Question about Schwinn Cycling
Why does my bike computer keep reseting when I press the left button in the trip distance screen.
The computer is a wireless 15 function with 1" screen. computer keeps resetting ..I have taken battery out and installed .when on short trip and tried to reset dst but everything get reset,and have to input everything time,tire input and odo total.. email gminges@yahoo.com
3 Suggested Answers
SOURCE: Resetting the distance on my Bell F20 bike computer
Did the same thing. Manual is incorrect. Hold only the left button for 3 secs. This will reset DST.
Posted on Aug 03, 2009
kingrh
  • 14 Answers
SOURCE: I just bought a Bell
after holding down both buttons for 3 seconds those four numbers show up . They are changed according to the tire measurement. Use the chart in the manual to determine your four numbers. then set each digit by repeatedly pushing the set button. push the mode button to advance to the next digit. After the fourth digit is set the set mode will advance to the next setting.
Posted on Aug 20, 2012
How to set tire size on sette triton wireless computer
For the Sette Triton 12 Function Cycle Computer:
Go to the ODO mode, then press and hold the tiny "SET" button on the back of the computer for 3 seconds to go to setting.
Press "SET" button again to select between Km/H or Mile/H. Press large "MODE" button to go to Bike1 & Bike2 Setting. Then press "SET" button to select Bike1 or Bike2.
Press "MODE" button to go to Wheel Settings. Input the correct wheel size by pressing "SET" Key. the size it asks for is the circumference of the tire, in millimeters. You can find the circumference yourself by making a mark on your tire, pushing the bike forward until the mark makes one full rotation, then measuring the distance on the ground between where the tire started and stopped.
A table like this: http://1.bp.blogspot.com/_bTatB4zy3aI/Sh8Yx7IsnwI/AAAAAAAAABs/KHvHuoYuARA/s1600-h/circs.JPG
is included in the manual, and if you know what size tire you're using, I'm almost positive the number under "circumference" is the correct one to input into the cyclo-computer.
Dec 21, 2013 | Sette Triton 12 Function Wireless Computer
03 Range rover "engine service
Try this:
Switch ignition OFF
Press and Hold left instrument panel reset button, switch ignition ON to position 1
Keep reset button pressed for approximately 5 seconds until the LCD displays "RESET SIA".
The distance to service and the service type " Inspection" will be displayed.
To reset distance the left hand button should be pressed before the 'RESET' message has
flashed 5 times. The LCD will display 'END SIA'. Switch ignition off
The timing to do this is must be about 5 seconds, if this is not working you can try again.
Jun 21, 2011 | 2004 Land Rover Range Rover
The service engine soon light is on for my range rover 2004.
Try this:
Switch ignition OFF
I have a Range Rover 2005 and it worked for me.
Nov 13, 2010 | 2004 Land Rover Range Rover
How do I reset my maintenance required light on my 2009 Avalon?
SWITCH IGNITION ON WITH ENGINE OFF.PRESS SMALL ROUND BUTTON ON LOWER RIGHT OF THE SPEEDOMETER UNTIL IT DISPLAY ODOMETER.THEN TURN OFF IGNITION SWITCH OFF.PRESS AND HOLD SAME ROUND BUTTON LOWER RIGHT SPEEDOMETER TURN IGNITION TO ON WITH ENGINE OFF.CONTINUE TO HOLD BUTTON FOR AT LEAST 5 SECONDS UNTIL IT DISPLAY INDICATES 000000 AND MAINT REQUIRED LAMP WILL EXTINGUISH.RESETTING IS COMPLETE.
Oct 19, 2010 | 2008 Toyota Avalon
I have a blackburn delphi 2.0 bike odometer how
Press and hold the middle button when you are on the total distance screen.
May 11, 2010 | Blackburn 4.0 Bike Computer
2007 Lexus ES350. Mater Warning Light is activated for oil maintenence. How do I shut it off?
if you do not have navigation system.
  1. Turn the engine switch OFF..
  2. While pressing the trip meter reset button, set the engine switch to IG-ON mode. Continue to press and hold the knob until the trip meter displays 000000.
if you have navigation.
  1. Push the "INFO" button
  2. Touch "Maintenance".
  3. Touch the desired button Delete All : To cancel all conditions which have been input. Reset All : To reset the item which has satisfied a condition. If "ON" is selected, the system gives maintenance information with the "Information" screen when the system is turned on. If "OFF" is selected, the "Information" screen is disabled.
  4. Input the conditions. Notice of Date : The next maintenance date can be input. Notice of Distance : The driving distance until the next maintenance check can be input. "Delete" : To cancel the date and distance conditions. "Reset" : To reset the date and distance conditions.
  5. Touch "OK" The screen returns to the "Maintenance screen.
Mar 05, 2010 | 2007 Lexus ES 350
Jul 21, 2009 | Cycling
How do you reset the odometer for new trip on Bell wireless odometer. there are 3 mode buttons bottom & 2 sides. Seems like it is all the same & none say reset.
Pressing the right button should cycle the bottom display thru the functions--the current time, ODO (the odometer, showing the total mileage you've put on the bike), DST (the trip odometer - the one you're talking about), MXS (the maximum speed you've traveled on the bike). AVS (your average speed since your last reset) and TM (the time you've spent moving since your last reset). Some computers will also show the current temperature, the number of calories you've burned and the grams of fat you've burned.
Press the right hand button until you get to the DST display. Then press and hold the left button for about three seconds. The display should reset to 0.000.
If this doesn't do it (the display changes to MXS or something), cycle the display around to DST again and try holding one of the other buttons for a couple seconds. Holding one of 'em down should zero out the display.
Jun 17, 2009 | Cycling
Bell f20
here are the wheel value for a Bell F20
Road Bike
20" 1596
22 1759
24 1916
26 2073
27 2124
Montain Bike
24" 1888
26 2045
27 2155
28 2237
I hope this helps set your F20 computer.
Sep 11, 2008 | Sport & Outdoor - Others
Showing dNE0
We had the same problem and got this from Indesit consumer line - it works!!!!!
1. press and hold the reset button for about 5 seconds.
2. press and hold - start/reset button
on/off switch and
the left function button ALL AT THE SAME TIME
keep holding until D OFF appears - this took about 15 seconds before it did it for us.
Feb 19, 2008 | Indesit W 123 Front Load Washer
Cycling Logo
57 people viewed this question
Top Schwinn Cycling Experts
Tony
michael
michael
jasiel murphy
Are you a Schwinn Cycling Expert? Answer questions, earn points and help others
