Question about Cell Phones
HOW DO I UNLOCK SCREEN TO RESET
CANT UNLOCK SCREEN
Sam sun gal note 4 screen black cant see to unlock..i need to unlock to reset and send back to samsung
If you use your PC link that may do it or shine a bright light at the screen, if the back light has failed, you should be able to see what to do.
Mar 20, 2017 | Samsung Cell Phones
HOW TO UNLOCK LGL34C
How to jail break the lgl34c
Oct 22, 2014 | LG Cell Phones
Screen frozen
you should try a soft reset and failing that, copy all your photos etc. onto a desktop computer or external hard drive then factory reset.
Apr 16, 2014 | ZTE Avail-Z990 Avail At&t Unlocked Android...
Screen locked and unable to unlock
Turn off . Press and hold POWER + ENTER button for reset menu.
Select
Factory reset with Volume Down button and press Power to reset. All data will be lost! there is an alternate method too friend
Use this method to hard reset your Samsung GT-S Galaxy mini phone: Enter *2767*3855#. Warning! All your data including contacts, messages etc. will be lost! Copy all your necessary data/Contacts/Messages etc. to SIM or make backup to your PC before full reset! Take out SIM card before full reset.
Samsung GT-S5570 Galaxy mini download mode if you want to install eg. Gingerbread
Press and hold Volume DOWN + HOME + POWER ON S5570
Restart your device to clear any temporary software bugs
If you know the hard reset with buttons / keys, pls leave a comment. All comments are welcome!
Your device freezes or has fatal errors
If your device freezes or hangs, you may need to close programs or reset the device to regain functionality. If your device is frozen and unresponsive, press and hold [Power] for 8-10 seconds. The device will reboot automatically.
If this does not solve the problem, perform a factory data reset. In Idle mode, open the application list and select Settings :Privacy
:Factory data reset :Reset phone : Erase everything.
Clear storageā€¢ : Erase the credential contents from the device and reset the password
Set an unlock pattern
Once you set a screen lock, your device will require an unlock code each time you turn it on or unlock the touch screen
Settings Location and security Set screen lock : Pattern
If you forget your PIN or password, bring your device to a Samsung Service Centre to reset it.
Set an unlock PIN code
Settings Location and security :: Set screen lock : PIN
Set an unlock password
Settings Location and security :Set screen lock : Password.
You can hard reset software firmware update your Samsung GT-s Galaxy mini phone
Hope it helps u
Dec 08, 2013 | Samsung Cell Phones
How to unlock my coby
This is the "master" reset procedure. No other way of clearing the unlock pattern.
*******This procedure will delete all items (file's) and entries on the unit******
Step 1- Power the unit off. Press and hold the "Power Button" till the "Device Option menu appears.
Step 2- Click on "Power Off and select "OK" .
Step 3- Once the unit has been turned off. Press and hold the "reset" button and "power" button simultaneously for eight seconds.
Step 4- The following screen will appear. Press the "reset" button.
Step 5- The Android system recovery screen will appear.
Step 6- The "Home and Menu" button will allow you to go Up and Down the Android system recovery screen.
Step 7- Press the menu button to go to "wipe data/factory reset". . Press the "reset" button.
Step 8- The following screen will appear. .
Step 9- Press the Menu" button to select "Yes- delete all user data".
Step 10- Press the "reset" button.
Step 11- The following screen will appear .
Step 12- Press the "reset" button to reboot/restart the unit.
Aug 18, 2012 | Coby Kyros 716829701508 Tablet PC
My phone screen doesnt work
Try Hard reset...else if u have rooted your device...then go to recovery and take backup and install custom rom....
Mar 25, 2012 | HTC Desire Z Cell Phone
Imate pdal touch
my mobile was in locked condition, and now my touch is not working..not even a single tap is working on mobile screen. i did soft as well as hard reset but every time the unlock screen appears after boot process. i can only press the unlock button on screen from the left button on mobile and cant press Unlock again because it is on the screen.
I believe in this situation, only two options can be used, One is to attach a Keyboard, or to access the mobile screen through any software on PC.
Nov 11, 2008 | i-mate PDAL Pocket PC
Locked my i mat jamin
Do a soft reset,if that doesnt work you"l need to replace the screen!!
Feb 22, 2008 | i-mate JAMin Smartphone
Cell Phones Logo
67 people viewed this question
Top Cell Phones Experts
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
