Question about Soleil Commercial Industrial Heater LH-1302
<!-- from fixya rte -->Heater runs will not heat soleil lh1302 - Soleil Commercial Industrial Heater LH-1302
Fan will not shut off what could be the problem?
if its the original model number without an b at the end it is supposed to shut off, if it is the 4604b the added a feature to keep the fan running anytime power was on to keep it from burning up the power strip, this was a temporary fix, i just picked up a new on tonight under warranty and it has a feature that lets the fan run for a while and then shut off, the newest model number is HA24-50m, is is the same heater as original but now only has 5000w and 3000w options on switch, good luck finding a listing but this is the heater northern tools gives you when they replace the 4604. im pretty computer savvy and i can not find any site that is for profusion heaters as a company, here is a number for tech support you can call, 1-866-206-0888
Oct 19, 2016 | ProFusion Heat ProFusion Ceiling-Mount...
What causes it to shut off?
I found nothing... iHeater 1500 Advanced...
(MY fault: strongly suggest the TELEPHONE)
Try
officialiheater.com
http://officialiheater.com/
or follow contact instructions (below)
Please be sure to read and follow all of the service
procedures outlined in this owner's manual. If you have
any questions concerning your iHeater, contact the
iHeater Customer Service Department at 1-800-469-0456
1-800-469-0456
iHeater, LLC.
5789 Park Plaza Court, Indianapolis, IN 46220
www.officialiheater.com
Carnac the Magnificent
Jan 02, 2016 | IHeater 1500 Advanced Infrared Heater...
Fan works but no heat
look to see if the safety fuse is open you can do that by using a continuity test on the heating element.
Feb 12, 2015 | Cadet EnergyPlus 1600 watt 120/240 Volt...
I tried the little buddy heater in my golf cart and as soon as I move the cart the heater goes out what can I do to stop this
This is not going to work in your golf cart. This is propane based heater with a pilot light. It will go out if you drive because of the wind blowing on it. I also believe all Mr. Heaters have a tip hazard turn off. I know the two I have do. If you really want heat in your cart I would recommend an extra battery, an inverter and a porcelain electric heater. Could be made to work very nicely in your cart.
Dec 25, 2014 | Mr Heater Base Camp BaseCamp Little Buddy...
Lava heater won't light
Try using a match, sometimes spark is not hot enough. be carefulle.
Mar 03, 2014 | Lava Heat Italia Patio Heaters
My propane outdoor heater lights and generates heat on low but when i turn control to high the flame and heat do not increase
The troubleshooting manual says low fuel, low fuel and cold weather and kinked supply line. Beyond this I would need to know if something happened to the unit like it fell over or was taken apart. Best, Joe 1_31_2014_3_36_44_pm.png
Jan 26, 2014 | Patio Heaters
My fahrenheat fuh-54b won't stay running long enough to heat
Most likely defective thermostat or heat sensors on the unit
Nov 28, 2013 | Fahrenheat 5,000-Watt Unit Heater FUH54
Are electric patio heaters bad for the environment?
there has been some debate about it, in America they are seen as environmentally friendly, but in the UK they are seen as more carbon intensive
Jan 23, 2013 | Patio Heaters
Soleil Commercial Industrial Heater LH-1302 Logo
400 people viewed this question
Top Soleil Patio Heaters Experts
deton8 von Splosion
Tom Chichester
Lawrence Oravetz
Are you a Soleil Patio Heater Expert? Answer questions, earn points and help others
