So mine is leaking out the front also. I can hear the water going into the detergent tray and then it drains out the bottom front of the tray itself. Obviously there is a clog somewhere in the tray, I just can't find it.
TAKE THE DETERGENT TRAY OUT AND CLEAN IT.
IF THE PROBLEM PERSISTS TURN THE WATER DOWN TO A DRIBBLE AND SEE IF THIS FIXS THE FAULT. IF IT DOES--- THE WATER IS SPLASHING UP THE FRONT OF THE TRAY AND OVER THE TOP.
1) TAKE THE TRAY OUT 2) LOOKING AT THE TOP OF THE CAVITY ,COUNT BACK 4 ROWS OF HOLES, DRIILL THEM OUT TO 1/4 INCH . 3) BLOCK THE FIRST 3 ROWS OF HOLES WITH SILSATIC.
IF THE SLOW FILL DOES NOT FIX THE PROBLEM TAKE THE 2 SCREWS OUT OF THE BACK AND SLIDE THE TOP OFF, YOU WILL THEN BE ABLE TO SEE THE DISPENSER AND THE HOSES GOING TO IT. THEY MAY BE DAMAGED.
