Battery number for lifegear magnetic oxy cycle
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 99 Answers
Http://www.lifegear.com.tw/PDF/16063-Motorized%20Oxy%20Cycle%20Manual.pdf TO REPLACE THE DISPLAY BATTERY:
When the display screen begins to fade, replace a 1.5V "AAA" size battery.
Disengage the digital display computer from top of the device by gently pulling
on it; replace a 1.5V "AAA" size battery.
Posted on Nov 15, 2014
How to insert batteries in a life gear path flashlight
Hello, Sandra -
From a Life Gear web page with frequently asked questions:
http://www.lifegear.com/faq
(Quote)
  1. How do I change the batteries in my Life+Gear flashlight?
We are currently in the process of uploading instructions on how to properly change the batteries in your Life+Gear flashlight, in the meantime please feel free to contact our customer service department for instruction. If you are unsure about which model you have, you can upload a picture of your flashlight and attach it to your email.
(End quote)
The email address for Life Gear Customer Service can be found here:
in the lower left corner of the page.
I do not find a Customer Service phone number you could call.
Best wishes.
May 03, 2018 | Camping, Backpacking & Hiking
I need the Owners Manual for LifeGear 22815 Upright Deluxe Bike
Try Googling (LifeGear)(22815)(manual) without parens.
Aug 13, 2017 | Cycling
How do i fix a lifegear treadmill 97520?
Try below:
ERROR CODE
DESCRIPTION
E1
Speed error (The treadmill running speed is 3.2 kph faster than the displayed
speed). The treadmill will stop immediately when the console detects this error.
E2
Speed error (The treadmill running speed is 3.2 kph slower than the displayed
speed). The treadmill will stop 16 seconds later after the console detects this
error.
Troubleshooting / Resetting error codes
In the rare event of the treadmill displaying an error code ("E" followed by a number), simply reset
the computer by:
1. Step off the treadmill. Ensure that you are clear of the running belt.
2. Turn the treadmill off at the master power switch located near the motor housing.
WARNING: Ensure nothing is positioned near or under running belt which may possibly block
it's normal operation.
3. Turn the treadmill on at the master power switch.
4. Ensure that the Safety Tether Key is securely and properly installed onto the console or just
reinstalling the Safety Tether Key can also reset the display.
If the above does not clear the error code, please contact the nearest Dealer/Service Center
LifeGear 97320 Owner Manual Page 17
May 22, 2016 | Exercise & Fitness
My maytag neptune spins water out, the tub is empty but when you turn the tub manually you can hear water sloshing and the clothes smells moldy after washing
There will always be some residual water left in the outer tub after draining. This is normal for most washers. Purchase a container of Oxy-clean and cycle the washer a few times using hot water settings with a half-cup of Oxy-clean added to each cycle. This will help remove any organic matter left behind that might be causing odors.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/dave_fb2c45146b845cea
Oct 15, 2014 | Maytag Neptune MAH5500B Front Load Washer
Put batteries in a highland series 150
I'm not familiar with this particular torch but similar torches use an adaptor such as one depicted below to enable AAA batteries to be used where the primary battery is either a 18650 battery or two CR123 batteries in series. I hope this helps.
Sep 21, 2014 | LifeGear Life Gear Highland Series 150...
Lifegear treadmill
You might inquire of Lifegear how many watts it consumes
Jun 04, 2013 | Exercise & Fitness
Agent in bahrain.
you must contact to the company supplier for the treadmillss and ask who is the dealer around you. Give you moder, mark, and serial number
God bless you
May 30, 2013 | Exercise & Fitness
Lifegear motion plus 97920 problem
please adjust the REED switch and see the diagram attached. Test for open or faulty. Clean it + tight the connector very well.
2) if you equipment has battery replalce by new ones and clean it, and putt with FULL energy.
3) TIGHT THE RIBBON CABLE for keypads , clean it and try again.
God bless you
Feb 22, 2013 | Exercise & Fitness
I need the I.C number on a Lifegear Walkease Motorized Treadmill # 97295, found out the ic was burnt on the control panel whicl always display E2 code
Dear Sir:
1)In electronics, you must need to get the number of IC.
2)If you get some information like as the number of the Control Panel, will be more easy to find, the I.C.
3) You must shure the why the I.C. was burn? . Normally this problem can occur a) failure for some short of some component around the I.C. b) Power supply +5 or 12 Vdc or Low or Higher( Indicating that power supply is Not Good).
4) Would you please tell the exactly Model, Mark, Serial from your Treadmill? In that way I can help you more, and try to get the Schematic Diagram from your Fitness Treadmill.
Sincerely. God bless you.
E.CUADRA
MANAGUA, NICARAGUA. C.A.
Oct 24, 2011 | Exercise & Fitness
Owners manual for lifegear manual treadmill
I have a lifegear treadmill and get an E2 error and the treadmill will not move.
Aug 19, 2010 | Exercise & Fitness
Computers & Internet Logo
David Payne
David Payne
