Question about Microwave Ovens
Microwave is on but it won't take any #s .I can't even program the clock
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 99 Answers
Try unplugging the microwave for 30 minutes. This will allow the computer inside to reset. If this does not work, your circuit board probably needs to be replaced (or buy a new one).
Posted on Nov 15, 2014
Light stays on and won't start
emerson mecrowave mw81195bm clock works but I can heat anything it doesn.t work inside
Oct 22, 2012 | AEG MCD3534EM Stainless Steel 900 Watts...
Sharp Carousel R-7A85 Won't Turn On
Yes! but the fuse went for a reason, the problem could be a bad door switch to a more serious problem.
May 29, 2012 | Sharp R-7A85 Microwave Oven
Panasonic Microwave suddenly won't cook.
Your microwave is detecting an internal shot and shutting down, Most likely due to a faulty Magnetron which is not a part that is worth replacing due to the cost of the part and the decrease in cost of new microwaves.
Mar 06, 2012 | Panasonic Microwave Ovens
How do I unlock the touchpad of my Profile 2.0 Spacemaker Microwave Oven # JVM2070
calvin,
If you have access to where your microwave is plugged in, unplug it for a few minutes and then plug it back in. This will reset your contol panel. Then follow your book directions to reset the time on the clock. Hope this helps!
Nov 06, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
My microwave resets itself whenever the door closes. I do not even program the time on it because it always resets. The microwave works, just very annoying.
either a defective circuit board or a keypanel problem. reset clock and disconnect circuit board keyboard ribbon connector to isolate problem.
Aug 06, 2011 | GE JVM1340AW/BW/WW Microwave Oven
Won't turn on after disconnecting the power code from the wall socket,
Press stop / cancel
Then press Clock
Enter time
Press clock.
It should now be working normally. If not respond here again and I will help you.
Thanks for choosing FixYa,
Kelly
May 12, 2011 | Whirlpool MH6150XM Microwave Oven
The colon between the numbers on the clock, example 8:00 won't stop blinking even after I set the clock and hit the clock button again.
Sometimes the correct procedure for setting the clock is to press the CLOCK or TIME OF DAY button, then enter the time on the keyboard, then press the START button instead.
Otherwise, as long as you can enter a cooking time and your oven operates normally, then don't worry about it. On some models it is normal for the colon on the clock display to blink all the time.
Good luck.
May 11, 2011 | Microwave Ovens
Keypad number buttons not working on ge spacesaver microwave - auto program buttoms work?
Very angry. Fairly new, little-used Spacesaver Microwave [3][Clock][Surface Light] buttons now do not work. We never even press [3], just [1] and [2] to warm sandwiches.
Unplugged for an hour. Still not working. Everything else works. We never use anything else. Bad solder joint in circuit board or keypad?
Thank you.
Aug 28, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
I have just been given a Panasonic microwave (NN-E255W)but have no idea how to program the clock, no manual either
On most microwaves, to program the clock you press the button marked, "Clock," or "Timer/Clock," or something similar. You then enter the time on the keypad by pressing just the numbers for the current time, then press the clock button again.
Mar 03, 2008 | Microwave Ovens
Sharp R-9H56 Microwave convection oven
I have this model. Press clear then press Auto/Clock. Enter in the time eg 700 then press Auto/Clock again. The time should now be set
Jun 08, 2007 | Sharp R-1872 Convection/Microwave Oven
Microwave Ovens Logo
27 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
