Question about GE Washing Machines
Can I adjust the water fill valve on my G.E. washer?
Water won't fill up enough to wash clothes. Fills to different levels when set on "super".
  • 603 Answers
You have a blockage between water valve to machine , hoses, or the valve that the hoses are attached to on back of machine. if you have hard water that valves small filter could be clogged up with small mineral deposits. You can remove this valve after removing top of machine, and clean it or you can replace the valve. GOOD LUCK FRIEND.
Posted on Nov 16, 2014
zeusfaber
  • 247 Answers
SOURCE: Washer fills and drains repeatedly
Have a look at the routing of your drain hose. It sounds a bit as if: a. The highest point of the hose isn't high enough (you normally want to aim for about 3 feet off the ground) - so that water starts draining from the machine before it is finished filling. and b. There isn't an effective air break or anti-siphon valve where the drain hose goes into the domestic drainage system - so that once the machine starts to drain by itself, it continues until empty. A.
Posted on Jun 07, 2007
Washer_tech
  • 164 Answers
SOURCE: Not enough water
run the machine empty. if the water comes to the bottom of the glass window, you're fine. No you don't need to see the soap suds either, too musch soap will cause the machine not to function properly and won't spin out all the water
Posted on Nov 17, 2007
Washer_tech
  • 164 Answers
SOURCE: Washer Fills/Drains at the same time
check that the drain hose saises above the water level of the tub. I f the hose does not come above the water level, the water will just drain right out
Posted on Dec 01, 2008
  • 54 Answers
SOURCE: Washer fills with water but wont continue washing cycle
Your lid switch is bad or loose.. open and close your lid and see if you can hear clicking noises.. if not.. then your lid switch is broken.. good luck
Posted on Jan 21, 2009
TheMobilian
  • 8220 Answers
SOURCE: My washer fills with water and keeps filling
The problem is simple and easy to fix. Your washer has a tubing which runs from the base of the tub to the water pressure switch. It might have vibrated loose from the switch, or their can be some sediment in the tub. Blow out the tubing and reattach it securely to the switch and pump out the water in the tub. Then try it again. I wrote an article about this:
Help my washer is overflowing !!!
Posted on Jan 07, 2011
Washer continuously fills
Not sure if you mean that it fills all the time and overflows or you mean that it just always fills and never has enough water.
The first problem would refer to a faulty water level switch - need to replace.
The second would be that the washer drains as it fills - if the drain hose is lower than the washer, inspect the anti-siphon valve.
Apr 10, 2014 | Maytag PAV2300 Top Load Washer
GE top load energy saver washer does not seem to fill enough
No you can't adjust because of the auto sensor
Oct 12, 2012 | Washing Machines
I get error FE- book says unplug and call a tech. Is this something I can fix myself?
FE error means that the water is filling past it's set point. You may have a broken water valve that won't shut off when it's in the filling mode. You can check by running the washer and watching the water fill. If the water level fills above the bottom of the glass, you have a water valve that's not shutting off. Replace the water valve.
Aug 21, 2011 | LG WM2487H Front Load Washer
Lg intello WD1243FH low water level? My Lg will not fill with water properly. It only lets in enough water to get the clothes wet then stops filling. I tried filling it manually through the drawer but as...
Try adjusting the water lvl going into the washer. Adjust accordingly. If you have a meter, just the resistance of the valves. Unplug of course. It should read about 1.4k ohms ish. Could be higher or lower but roughly that.
Apr 28, 2010 | LG Washing Machines
Water not filling.
r u using auto fill mode?if u r then try selecting high medium or low. check water pressure coming out of inlet hose, could b faulty valve not letting enough pressure thru.please reply if u need more help
Mar 14, 2010 | Fisher and Paykel GWL11 Top Load Washer
Not enough water to wet all the clothes.
Either the water level switch has bad calibration or the water level tube has lost its air seal and needs to be refitted and air locked. If you do not know how to go about these tasks, call someone with experience. Goodluck, Macgivor
Jan 16, 2010 | GE Profile Harmony WPGT9360E 4.0 Cu. Ft....
Washer over fills and water comes out the door. Water continues to run even durring the pump out cycle just before the spin cycle
  1. Water inlet valve. It may not be able to shut completely when the electricity to it has been turned off. The valve may leak and drip water into the clothes tub. Water may accumulate substantially and overflow. Remove the washer's cabinet to access it.
  2. Water level switch. This switch senses the water level in the clothes tub. It is usually a diaphragm device with a small clear tube attached between the switch and the bottom of the washer's outer tub. As the water level in the tub increases, the air pressure in the tube increases and activates the switch when the water reaches a certain level. When the switch is obstructed, it cannot tell the water to shut off and the machine overflows.Clear it from any obstruction.
  3. Air-hose. It is connected to the water level switch through a tube. If the tube or hose is cracked or broken, no enough pressure builds up to trigger the switch and shut the water supply off. Check it for any obvious damage.
Oct 08, 2009 | Maytag Neptune MAH5500B Front Load Washer
Hot water stream when tub fills & how full tub gets super wash
there should be a knob connected to your water lines that come from the wall, turn the hot to the left.
Jun 22, 2009 | Estate Washing Machines
Can you adjust the water level on the LG Tromm WM1814CW? The water level when washing and rinsing is so low that the clothes are barely wet when the washer has finished.
No. Water level is not user adjustable. The washer will automatically put in the correct amount (about 3 inches in the bottom of the tub) and adjust for load size and type. This level is all that is needed. The reason the clothes are hardly wet at the end of the cycle is due to the high spin speed (compared to almost all top loading machines). If you want to see how wet the clothes really are, pause the machine mid cycle and the door will unlock and you can see, or select a "no spin" option and see at the end of that cycle. You will use about 12 gallons of water for a large load, vs. about 45 for a top loading machine, so remember to adjust your soap and fabric softener use accordingly. ( one tablespoon detergent and one teaspoon fabric softener maximum per load)
Mar 29, 2009 | LG WM1814CW Front Load Washer
Washing Machines Logo
117 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
