I need to find a schematic diagram for a K&K Sound Systems Dual channel Pro preamp.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 924 Answers
You'll probably only find that at the manufacture. You can try a Google search as well. What is the issue with the preamp? If you need more assistance, or would like to inquire about about repairing this, please contact me at audioserviceclinic.com. Thank you..
Posted on Nov 23, 2014
K-4040 left channel lost. How solve this problem?
Look for shorted capacitors and driver stages. You'll need an audio voltmeter and an oscilloscope to trace the signal path. A schematic diagram is a must.
Sep 26, 2016 | Velleman STEREO TUBE AMPLIFIER KIT /...
I'm looking for a schematic diagram for a K&K Sound Systems Dual channel Pro preamp.
Hi the only way to obtain your schematic is to contact directly the manufacturer. Anyway go see this webpage in hope you'll get some info. Have a nice day
http://kksound.com/products/dualchannelpreamp.php
Nov 15, 2014 | Audio Players & Recorders
I request a schematic diagram of crown power amp CE2000 2-Channel
The surface mount ic= MC33079D , 14 pin quad low noise op amp is likely at fault, IF the amp is NOT showing a fault light. A LM324D surface mount will
also work in a pinch. It's located on the input pcb attached to the input jacks.
Jan 19, 2010 | Crown CE2000 2-Channel Amplifier
Behringer pmp2000 europower no sound
Probably the power amp has arced and popped a lot of components.
When teh amps go usually the final pwer transistors, their drivers and sometimes even the power supply gets zapped.
Check the output of the preamp at the inserts for the final amp with headphones to see if anything is coming through.
Jan 28, 2009 | Behringer EUROPOWER EP2500 Amplifier
Where i could find the schematic diagram of yamaha amps model DSP-A1000
A common problem on these amps ie no sound is due to dirty switches and tone contols,amp face needs taking off and contact cleaner needs spraying into all controls...
Jan 14, 2009 | Yamaha DSP-A1000 5-Channel Amplifier
Carver Sound Problems
your going to need this place to download the remedy's for your system http://www.euras.com/repair_tips_1/CARVER/AV505/AV505_CARVER.htm
if it is not working then there is another serious problem , and it could be the amp IC or the volume IC but tests will need to be done to determine what is causing the failure , but it does sound like amp IC as a suspect since the rear were not even working , did the volume seem different when turning it up or down before the center quit or after the center quit?
Nov 02, 2008 | Audio Players & Recorders
Help
http://www.behringerdownload.de/EP1500_EP2500/IMPL%20Tech%20GLOB_P0183_M%20Web%20EN_2008-01-25_Rev.6.zip
Feb 01, 2008 | AMC Multimedia AV81HTC-DD 6-Channel...
Gemini p-07 amp board fault
Its better to get the schematic diagram or a similar one to be sure, but the reason for a blow up may have to do with a s/c along the line.
May 16, 2007 | Gemini Sound Products P07 2-Channel...
64 people viewed this question
 Grubhead
Grubhead
