Question about ZEEPAD 7 inch Android 2.2 Tablet
What can i do to get back back all my apps and drivers and OS back every thing has been deleted from my tab very time i try to reboot it to factory settings it remain on the starting mode
My acer tablet screen froze after I accidentally deleted apps that I don't need. How can I fix other than buying a new tablet
First, try rebooting. If that doesn't fix it you may consider restoring the device to the original factory settings. A word of warning...restoring to factory settings will take the tablet back to the way it was when originally purchased. All passwords, updates, music, photos, videos, audio recordings, apps and so on added after it was purchased will be deleted. So don't do this if you are concerned about losing the aforementioned data and files. To do a factory reset go to settings and look for a restore option. It may be under something like system restore, device settings, back up and restore or something similar. Once you find it, it should warn you that your device will be restored to factory settings and that all post factory apps, passwords, data and files will be deleted. If you still want to restore your device follow the instructions. You will then have to set everything up from scratch as if it was just purchased. I did this with a Kindle Fire. After the factory restore I reinstalled my apps, added all my accounts (email and so on), downloaded all my books, music, etcetera, and it has worked great since.
Jun 18, 2017 | Acer Tablets & eReaders
How do I reset this tablet
Since model number you wrote is for kickstand I assume that you want to reset Galaxy tab 3
Please make sure you have backed up all of your important data and apps before performing a reset.
Turn your Galaxy Tab 3 off.
Press and hold the Volume Up, Power and Home buttons together until you see an Android lying on its back. This is the - stock recovery screen.
Use the volume keys to scroll down to Wipe Data/Factory Reset and use the Power button to confirm.
Scroll down to Yes, Delete All User Data and hit Power to confirm.
Back on the first screen, scroll down to Wipe Cache Partition and select with power button.
Hit Reboot System Now to restart your Galaxy Tab 3 with factory settings restored.
Oct 15, 2016 | Tablets & eReaders
How do I delete history on my Galaxy Tab 3?
history, like browser history? if so, go to whichever app you use to browse, like, chrome or firefox, go to the settings for that app and there should be an area for history. from there you can delete it.
if its for another app, just start the app and try the same thing.
Aug 17, 2016 | Samsung Galaxy Tab Tablet PC
Recover facebook app
Delete the app, reboot and then redownload. Log on with your email address that is associated with your Facebook account and the Facebook password. All your Facebook data is saved on the Facebook server so everything will come back.
Jan 30, 2016 | Samsung Galaxy Tab Tablet PC
Had to do factory reset, now unable to download apps from google playstore like youtube etc, any help?
I suggest that you troubleshoot first, instead of a hard reset. Factory reset is within settings.
If any google app won't download nor install, it's probably because your google services are not updated or is corrupted. Try the next steps before factory reset.
1. Go to settings, scroll down to app.
2. From here search for PlayStore and tap it.
3. Tap Clear Cache and Clear data.
4. Go Back.
5. Search now for Google services, this one is not under the download tab, which you can notice at the top of the screen, instead got to All and scroll down until you find it.
6. Tap Clear Cache and Clear data if available.
7. Reboot phone or tablet.
Most of the time this procedure do work, some people also opt to remove the google account and sign in after the reboot.
After the boot, open the PlayStore, accept the agreement and try to download anything from the PlayStore that is compatible with your tablet. Also, just to be sure, go to settings, security, look for Unknown Sources and enable it. This feature allow you to install any apk file that is not from the PlayStore.
Mar 07, 2015 | Tablets & eReaders
Freeze up
reboot it 2-3 times or open up task manager by pressing
alt+ctrl+delete simultaneously and look for back ground apps
Apr 05, 2014 | Microsoft Surface RT
Keeps freezing
shut down running apps in background
Mar 25, 2014 | Digix TAB-840 Android 4.1 OS Tablet PC
Samsung tab 2.0 keeps rebooting
I had same problem with note 2, full backup and factory reset problem solved.
Mar 22, 2014 | Samsung Galaxy Tab Tablet PC
ZEEPAD 7 inch Android 2.2 Tablet Logo
42 people viewed this question
Top ZEEPAD Tablets & eReaders Experts
Frank Russell
Frank Russell
Da Doc
tony wahlman
tony wahlman
Are you a ZEEPAD Tablet and eReader Expert? Answer questions, earn points and help others
