Would that be the same for Trane thermostats? ...is there a way to unlock the screen?.
Venstar. T-1700 Thermostat. Which Buttons Do What ...
? 4:21
https://www.youtube.com/watch?v=PbfyzplRYco
Mar 9, 2013 - Uploaded by OcRefrigeration & H.v.a.c.
I will do a Video on Programming the T1700 at a Later Date. Soon. Similar thermostats include---Pv100 and the Pv110. Serving--- All of Orange ...
Oct 18, 2015 | Universal NIB LUXPRO PSP511L Digital...
I have a T1700 in my apartment and my air want shut off and i see a lock symbol on it how do i shut it off
Do you mean a Venstar T1700 thermostat? If that is the case, the Lock symbol merely indicates that the keypad is locked to keep people from reprogramming the thermostat. This prevents anyone from quickly changing the target temperature or the swing temperature (the temperature at which the unit turns on) for the HVAC system. To unlock the keypad, press and hold the Mode button. Then press both the Up and Down arrows. Release all three buttons when the lock symbol disappears.
If the AC has cooled your apartment to a temperature below the target temperature for the current time period, then the control board of the HVAC may be damaged. (It isn't getting the message and has failed in the on position.) Contact an HVAC repair professional.
If the thermostat is indicating that the room hasn't reached the target temperature, then you should replace your thermostat. The thermistor has failed. (Contact Venstar if the thermostat is less than one year old.)
I hope this helps.
Sep 27, 2014 | Heating & Cooling
I am wiring a Honeywell wifi unit and I used a separate 24v transformer and connected to the c and rc terminal. My system is ac and heat and uses both and rc and rh wire. I wired the rc to the r ter
A thermostat is a switch. It connects 24vac from one terminal to another depending on the request. The 24vac comes from a transformer, usually located in the furnace and connects to the R terminal. Since you are using RH and RC without a jumper between it means there are two transformers, one in the furnace for heating (RH) and one in the air conditioner condenser used for cooling (RC).
Your old thermostat was probably mechanical and did not have a C (24vac common) terminal. Your new thermostat requires power to operate therefore needs a wire connected to a C terminal. I would get rid of the transformer you added and look for an unused wire in the bunch at the thermostat. If it's there connect it to C on the thermostat and to C on the furnace. Remove any jumper from R to RC or from RH to RC depending on your thermostat and connect wires same as the old thermostat.
Jul 04, 2014 | Heating & Cooling
Blown Transformer heat pump
blown transformers are usually from a low voltage short the first thing i would do is wire a automotive or resetable 3amp fuse in line with the transformer so you dont blow transformer after transformer the wire coming off the transformer that say 24v take that wire a couple of inches down and cut it and install the fuse in series there
24v----------------
24v----------x----------
24v--------{3ampfuse}----------
now you can go through your low voltage wires one by one and test them unhook all the wires to your outdoor condenser at your indoor unit(furnace or airhandler) and try turning it to cool now if you blow the fuse the short is between the tstat and the indoor unit if the fuse is still good leave it on cool and hook up one wire at a time to your outdoor unit starting with R a lot of times your contactor or your defrost board will short out on you also look for pinches in wires wires with cracks in the insulation and wires touching metal this situation can be a real pain sometimes i would recommend calling a hvac company if you start to get stumped
hope this will help you
Jul 26, 2009 | Ruud UBHC Air Conditioner
Thermostat wiring
Thermostat wiring depends on which thermostat you are using. The blue wire is typically used for the 24v common. The red is your 24v power. If you have one transformer you will jump RC and RH.
Feb 16, 2009 | Honeywell Programmable Thermostat Heater
Honeywell Chronotherm IV Plus requires frequent resetting.
Check to see if you have wires going to a C/C1 terminal. The older chronotherms used a transformer to supply 24 volts to power the clock. If in fact you do have these terminals, then I would suggest checking the output voltage on the transformer, (secondary (24v)side) to ensure it isn't close to dead. Hope this helps
Nov 28, 2008 | Honeywell Programmable Thermostat Heater
Wiring diagram
C--=common r-red=power y-yellow=cool g-green=fan w-white=heat..!
Sep 05, 2008 | Honeywell Programmable Thermostat Heater
Honeywell thermostat
If you have a forced air furnace with an air conditioner attached make sure you have a jumper wire between Rh and Rc. If the Bryant thermostat had a wire hooked up to C you do not want to hook this up to Rc. Just cap it off and put it back in the wall or disconnect that wire down in the furnace.
Aug 10, 2008 | Honeywell Programmable Thermostat Heater
Venstar T1700 Thermostat T1700 Logo
109 people viewed this question
Top Venstar Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you a Venstar Air Tool and Compressor Expert? Answer questions, earn points and help others
