Question about HP Photosmart M525 Digital Camera
Hp phtosmart m525 battery door will not close after the sd memory card is installed.
The battery door closes just fine with just the batteries installed but when you insert the sd card is till not latch. Can anything be done to fix this problem.
  • 63 Answers
If the card is inserted correctly, the door should close.
Posted on Nov 15, 2014
SOURCE: won't read sd card - says card not suppoorted
Did you try putting the card in the camera, and using the camera's "format" card option?(Make sure there is nothing on the the card-a format will delete it.) Often times, a digital camera requires a format of the card so the proper file/directory structure can be created. If the card is empty, you have nothing to lose.
Posted on May 21, 2007
dmathwizard
  • 113 Answers
SOURCE: How to unlock camera card--HP M525
Take the card out and there is a notch in the side of it move into the position it is not in.
Posted on Mar 01, 2008
SOURCE: HP Photosmart R927 Battery Compartment door latch
Same problem, The small plastic tab that extends into the slot to keep the battery compartment door broke off. I can't locate a source for replacement part. I disassembled the slide and reversed it, breaking off the little tip that fit into spring, and it sort of works, but a new plastic slide would be much better.
Posted on Mar 31, 2008
  • 73 Answers
SOURCE: new memory card unable to format
if there is a little slide on the side of the card try moving it to its other position either up or down
Posted on Mar 25, 2009
SOURCE: hello i have the hp r937 and i had dropped it and
Did you find someone that fix it?. I dropped mine today and there was a small plastic piece that helps to close the door, it broke, now the door won't close.
Posted on Dec 17, 2009
I havent used my olympus tg310 for a while and its been in good storage so I need to use it now and when the waterproof seal thing where the battery and sd card is when thats open it works but as soon as I...
Carefully scrutinise the battery/memory card cover. In the camera is a switch that supposes to tell the camera if the door is locked correct or not. Perhaps something is blocking the correct working of that switch. Clean the inside of the battery / memory card holder and its door.
Open and close the door several times and hope he switch starts working as it should. I hope there is no spring broken or blocked.
Success
Jan 27, 2014 | Cameras
HP Photosmart M627
Try first removing battery and putting back.
Aug 01, 2008 | HP PhotoSmart M627 Digital Camera
Where to insert sd card polaroid a515 digitgal camera
Open the battery door, located on the underside of the camera (use your thumb to slide the door outwards). Install the SD card into the slot located next to the battery bay. Close the battery door.
Apr 04, 2011 | Polaroid i830 Digital Camera
How do I reset the camera.
Hi.
1.Turn off the camera.
2.Remove any memory card installed.
3.Remove all power sources (batteries and AC power) from the camera for at least 5 seconds.
4.Reinsert the batteries and close the Battery/Memory card door and/or reconnect the HP AC power adapter to the camera.
5. Verify if the camera works without an optional memory card.
NOTE: Resetting the camera returns all settings to the factory defaults. Any images stored in memory will be retained.
Thank you for using Fixya!
Nov 16, 2010 | HP Photosmart M22 Digital Camera
My m525 is telling me card locked how do i unlock it
Little sliding switch on the side of the SD memory card. Remove from camera, slide switch away from lock position, re-install and you should be good to go.
thanks.
aman
Mar 27, 2010 | HP Photosmart M525 Digital Camera
The on off button is stuck in. is there anything you can do or do i just buy a new one.
Reset the camera
  1. Turn off the camera, if possible.
  2. If an SD memory card is installed, remove the card.
  3. Remove power from the camera as described below:
    • If you are using only batteries for power, open the battery/memory card door and remove both batteries.
    • If you are using only the HP AC power adapter, disconnect it from the camera.
    • If you are using both batteries and the HP AC power adapter, remove both batteries and the power adapter.
  4. Wait for 15 seconds. Then reinsert the batteries and close the battery/memory card door or reconnect the HP AC power adapter to the camera. If you are using both batteries and AC power, try each method separately.
Turn the camera on and off. If the issues is not resolved do the following
Connect the camera to the optional AC power supply
  1. Connect the camera to the optional AC power supply. Ensure that the AC power supply is connected to a working power outlet.
  2. Try turning the camera on.
  • If the issue is resolved , you do not need to continue with the rest of the instructions in this document.
If the is not resolved ,then repeat setps 1 to 4 abiove but remove the batteries and keep the AC power adapter connected.
Oct 14, 2009 | HP Photosmart M425 Digital Camera
Samsung s1030 will not retract lense and bleeps 3 times then no response - batteries are fully charged
Try hard reset . Remove the batteries and insert new batteries . Sometimes this may work
Another chance is that lens is struck
* Carefully inspect around it for dirt or debris
* If you see any dirt or debris around the lens, use canned air to gently blow it away
* After removing dirt and debris, turn the camera on and off
This should work.
Try this alternate solution (got information from HP )
  • Turn off the camera, if possible.
  • If an SD memory card is installed, remove the card.
  • Remove power from the camera as described below:
  1. If you are using only batteries for power, open the battery/memory card door and remove both batteries.
  2. If you are using only the AC power adapter, disconnect it from the camera.
  3. If you are using both batteries and the AC power adapter, remove both batteries and the power adapter.
  • Wait for 15 seconds. Then reinsert the batteries and close the battery/memory card door or reconnect the AC power adapter to the camera. If you are using both batteries and AC power, try each method separately.
  • Turn the camera on and off. If the lens does not retract correctly or the camera does not turn on,
You need to take to service center .
Thanks for using FIxya
SAM ANDERSON
Dec 09, 2008 | Samsung Cameras
Installing the 1gb card
Remove the sheel backside of your phone
remove the battery
now you see your sim-card
you place the sd-card just at the right side of the sim-card
lift the mediacard holder
insert the sd-card into the slot in the mediacard holder so that the metal connectors on the card will align with the metal connectors on your phone when the media card holder door is closed
close th media card holder door and slide the media card door away from its hinges to lock it
put back the battery and shell and you done!
If you still dont know, here is an demostrator how your phone works
http://demos.blackberry.com/8310/na/us/gen/
Good luck
Dec 07, 2008 | SanDisk 2GB microSD Memory Card
Camera insist on memory full, but card is empty
Press "Menu" Press button to the right (towards a little flower on my camera) which takes you to the "setting" menu. scroll down to "format" right click again and it reads "All data deleted" and then gives you the option to "Format" or "Cancel". Select "Format" and then "ok" and pronto....your memory card is ready to go.
Nov 17, 2008 | Cameras
Battery/memory card compartment wont close
Don't force it. It could be that your memory card is in backwards. This is a common cause for your battery door to not shut.
Hope this helps!
May 20, 2008 | Canon PowerShot A540 Digital Camera
HP Photosmart M525 Digital Camera Logo
329 people viewed this question
Top HP Cameras Experts
Fred Sops
teddyboy
Lawrence Oravetz
Are you a HP Camera Expert? Answer questions, earn points and help others
