Question about Canon PIXMA Office Equipment & Supplies
How do I copy a multi-page document on canon mx410?
I don't know how to copy a multi-page document.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Canon Master
  • 884 Answers
Hi
You need to use the ADF (Automatic document Feeder) for this. The procedure is quite simple but would be very long winded to explain here. I have therefore found the manual for your printer here:
Canon PIXMA MX410
On this page, the first file is the one you want and on clicking Download - the big green button an executable file will be downloaded and stored on your computer. When the download is complete, locate the file and double click on it to install the manual on your desktop. Once installed double click on the icon and the manual will open. In the left hand window is an index. If you click on the + signs you will expand the contents making it much easier to find what you want. If you expand the Basic Guide you can go to the copying section to find out how to use the copier function and use the links on the various pages to go to Loading originals and this will explain how to copy multi-page documents.
Good Luck
Posted on Nov 15, 2014
Canon mx410 how to scan multiple pages into one document
What you need to do is select the file type as .png instead of the default .jpg. A .png file will create one file with multiple pages.
Good Luck
Mark
Aug 31, 2014 | Canon Pixma MX410 All-In-One Printer
Changed cartridge and now won't print a document
Verify the data cable or the PC printer setting,perform the test page,if you make a copy not problem the cartridge change.
Feb 25, 2013 | Canon Pixma MX410 All-In-One Printer
I have a brand new Canon PIXMA MX410 and don't know how to scan into my computer!
You will have a utility on your PC Named "Windows Fax and Scan" this is in my opinion the easiest and most accessible utility to use.
Nov 18, 2012 | Canon Pixma MX410 All-In-One Printer
Canon pixma mx410 document in adf has paper inside
The Alarm light was always on and the screen said "Document in ADF. When I pressed "OK" it would read "Eject the document". ..............................solution, Lift the cover to expose the flat bed scanner glass. Under the cover, there is a long white bar with two white tabs perpendicular to the white bar. One of the tabs was retracted. Pull on the tab until it is fully extended. The alarm turns off and there is no longer the error. Simple solution .....................................THIS WORKS!!!!!!!! thank you
Sep 12, 2012 | Canon Pixma MX410 All-In-One Printer
Scan and email with mx410 cannon printer?
Scanned document is saved with a file name and in a directory such as desktop. Then attache the file name to an email you send to someone.
Jun 30, 2012 | Canon Pixma MX410 All-In-One Printer
Document in ADF
None of these worked for me. Here is my FIX:
Open the part containing the rollers. You can see a white plastic part which stop the documents feeded into the adf. Lower this part and insert a page into the adf just a bit further than where it would have stopped from that white stopper. This forces the machine to feed the document and clears the error right away. You only have to do this once and from then mine worked fine.
Jan 25, 2012 | Canon Pixma MX410 All-In-One Printer
I can't erase the faxes I already send
Hi There,
While not as popular as they were before the Internet became a principal means of business communication, fax machines are still an essential item in many offices. They are particularly useful on business documents when a signature is needed. Canon makes a number of fax machines that use both ink-jet and laser technology to receive and print documents. Most fax machines store incoming faxes in memory so you can reprint them, but occasionally the memory becomes full resulting in an error message. Your Canon fax machine's memory can be cleared quickly and easily so you can start using it again.
Instructions
* Click the "Menu" button.
* Press the arrow buttons to scroll through the options on the screen. Select
"MEMORY REFERENCE" and click "Start/Copy."
* Use the arrow buttons to choose "DEL. PRINTED RX" then click "Start" again.
Press "*" to select the "Yes" option from the screen. This will delete all documents from the fax machine's memory.
* Click "Stop" to finish.
Nov 27, 2011 | Canon Pixma MX410 All-In-One Printer
My Canon MX410 went off line and I can't get it back on line. I have a Macbook.
Deleting ICONS willnot help as the driver programs must be UNINSTALLED. Now the printer driver software can have errors while being in use or is shut down. So to reset remove your printer from the PC and uninstall the printer software after opening control panel >programs. Now reinstall the printer software and then connect the Printer ONLY WHEN PROMPTED, to be detected as a new hardware as it will be installed. Now check the printer properties to see the ink levels.
Activate head cleaning before a test is taken.
Nov 22, 2011 | Canon Pixma MX410 All-In-One Printer
I have a Canon MX410 that scans, faxes, prints & copies. I need to know what to do to clear the fax memory. Thanks!
It's under printer options, format memory. You'll probably have to play with it a little because they like to hide the format option so you don't do it accidentally. Good luck! Please leave me a good rating, thanks! :)
Jul 27, 2011 | Office Equipment & Supplies
54 people viewed this question
old marine
old marine
