Question about Microwave Ovens
For GE Oven PLT059-2 How do you access the surface lights for replacing bulbs? What is bulb #?
5 Suggested Answers
jonniewalker
  • 1031 Answers
SOURCE: Replacing interior light bulb for ge spacemaker xl1800
Always unplug a microwave before removing or installing any bulbs.
If it's an over the range type, remove the vent grille across the top to check if you can access the bulb fromthere. There may be a panel on the bottom covering the light(s), instead.
you may have to remove it from the wall, then remove the outer cover. If so, the installation instructions are very handy,
Once it's out of the wall, the outer cover (wrapper) will need to be removed, just as you'll need to do on a counter top model.
On a counter top model, be sure it's unplugged, but otherwise ignore the instructions above this paragraph.
The screws you need to remove should be pretty obvious, but a special driver (such as a T20H Torx type or GTXH20-100) may be needed.
Be sure to put all the screws back in the right holes, since some may be special grounding screws.
Bulbs can be had in most grocery stores, hardware stores, home improvement centers, and big box or department stores.
Many models use halogen lamps. You must not touch the new one with your bare skin, as the oils will shorten the bulb life.
hope this helps dont forget to rate this
Posted on Sep 21, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: ge microwave oven jes1288 light bulb replacement
The light bulb assembly (bulb and socket are all one piece) is part number
WB36X951.
It is located on the air duct assembly where the door switches are mounted.
You can see an exploded view diagram here.
You'll need to remove the outer cover (wrapper) to get to the bulb assembly.
See these links before proceeding:
http://www.microwavedisplay.com/safety.txt
http://www.microwavedisplay.com/disassembly.txt
The screws you need to remove should be pretty obvious, but a special driver (such as a T20H type or GTXH20-100) may be needed.
If you're not able to find the bulb assembly at your local appliance parts store, you can order one here.
Posted on Jan 24, 2009
SOURCE: bulb replacement
NO,If you can get to the three phillips screws directly over the vent door then you do not have to take the unit down. Unplug the unit. Remove the top three screws over the center of the louvre and then carefully lower the vent louvre. (Lowering helps me get a better grip on the louvre assembly. Then you will slide the vent louvre assembly about 1/8" to the left and then it will pull straight back and out. In the center is an aluminum cover which has a phillips screw facing you. Remove this screw and the cover plate. The light bulb is directly to the left of the inside of the cover plate. You will see the metal tabs which hold it in place. Pull the bulb housing assembly straight out (to your right) as you face the microwave. Then you will locate your halogen 120V 20W bulb. I just received this from a fellow guest on fix it and I was able to fix my unit 10 mintes ago.Also another tip was to take the inside glass out when reinserting the bulb unit back in because it does get in the way. Good Luck
Posted on Jun 08, 2009
  • 149 Answers
SOURCE: How to replace the bulb in our GE Microwave Oven,
the outter cover wrapes around unit remove screws, be careful high voltage is present even with power off just replace bulb reassemble
Posted on Jan 14, 2010
GE double Oven range PLT059-2 How do you access surface light bulb to change it?
There should a sliding panel of glass or plastic covering the light. Remove the glass or plastic then you should see the light bulb. If the light buld is a regular old bulb unscrew it if its a small floorisent bulb twist it so it will roll out of its sitting position. Then you can take the bulb to any hardware store to match the bulb. DO NOT PAY FOR SOME ONE TO CHANGE A LIGHT BULB....Please if this helped you post that I helped you with the correct answer so i may get credit....
Nov 17, 2014 | Microwave Ovens
Changed the light bulbs in my ge jvm315 and know the surface light will not turn off ?
This sounds like the control board also called a smart board in some models has to be replaced.
May 02, 2014 | GE Spacemaker JVM1640SJ Microwave Oven
Over the range Danby Model dom16a1wdb surface light replacement
a screw at the back side when removed get access to the bulb.Usually 40Watts bulb with1/2 " threaded
Mar 28, 2014 | GE JVM1790SK Convection/Microwave Oven
Replacing light bulbs?
Replace the burned-out bulb with a 120 volt, 30-watt incandescent bulb (WB36X10198), available from your GE supplier
  • 1 To replace the oven light,
first disconnect the power at the main fuse or circuit breaker panel or pull the plug.
  • 2 Remove the top grille by
taking out the 2 screws that hold it in place.
  • 3 Remove the charcoal
filter (if present) to access the light cover (see Remove Charcoal Filter section).
  • 4 Remove the light cover
located near the center of the oven that holds the bulb. Remove the bulb by gently turning. Replace with the same size and type bulb.
  • 5 Replace the light cover
and charcoal filter (if present).
  • 6 Replace the grille and
screws. Connect electrical power to the oven.
The full owners manual can be found here: http://products.geappliances.com/MarketingObjectRetrieval/Dispatcher?RequestType=PDF&Name=49-40474.pdf
Mar 07, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Replacing surface light
That's on page 33 of the owner's manual. If you've misplaced yours, it's archived online here.
Cooktop Light/
Night Light
bulb with a 40-watt
incandescent bulb
(WB36X10003), available
from your GE supplier.
1 To replace the bulb(s),
plug.
2 Remove the screw from
light cover and lower
the cover.
3 Be sure the bulb(s) to be
replaced are cool before
removing. After breaking
the adhesive seal, remove
4 Replace the screw.
to the oven.
Oven Light
bulb with a 40-watt
incandescent bulb
plug.
3 Next, remove the screw
located above the door
oven that secures the
light housing.
to the oven.
May 30, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
One surface light bulb on GE Profile microwave keeps burning out
I have the same problem. The left one burns out within a couple of hours use, the other one lasts a couple of months and is then gone. This pattern has repeated over 8 years. I replace them every now and then and then just go without until I get the urge again to fix it. Maybe smaller lower wattage lamps are worth trying...
Jun 06, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Surface and night light bulbs
If the model number you have this listed under is correct, the bulb you need is part #AP2029997, made by GE. You can also purchase these bulbs at any hardware store. They are the half sized small base, 40 watt bulbs. If you can't find 40 watt, make sure you use a lower wattage rating. If you have questions, or if the model number is incorrect, please let me know. I hope this helps you.
May 04, 2009 | GE JVM1650 1000 Watts Microwave Oven
Surface Light Bulbs GE XL1800
Dont waste time blaming the wife. It does not pay. LOL
Call GE customer care. Give them the model and they can 1. Tell you what bulbs to use, 2. Ship you the bulbs or, 3. Send you another owners manual which I hope you will keep in a safe place.
Ray
Nov 18, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
GE Microwave Surface Lights
The control circuits for the cooktop lights and the hood fan are spearate. The problem is indeed with the control unit. It's usually caused by either the filaments shorting when the lamp blows or by removing or installing the bulbs while the oven is still plugged into the power line. We regularly repair these nationwide for $32.50. Details of our service, as well as *critical* safety and disassembly info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
Feb 21, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave Ovens Logo
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
