Question about Garden
Need to find correct spark plug for Troy-Bilt #42027 Snow Thrower.
  • 776 Answers
Several engines were available, you need to look for the number on your current plug - easiest method.
otherwise, you will need to give the motor manufacturer and nameplate info (Tecumseh SnowKing 8HP?)
Posted on Nov 16, 2014
Where is spark plug located on Squall 2100, 4 cycle,208cc ohv?
You will have to drop the back panel. See picture also add a link to your manual.
Troy Bilt Snow Thrower 31AS2T5F711
Feb 15, 2016 | Troy-Bilt Squall 2100 208 cc 21-in...
I just replaced the auger belt and the auger cable has no tension. What do I do to fix it?
Here's some silly questions: Did you put the belt on the correct side of the Tensioner?
Is it the correct sized belt?
Is there a spring on the cable for the auger that can be lifted up the cable to expose the adjustment nut ?
Feb 08, 2016 | Troy-Bilt Troy Bilt Storm 3090XP Snow...
Troy bilt repair manual
Check with the engine manufacturer if you have trouble with Troy built.
Aug 03, 2014 | Troy-Bilt 179cc 24" Snow Thrower Storm...
Remove rim from Troy bilt snowblower?
Excellent. Put some grease on the axle before you put it back together so it comes apart next time.
Aug 02, 2014 | Troy-Bilt 179cc 24" Snow Thrower Storm...
Augur wont turn on troy bilt model 2410 snowblower,stall s out when i engage the augur
ICE OR HARD PACKED SNOW IN BLOWER HOUSING
warm up or pour hot water down chute to thaw out
Feb 13, 2014 | Troy-Bilt 179cc 24" Snow Thrower Storm...
Runs for 10 minutes then stops
clean the carb may have some water in there
shut off gas remove bolt in bottom of the carb
check for any foreign materials. (water,rust ,gelled up gas)
spray with carb cleaner put back together
change spark plug
Feb 01, 2014 | Troy-Bilt 179cc 24" Snow Thrower Storm...
Tires for troy built snow thrower storm 8526. One of my tires went flat. IS there an inner tube I can purchase or do I need to purchase a new tire assembly?
Take your tire to your local tire shop they can install a tube for you i would recomend doing both tires i had this done on my MTD snow thrower
Oct 28, 2011 | Troy Bilt 5.5hp Self Propelled Mower
I have a Troy bilt snow thrower 2 stage-storm 2410. Bought it new last year, used it twice. It won"t start even after adding new gas and changing the spark plug. It doesn"t start, engine...
You need to remove the carburetor float bowl and clean it. The needle and seat also need to be cleaned. The best thing is to totaly remove the carb. and soak it in a commercial/professional strength cleaner.
Your problem is fuel related, but just to make sure, remove the spark plug and spray some carburetor cleaner in the hole, replace the plug and give it a pull. If it fires up then quits..... The fuel system is to blame.
Hope this helps, Matt
If you need further help, I’m available over the phone at https://www.6ya.com/expert/matt_8dbc24bf722649ac
Dec 10, 2010 | Troy Bilt 175HP Manual 42" Riding Mower
Garden Logo
85 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
