Question about Camping, Backpacking & Hiking
Sifter cable will move but the car wont you can feel it go in gear but wont move
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 99 Answers
You may have a broken axle. You need to take it to a shop to have the car looked at.
Posted on Nov 15, 2014
Izuzu rodeo drives forward on reverse gear
redux. (A/T trans answer not STICK SHIFTED manuals)
no years stated
no transmission stated, auto or stick.
stuck in Reverse.
linkage checks are first.
the trans has lever on the side
called the Manual valve.
it that lever does not go to DRIVE,
then there will be no drive.
there is a cable from the Shift selector to that
transmission side lever.
inspect these parts for proper movement
no damage, not slipping cable, etc.
only you can do that.
or your mechanic.
Dec 13, 2016 | Isuzu Rodeo Cars & Trucks
Sifter cable for 2005 hyundai elantra
Your axle may be broken. You will need to take the car to a repair shop to find out exactly what is wrong.
Nov 15, 2014 | Camping, Backpacking & Hiking
Grinding noise from transfer case
you need repair manual for the 4 wheel drive.
you will need to pull it apart and repair the internals.
Apr 08, 2014 | Ford F-150 Cars & Trucks
Having a problem with my 99 tahoe 4x4 5.7 will shift up to 3rd and the when u come to a stop it wont shift back down to 1st gear till u shut off the truck just got it and it was doing the same thin
run the fault codes to determine if the electronics are working correctly. TCM servos and solenoids. Change the oil and filter and while the pan is off check the band and clutch pack adjustment. Have a pressure test done on the box to check for internal problems.
Feb 16, 2014 | Cars & Trucks
Gears wont select in 95 hyundai excel
check the sifter cable it might have gotten slack, stretched or stripped. you may need to tighten it or replace it.
Dec 30, 2012 | Cars & Trucks
88 pathfinder wont engage
check your rear brakes brakes could be locked due to frozen park brake cable or cables
Mar 07, 2012 | 1988 Nissan Pathfinder
Shift lever won't go to park and moves stiff even while pushing on metal lever on the side of the transmission
The first thing i would do is to disconnect the cable at the lever on the ******, next move the lever at the ****** by hand and it should move by hand with little force. if the lever is hard to move then you may have a trany shift rod problem. next with cable removed try to go through the gears with the shifter , the shifter should flow with ease if its hard to move then its the shifter cable or the shifter itself. to find out which one you will need to disconnect cable at sifter and then move the shifter to see if its still tight. if the shifter is tight to move with cable removed then its the shifter but if it moves with ease then you have a bad cable. good day.
Aug 27, 2011 | Chevrolet 1500 Cars & Trucks
Gear sifter is broken.cant put in gear
if you need to move it manualy shift it on the trans where the linkage hooks up to it
Sep 16, 2009 | 1991 Mercury Grand Marquis
My manual trans in a 1999 vw beetle reverse drive forward
I had a simular sounding experience with my 99 beetle after hitting a curb. felt like it was stuck in 3rd and 4th only-had no reverse. My problem was that there was a linkage on the sifter gears broken.
Apr 01, 2009 | 1999 Volkswagen Beetle
Trany won't go into gear
rip gearbox out and fit a manual ,then you can become a man by right of passage.Front clutch ??? fluid level??
Mar 18, 2009 | 2000 Daewoo Nubira
Camping, Backpacking & Hiking Logo
44 people viewed this question
Top Camping, Backpacking & Hiking Experts
Tom Chichester
ray gallant
Are you a Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
