Question about Sharp Aquos Televison & Video
MY SHARP AQUOS 70" TV HAS STARTED TO HAVE A DARK SHADOW ACROSS 1/2 OF THE SCREEN WHILE THE OTHER 1/2 IS PERFECT. DO I HAVE A HDMI INPUT ISSUE OR IS THE TV BROKEN?
    Top Expert:
  • Sharp Master
  • 75,304 Answers
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
Posted on Nov 16, 2014
  • 103 Answers
SOURCE: Sharp Aquos LC-32D41U
The unit has bad drive ic's,which is part of the lcd panel.It is not cheap to fix.
Posted on Mar 05, 2008
  • 53 Answers
SOURCE: My Sharp Aquos 46" LCD
Digital inputs on Aquos TV's are "always on," usually the HDMI inputs and DVI inputs. As opposed to analog inputs 1, 2, or 3, are only activated once something is plugged in.
Try plugging in another HDMI sources into input4 or 5, if its still not working, the TV needs a new Main Board. Try calling Sharp 1-800-237-4277 and locating a local service center in your area.
Posted on Mar 14, 2008
swami nathan
  • 208 Answers
SOURCE: Sharp Aquos LC-37P50E connected to computer with HDMI cable
I got the chat , but some how it got disconnected.
But i would like to help you in this aspect.
HDMI stands for High Definition Multimedia Interface, and supports transmission of both audio and video in high fidelity.
First make sure these things,
Both your computer and your TV will need to support HDMI interface.
It's quite a recent thing in PC graphics cards, so you may have to resort to S-Video, DVI or VGA for the video, plus a 3.5mm stereo cable (or the optical TOSLINK equivalent) for the sound.
Let know your comments and i will follow up with the suggestions.
Thanx for using fixya,
Good luck.
Posted on Sep 28, 2008
  • 10 Answers
SOURCE: Sharp Aquos 37" Audio Static Issue when watching DVDs
i have had to replace the hdmi input board on these units to fix them.
Posted on Jan 08, 2009
SOURCE: trying to connect a sharp aquos lcc3234u tv to pc using hdmi
it sounds like your computer isnt set up to send the signal out. try right clicking on your desktop and selecting a dual monitor setting. It should be found under graphics options or something similar.
Posted on Jun 27, 2009
When tv is turned on you get poicture and sound but there are broken horizontal lines from top to bottom of screen. this occurs on all hdmi inputsincluding roku and dvd player.
How to fix lcd lines on Sharp tv screen, hdmi video board ...
? 3:43
https://www.youtube.com/watch?v=cHki4D0EwOo
May 24, 2014 - Uploaded by Tampatec
How to fix LCD lines on Sharp TV screen, hdmi video board easy ... Make Money From Your Broken Cracked LCD LED PLASMATV ... TV Repair Help for Vertical & Horizontal Lines on Your TV Screen ... Sharp Aquos LC-32 37 46 52DH65E 66E 77E - NoPic/Sound with ... Get video URL at current time.
comments on LCD Display Symptoms and causes. - YouTube
https://www.youtube.com/all_comments?v=DedJvyNm_s4
We have frequent outages causing the TV to turn on from standby mode when power returns. (These ..... Sharp LC-70LE650U 70-Inch Aquos TV TURNS ON WITH PERFECT PICTURE AND ..... It has thin horizontal lines on the top quarter of thescreen. ..... hey there, bought a 52lg60-ua had no image/picture but had sound.
? 2:01
https://www.youtube.com/watch?v=DedJvyNm_s4
Jan 28, 2016 | Sharp aquos 52 in lcd 1080p aquos 52...
MY SHARP AQUOS 70" tv STARTED HAVING DARK SHADOWS ACROS 1/2 OF THE SCREEN, THE OTHER HALF OF THE SCREEN IS FINE. DO I HAVE A hdmi INPUT PROBLEM OR IS THERE A TV DEFECT?
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
Nov 15, 2014 | Sharp Aquos Televison & Video
Sharp aquos tv no sound hdmi
What are you connecting to that HDMI input? Some devices do not put the audio on the HDMI cable. For instance: If your laptop has a HDMI out and you connect it to a HDMI input on the TV, you'll get a perfect picture without sound
Jan 02, 2014 | Televison & Video
I have a Sharp Aquos LCD TV Model LC-32BX6M , when I try to connect a new generation Android TV Box HDMI Out to TV's HDMI input the Android Logo appears and after sometime the screen goes blank t
im not sure but could it be a comparability issue with the device and the wake up signal from the device to the tv? android systems use a Linux based file system, so the problem may be in the tv's input settings. hdmi input from the device to the tv. and then go to tv input mode and see if putting the device in another hdmi port doesn't work.
Oct 15, 2012 | Sharp Aquos Televison & Video
Trying to hook my roku box to my sharp aquos 46 in using my hdmi
according to roku support hdmi won't work with the aquos as of today (1/6/2010). i have no idea if it's an hdcp issue or not
Sep 10, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Jan 08, 2009 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
Sharp aquos 42"
Check the settings in the TV set for HDMI sound on the input of the TV that you are using. Try another HDMI cable. It may be defective.
It is also possible that there is a compatiblity problem for the HDMI sound between the TV and the computer's sound protocol.
Jerry G.
Apr 27, 2008 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Mar 14, 2008 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Sharp Aquos
Shine a bright light on the screen, do you see the image (but very very very dark)? If so, its either a bad inverter or lamps, which are only sold with the LCD panel as an assembly, which is very expensive (more than the TV is worth).
Mar 09, 2008 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
Televison & Video Logo
157 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
