Question about Drills
How do I take apart a makita6011d cordless drill
  • 74 Answers
Here is a site with a break down and the parts list Makita 6011D Cordless Drill Parts
Have a Good Day
Posted on Nov 25, 2014
I have a cordless drill model 6095D. The torque function is always on torque, won't put in screw. I don't need the torque function at all, just straight screw driving, but need to fix some way.
50% of issues like this one are solved by cleaning the mechanism, you have quite old drill so it's a big chance a metal chip went somewhere between the gears, take the drill apart and clean the mechanism first, if this is not the issue you may figure out by taking the drill apart which you need to do in any case. Or take the risk and use brute force. drillselect com
Nov 12, 2016 | Drills
Ryobi 18v drill stuck chuck
easy to fix
with the drill not running
grab the bottom part of the spinning part of the drill nearest the drill's motor.
then
grab the spinning shaft bit nearest the drill bit
pull them apart slightly
when the two parts are pushed together thay lock the chuck
I own a ryobi hammer drill that does the same thing
Mar 13, 2015 | Ryobi 18v Cordless Drill - P206 18 Volt V
I inherited a Makita 6071D cordless drill w new home; ordered a battery since it did not have one, but drill does not work. Tried another battery known to be good at Batteries+ store and the problem is the...
Here is a part breakdown. Chances are the switch assembly #14 or if you get to the brushes, they sometimes go bad. If you don't want to try to fix it yourself, these people know where to send it. It really is pretty easy to fix. https://www.ereplacementparts.com/makita-6071d-cordless-drill-parts-c-97_106_107_268.html
Oct 31, 2017 | Makita Drills
I have two 18v DeWalt cordless drills that I have USED A LOT -- can I replace the motor pack?
If your mechanical/electrical knowledge is up to par, then yes. I'm not sure what the cost would be..but I've taken apart a few drills and replaced brushes, lubed bearings, etc.. They are fairly simple..although I know those XRPs are tanks..you must have put it through some insane force to break it. You may want to check with the warranty on them though...my friend has gotten a few, free, replacements though the depot.
Sep 26, 2010 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
I have a makita cordless drill 18 volt,after I release the trigger it keeps running..
dirt in the trigger most likely. you will have to take it apart and clean it. Some hardware stores may service it for you.
Jan 07, 2010 | Makita 12 Volt Cordless Drill/Driver Kit
How can I disassemble a Dewalt keyless cordless drill chuck? I mean take it apart, not just remove it.
depending on the chuck it would take special fixtures to press apart, and unless you are very good with tools you would damage it beyond repair. I have never taken a keyless apart and tried to repair and put together, I have on the other hand done the same with the keyed chucks.
Dec 13, 2009 | Dewalt Drills
How do i release a drill bit
This particular drill/driver has a keyless locking chuck. Apart from suggesting you read the manual, you grip the black plastic part of the chuck and turn it anti clockwise (when it's facing you)
Oct 03, 2009 | Black & Decker 14.4v Cordless Lithium...
Transmission fell apart. Looking for blueprint to reassemble.
The transmissions come as an assembled unit and there are no drawings for the internals. If you can find an old drill that is no good, use it as a guide.
Hope this helps
Apr 13, 2009 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
Makita 18volt 6347 cordless drill
then you need transmision assy. item 14 in breakdown
see toolpartsdirect.com for further info on your drill
Mar 28, 2008 | Makita 18V LXT Lithium - Ion Cordless...
Drills Logo
152 people viewed this question
Top Drills Experts
Are you a Drill Expert? Answer questions, earn points and help others
