Question about Dyson Flowcheck CRO1 Front Load Washer
My Dyson washing machine goes through a full wash cycle, but will not spin, any ideas anyone?
  • Official Brand Answer
  • 2,572 Answers
Hi Tina, it's Jack at Dyson.
I'm sorry to hear you're having difficulty with your Dyson washing machine not spinning as normal. Unfortunately, since December 2012 we have been unable to offer servicing or support for CR01 or CR02 washing machines. In October 2012 we proactively contacted all Dyson washing machine owners we'd interacted with within the last 4 years to make them aware of this.
I'm sorry that I'm not able to help further in this particular instance, but if you'd like to discuss this with our experts you're welcome to call us on 0800 298 0298. We're available from 8am-8pm from Monday to Friday, and 8am-6pm on weekends. Calls are free from UK landlines.
Posted on Nov 17, 2014
barkencoa
  • 3463 Answers
SOURCE: Hi I have a Dyson CR01 washing machine and have it
Sounds like it could be a control board problem.
The web address is;;;;;
WWW.dyson.co.uk.
Hope this helps
Posted on Dec 19, 2009
Dysonteam
  • 167 Answers
SOURCE: Hi my dyson washing machine comes on for 30 secs than turns off
Hi its Darran at Dyson.
I would recommend switching the machine off and contacting our Helpline on 0800 298 0298.
Kind regards
Darran
Dyson Customer Service
Posted on Apr 19, 2010
Dysonteam
  • 167 Answers
SOURCE: dyson washing machine fault
Hi its Darran at Dyson. If you paid for a repair then there is a 12 month guarantee on any work that was carried out. To arrange a visit, please contact our Helpline on 0800 298 0298, between the hours of 7am - 10pm, 7 days a week.
Kind regards
Darran
Posted on May 24, 2010
  • 27 Answers
SOURCE: dyson washing machine seems to have no power tryed
disconnect the power first then remove top cover using a digital test meter carefully check the on/off switch for continuity using the ohms setting if you do not have a digital meter a test light will work fine too my machine had this fault and the power switch was open circuit on the live side of the switch fitted a replacement machine working fine in about ten minutes
Posted on Dec 19, 2010
e-Guru
  • 3917 Answers
SOURCE: My Dyson Contrarotator CRO1 is
Hi
F15 means the gear plate switch is faulty or the gear plates are sticking or worn out.This code means a mechanical or electrical fault possibly the servo motor for the contra rotator .This is situated behind the back panel at the bottom of the drum .It drives a gear which "changes gear" if this is faulty it cannot engage.
Switch the machine off with the 'Mains On/Off' button, then press first the 'Temperature' button whilst switching the machine back on, then the 'Soil type' button within 6 seconds, one at a time, not both together. If you are not quick enough you will have to switch off and start again. a diagnostic screen should then come up telling you a code number for the fault. now you can switch the machine off, then on again, and it should have now re-set an be working (unless the fault is a serious one).
Also the fault codes F15 F13 F3 F4 cannot be freed up by pressing the buttons stated, all this does is let you into diagnostic mode, allowing you to run through the chosen wash cycle. the numbers shown after the buttons have been pressed are IE: 670F13F15F4131, the first 3 num are the amount of wash cycle, the second set`s are recorded faults the last 3 num are the soft-wear up grades, when in diagnostic mode and running cotton @ 40% stains, press the start button the screen will display main wash 8, now press the soil button and number will change up and the machine will move to the next stage of the wash cont up to 13 then jump to 15 and so on, the only way to clear fault codes is to turn off then on, if the code stay`s on you will have no choice and will have to fix it your-self or get dyson, F15 is the ramps and servo unit at the back which engage contra rotation the servo spins round a nylon ring to engage and disengage also the same ring pushes micro switches to let the machine know if it has engaged or not, the fault will probably be the servo been slow or lazy.
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Posted on Apr 20, 2011
Kenmore Series 70 Top Load Washer Direct Drive Model # 110.20722991 Serial# CL 1134809 Wet Clothes after Spin Cycle
many machine spin a full tub as they are pumping the water out
this helps to even out the washing load and reduce the unbalance situation
when the water is removed , the machine progresses the program to a high speed spin
call a technician as there may be a problem in the program board
Jun 11, 2016 | Kenmore Washing Machines
Fisher & Paykel Washing Machine WL80T65CW1 Aquasmart - Machine keeps saying it is unbalanced.
this model is prone for the suspension rods to weaken and cause fault,fit new set of suspension rods
Nov 10, 2017 | Washing Machines
Does not empty at end of wash cycle (not blocked or pump)
faulty program board not progressing
call a technician
Jan 01, 2018 | Hotpoint WMA46 Front Load Washer
It seems like our washing cycle goes all the way through to drain/spin without fulling draining or spinning - we have fabric softener left in the dispenser and the clothes are - particularly at the bottom...
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Jun 27, 2011 | General Electric WJRR4170GWW Top Load...
Spin Led stays on and beeper beeps
this spin light that is on is a fault code no:1 which means the electronic motor control has a memory problem solution replace motor control module ... hope this helps..:0)
May 24, 2010 | Fisher and Paykel GWL11 Top Load Washer
Washing machine wont drain keeps bleeping ERR2
It will not spin with water in.
See if you can locate a filter, and clean same.
Jan 19, 2010 | Haier Washing Machines
Bosch classixx 1000 washing machine - stops on spin
Washing machine stops at the spin cycle - light flashes. Have to drain water out manually. Happened last week and was then able to run an empty rinse cycle. Machine worked normally for another week. Same problem today but have had to drain water manually from the drum after trying an empty 90 wash and rinse cycle (both stopped on the Spin and flashed). Any ideas? Thanks. x
Apr 29, 2008 | Bosch Classixx WVF 240S Front Load Washer...
Maytag Washing Machine Stops after wash cycle...
sounds as if you have abad contact in the timer
advance the timer to a different spin cycle and see if it spins
then bo back to where it stops
if it will spin in the other spin cycles but not where it stops the the timer will need to be changed
Apr 21, 2008 | Maytag Dependable Clean Top Load Washer,...
LG WD-8013F wont spin
Hi deppgirl,
I checked the lint filter at the front bottom left hand side and it was full of junk.  Once emptied it worked a treat.  Pull the flap down and turn the large knob anti-clockwise and pull to remove.  Good luck.
Mar 29, 2008 | Washing Machines
Dyson Flowcheck CRO1 Front Load Washer Logo
97 people viewed this question
Top Dyson Washing Machines Experts
Starnley Johnwells
Starnley Johnwells
Gerry Harvey
Gerry Harvey
Are you a Dyson Washing Machine Expert? Answer questions, earn points and help others
