Question about Samsung LN52A650A LCD TV
Still trying to troubleshoot horizontal lines on my tv. so bad, can't watch. have been in contact with "The Knight". so far no luck.
Have taken off back of tv, caps look good,have not put meter on caps. thinking of replacing power board. any suggestions especially from "The Knight". any and all input would be appreciated, thanks,steve.
    Top Expert:
  • Samsung Master
  • 74,136 Answers
Hi Steve
The power board to your TV is working fine now. If you're determined to make experiments with it; just carry on!! Replace the boards. one after another, till the fault is rectified.
Posted on Nov 16, 2014
relectronics
  • 38 Answers
SOURCE: SAMSUNG LCD TV horizontal lines
causing of horizontal lines is leaky or defective capacitors. check big value capacitors around the board at Horizontal area. check the filter capacitor as well. good luck
Posted on Apr 20, 2008
romsky79
  • 822 Answers
SOURCE: Samsung Plasma Lines and Colors on Screen
yes it can fix. its only loose connections from LCD connectors. trust me. romsky79@yahoo.com
Posted on May 29, 2009
SOURCE: Samsung HPR4252 with red horizontal lines accross the screen
I just had my HP-R4252 repaired on 12.05.09 with a similar problem. The picture is covered in horizonal, broken lines and the color is predominately red. They lines are grouped together in large bands across the screen.
The tech replaced the Y-Buffer boards (Up) and (Low) in about 20 minutes.
Samsung BN96-02034A BOARD, Y BUFFER UPPER ASSY
Samsung BN96-02216A BOARD, Y LOWER BUFFER ASSY
Posted on Dec 06, 2009
  • 927 Answers
SOURCE: Samsung model LNT5271f excessive relay cycling before full power
Howdy,
Yes, it is very easy to repair. Solder iron wattage should be at least 300 w.
The PSB is the center Board (towards left) after you remove the back off the TV. Remove the shield that covers the Boards and remove Board from TV with the 6-7 screws. Replace capacitors CM852 & CM853; 2200ufd 25volts.
Good Luck, big IRISH.
Posted on Dec 28, 2009
Testimonial: "Great fix"
  • 53 Answers
SOURCE: My tv Samsung HP-R4252, have Y-Main board
Do you have more specific information on your set, such as the full product model? Such as: HP-R4252X/XAA? What about the version?
This can help, because--as of right now--you are telling me that you put that Philips part into your Samsung TV. The LJ41-02759A is made for a range of Philips sets. They may work, don't get me wrong, but the part # for your Samsung set is: BN96-02033A
I don't have both these boards in front of me, of course, so I can't tell you if they cross or not.
Hope this helps.
Posted on Jan 22, 2010
My LCD TV has a vertical line on the right side of the screen. What causes that?
Search Results
    how to fix horizontal or vertical lines on lcd tv - YouTube
    ? 4:52
    https://www.youtube.com/watch?v=k2QpYJp6MU8
    Apr 12, 2014 - Uploaded by cr4zyw3ld3r
    how to fix horizontal or vertical lines on lcd tv ... Bad T-Con/Mainboard(causes vertical/horizontal lines or half of thescreen is black)
    How to fix / repair vertical lines on half of LCD tv screen ...
    ? 5:23
    https://www.youtube.com/watch?v=8P_i-JIsrYA
    Jan 27, 2012 - Uploaded by chipotletv
    It shows how I fixed the vertical lines on the right half of a Samsung LCD screen tv. Music on video "Crazy ...
    how to fix led tv vertical lines on screen 55 ... - YouTube
    ? 9:47
    https://www.youtube.com/watch?v=zE0eqB4Ppjw
    Nov 11, 2012 - Uploaded by LUFERQUINT
    HOW TO FIX LED TV VERTICAL LINES ON SCREEN 55" MODEL LG ... YOU MAY HAVE, GIVE IT A TRY BUT DO IT ON YOUR OWN RISK!
Jan 26, 2016 | Televison & Video
Horizontal lines on Samsung Plasma
The most common cause for the loss of picture is a bad Horizontal Output Transistor (HOT). but I would suggest you get a detailed estimate. I think that this would cost you about $60.
The horizontal lines means the vertical amplifier or deflection system has failed. There are over 100 components in this section and any one of them, or most of them can be at fault. However, the most common failure is the VOT or vertical output transistor (which is often buried inside a chip).
The repair will cost around $150 plus or minus.
FEW TROUBLESHOOTING STEPS YOU CAN TRY:
ONE: Do a hard reset (just to make sure there is nothing in the coding that is fowling things up). Unplug the power cord; leave it disconnected for 4 hours. That will restore everything to factory defaults when you power it back up.
TWO: Do the "whacking test" by banging your fist on a few strategic places to see if there are any cold solder joints or loose wires acting up inside the set.
If the above steps don't solve ur problem then I suggest you to go for a repair if you don't have any knowledge of repairing it.
