Question about Samsung VP-D361 Mini DV Digital Camcorder
Can i subatute a 7.5 300ma charger for a 7.4 .5a charger
Lost charger want to subatute 7.4 .5a charger with 7.5 300ma charger will it work or damage camcorder
  • 63 Answers
This is 300mA vs 500mA .The voltage increase is insignificant
But it is 40% less current.
If the plug polarity is the same;
TRY IT that a YES it might work.
Posted on Nov 16, 2014
Where is fuse for 1997 mercury wagon for windshield wipers
1997 mercury wagon ? Sable ? VISUAL INSPECTION CHART-WINDSHIELD WIPER AND WASHER SYSTEMS Mechanical Electrical
  • Windshield wiper blade missing or damaged.
  • Binding windshield wiper pivot arm.
  • Binding windshield wiper mounting arm and pivot shaft.
  • Empty windshield washer reservoir.
  • Kinked or broken windshield washer hoses.
  • Open fuse junction panel Fuses:
    • 8 (5A)
    • 12 (5A)
    • 20 (5A)
    • 23 (5A)
  • Damaged windshield wiper motor.
  • Damaged windshield washer pump.
  • Open connectors.
  • Corroded connectors.
  • Inoperative multi-function switch.
  • Open thermal breaker internal to the wiper motor
Which are not working , front , back or all ?
I/P Fuse Panel C225
Under left corner of instrument cluster
Feb 05, 2017 | Mercury Cars & Trucks
I need a yes or no answer can i subatute a 7.4 .5a charger with a 7.5 300ma charger
Nov 16, 2014 | Samsung VP-D361 Mini DV Digital Camcorder
What battery for ac input 100-240Vac 330mA
You need two 12 volt batteries in series for your charger to work. If the batteries are both flat then use an automotive 12 battery charger to recharge them individually. It may take several days to get them back up enough for the 24 volt battery charher to start working again.
Jul 29, 2014 | Pride Health & Beauty
Where can i get a schematic drawing for a TE 5A battery charger
There are no schematics for the 5A charger. Those were not serviced by Hilti. If they were bad then they just replaced the whole unit. If your charger has no power at all there is a fuse inside that you can replace. Other than the cord that is about it. I think you can still get a charger from Hilti. 1-800-879-8000
Nov 22, 2011 | Hilti Drills
I have a HP8204B Pride battery charger 24vdc 5a 230vac, the wire to the end connector (3 pin with 2 of the pins bridged) has come away and i don't know which wire (one black, one red) to solder to which...
The red wire is positive and is soldered to pin 1. You can see the 1 on the pin (non solder side) of the plug housing or on the solder side as a raised stamp 1.
The black wire is soldered to the negative pin 2. Two of the pins are bridged to inhibit the power chair operation when the charger is plugged in. Hope this helps.
Mar 16, 2011 | Health & Beauty
I damaged the charger cord. I bought a
The traffic receiver in some models is built into the charger itself. If you bought another charger that is not identical, it may not have the traffic receiver.
- Jim
SHARCNET-USA
Nov 24, 2009 | Garmin Nuvi 265W GPS Receiver
Lost telewest codes for eurovox
New Code For TW and Virgin Please CHECK PROpely and Try ,,,Good Luck
5A 01
00/83 5d 12 b8 96 f6 1f c4
01/D2 F9 3F 22 0C A7 D6 C9
Aug 30, 2009 | Televison & Video
My 2003 Lincoln ls horn doesn't work
it may be your clock spring. if your fuses aren't blown try the clock spring. you can get the directions online and buy the part from the dealership. it takes maybe thirty minutes but saves you lots of money. another easy way to tell if it is the clock spring.....does your cruise control work? if not the clock spring is bad.
Aug 13, 2009 | 2002 Lincoln LS
Lincoln LS 2001 3.0
Fuse/Relay
Location
Fuse Amp
Rating
Passenger Compartment
Fuse Panel Description
9 10A Right Front Low Beam
10 5A Left Front Turn, Left Front Repeater, Left
Front Sidemarker, Left Front Park Lamps
11 10A Left Front High Beam
12 — Not Used
13 5A Cluster
14 10A RCM, DATC
15 5A Not Used (Spare)
16 5A E/C Mirror, Heated Seat Controls, RSM
(Rain Sensor Module)
17 5A RCM, Alternator Warning Lamp
18 20A Radio, CIA
19 15A Tilt/Tele Motors
20 10A FEM, DATC, Cluster, Brake Shift Interlock,
REM
21 10A Power Folding Mirrors
22 10A DDM
23 10A Right Front High Beam
24 5A PATS
25 10A Left Front Low Beam
26 10A Wiper Relay, Windshield Washer
27 10A Radio, Cellphone
28 5A Security Horn
29 5A Trailer Tow Ignition Sense, VEMS, FEM
30 5A FEM
31 — Not Used
32 20A Cigar Lighter
33 10A Switch Backlighting
34 10A Not Used (Spare)
35 5A Stop Lamp Signal
Oct 23, 2008 | 2001 Lincoln LS
Polaroid FLM-2011 LCD
look at the back of your lcd it usually will state the voltage and power requirements of the required replacement adapter...never exceed the voltage requirements this may cause damage DO NOT USE THE 16V ADAPTER!
The adapter you require appears to be rated at 12V x 5A a 60Watt unit you can replace most likely with similar switch mode unit rated at 12V and at least 5A or more
Aug 25, 2008 | Polaroid FLM-2011 Television
Samsung VP-D361 Mini DV Digital Camcorder Logo
62 people viewed this question
Top Samsung Video Cameras Experts
Tony
Lawrence Oravetz
Are you a Samsung Video Camera Expert? Answer questions, earn points and help others
