Question about Dryers
We have put a new belt and bearing on my 4kg Simpson eziloader dryer and spring is in place it works for a while and then the belt comes off again what could the problem be
  • 599 Answers
I would check the pulley on the motor, and the belt tensioner that the belt winds through. My initial thought is that when installing the belt onto the tensioner it may have been bent. GOOD LUCK FRIEND.
Posted on Nov 16, 2014
SOURCE: Dryer won't start, Simpson Eziloader 4kg
On dryers with the old mechanical timers you can turn the knob in either direction without harming the mechanism. On either type, even electronically controlled models with a problem like you described, there are a lot of possibilities. After confirming you have power to the appliance check the thermal safety fuse located on the heater housing.
Posted on Jan 25, 2008
dmftrucker
  • 1922 Answers
SOURCE: dryer will not spin
are you sure the drum belt isn't broken,the whirring noise your hearing sounds to me like the motor is turning
Posted on Jul 30, 2009
  • 93 Answers
SOURCE: how to turn on the simpson eziloader dryer
The timer is the "on" switch.
Things that can stop it starting.
Door switch- is the depresser pin contacting.
Broken main belt.
Faulty - motor- timer- door switch- belt switch ( if fitted) wireing.
Posted on Aug 29, 2009
SOURCE: I have a simpson eziloader dryer modal 39S500 the
Hi I have a simpson eziloader 5kg Model: 39S500. I've just replaced the drum and put it all together but I have a spring that I'm not sure where abouts it goes can anyone help thank u
Posted on Jul 02, 2010
txinspector
  • 359 Answers
SOURCE: Hi I have a Simpson 4kg eziloader dryer that keeps
The heating element uses the most power. Was the home wired by a licensed election ( the dryer plug)? if it was it should have #8 or #10 wire depending on the load. the breaker is sized to the wire (so don't change it). you may have a clogged vent pipe. this will reduce air flow and make the dryer work harder possibly tripping the breaker. You should probably start by making sure you vent is clear and free from debris, debris in the vent could cause a fire.
Posted on Sep 10, 2014
Hi I have a Simpson 4kg eziloader dryer that keeps tripping the power mains . Would this be the timer ?
Sep 10, 2014 | Dryers
Simpson 4kg eziloader dryer wont turn on can hear faint noise when i switch it on though
If the faint noise is the motor running, the belt is broken.
Jan 03, 2014 | Dryers
Where does the spring belt tension go on my simpson ezi loader dryer??? I was replacing the drum belt and it flicked off and I didnt see from where. A picture would be good.
the motor is spring loaded - move lift motor towrards the cabinet lining to the right. Put band around drum and pully at rear of motor then allow motor to move back onto band to cause the tension
Feb 17, 2011 | Dryers
I have a simpson eziloader dryer modal 39S500 the belt broke. i need a diagram on how to replace it. I also have to replace the bearing.
Mar 15, 2010 | Dryers
How to turn on the simpson eziloader dryer
Broken main belt.
Aug 29, 2009 | Dryers
Dryer will not spin
Jul 30, 2009 | Whirlpool GEW9250 Electric Dryer
Yes, the knobs don't like to be turned counterclockwise. Spin the knob clockwise to reinstall tightly, then move to set a dry time. Make sure half load button is pressed.
Jan 24, 2008 | Whirlpool GEW9250 Electric Dryer
Dryers Logo
207 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