Goodluck...
Feb 13, 2008 | Samsung HP-R4252 42 in. Plasma HDTV
My 42 in phillips LCD flat seen has a black horizontal line toward the bottom how can I fix this.
Samsung LN46B650 Thin Black Horizontal Lines - Forums - CNET
www.cnet.com > Forums > Samsung
CNETI'm experiencing thin black lines from the top of the screen to the bottom. ... by babes808gpa / January 15, 2010 1:42 AM PST ... lines are about 1/4 inch apart from top to bottom of screen. starts on the right and about a 1/3 of the way toward the ...have the exact same problem, my lcd tv has multiple lines are horizontal it ...
Faulty HD- LCD - LED TV - Horizontal Lines STRIPS on the ...
? 3:05
https://www.youtube.com/watch?v=KiqJuMiEiak
Jun 8, 2013 - Uploaded by Sameh Moustafa
Faulty HD- LCD - LED TV - Horizontal Lines STRIPS on the picture SOLVED .... I just have one black line ...
TV Repair Help for Vertical & Horizontal Lines on Your TV ...
? 2:47
https://www.youtube.com/watch?v=b0sI7LB4cZE
Dec 20, 2015 | Televison & Video
To The Knight: followed your advice, nothing came up for my samsung LN52A650A1FXZA. will keep searching the problem.
Horizontal line problem is usually related with T'Con board itself. In rare cases, with panel too. There is details about this, at one or tow among the posts with the blog I've pointed out to you. I do clearly recall that, I've seen it there. It is a site, has more than 400 indexed pages on Google. a helpful one too. I've pointed out to many others, and most of them did find solutions to their problem there. I do get their responses too; by Fixya.
Just understand, an LCD TV is working mearly by some capacitors, and some users trusted as it is.
Contact any service technician. It will be the best.
Nov 15, 2014 | Samsung LN52A650A LCD TV
Sony bravia KDL 40s4100 vertical lines on left
LOD (lines of death) are a known service issue with the Sony bravia line of TV's contact Sony and cross your fingers. Wish I had better news for you. I had a 52w4100 and Sony arranged me with a service center to get it taken care of.
Aug 18, 2012 | Sony Bravia KDL-40S4100 40 in. LCD TV
While watching tv it just blanked out and would not come back on. there are no lights on in back of tv. I also tried plugging it into another wall socket and nothing happened
that sound like horizontal section got bad. please recheck that horizontal output transistor & all component like capacitor.& resistor. good luck!
Jun 05, 2011 | Sharp 36L-S400 36" TV
Vertical blue lines appeared on the screen with no sound.
All plasma an LCD TV have boards that control vertical and horizontal output to their respective areas. They are connected to the screen by ribbon cables. If one of these boards fails all together, has a failed chip, a bad connection, or a bad ground somewhere it will result in a black line in the area of that board. A bad ribbon cable connection on the bottom will result in a vertical black bar though the screen. Many times resetting the connection will fix it, if the ribbon cable has been nicked there could be a severed connection. They an sometimes be fixed, but it is a pain. An yes I have done it, but the bar is gone. The same will happen if the chip that outputs to that area opens. The connectors are the first place to look paying close attention to the cable, they are extremely delicate so great care must be taken if you decide to tinker with em, the usually have lift locks that release them, but it is very easy to wreck em. Good luck.
Jun 07, 2010 | Vizio P2 42 in. HD-Ready Plasma Television
Picture on RCA TV shrinks to a horizontal line
Sounds to me you have a cold solder joint ( loose solder connection ) on the printer circuit board around or on the vertical chip or on one of the vertical capacitors. You may also have a bad vertical chip or a bad vertical capacitor, but I doubt it since it did come and go. I'de get a soldering iron and some solder and touch up the connections. I will remind you that you need to always excersise saftey by making sure, before removing the back, unplug the TV from the wall, and use care not to come in contact with the large red wire going to the back of the picture tube as the picture tube can be turned off and still store lots of voltage ( up to 35,000 volts). Always stay safe and when soldering, use care not to run solder across places that will make a short.
Good Luck and I hope this helps
Ed Meshechek ( Radio Man )
NC Electronics
Mills, Wyoming
307-266-4675
Dec 19, 2008 | Televison & Video
Tv shows a white horizontal line and then shuts off
for sure the tube is bad be better off buying a new tv or find someone that has a tv repair shop
Oct 07, 2008 | Sony FD Trinitron WEGA KV-24FS120 24" TV
Horizontal lines on lower portion of screen
Your problem is a bad matrix drive circuit or a drive connection cable. There are no user replaceable parts inside this set, so Im sorry to say, you are going to need to call in a trained plasma repair person. good luck!
Oct 08, 2006 | BenQ PDP-46W1 46 in. HD-Ready Plasma...
Samsung LN52A650A LCD TV Logo
46 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
