Question about Husqvarna 350 18 Inch Gas Chainsaw 52CC Fully Assembled Brand New 18"
What is the gap setting for the ignition coil
I rebult the engine but i cant find out what the gap setting is. Any help will be a big help.
  • Husqvarna Master
  • 1,169 Answers
0.3 mm (.012 inch)
Posted on Nov 15, 2014
What is the ignition point gap?
In older engines with traditional points-condenser-coil ignition systems the dwell if the ignition was set by the gap between the points. The points act like a switch that opens and closes the circuit of the primary side of the ignition coil.
All later engines use electronic ignition that do not require points.
Mar 28, 2016 | Cars & Trucks
460 cu spark plug gap
On that big 7.5 liter engine, .042-.046 stock; if hotter cam go .046-.050 and make sure ignition is in good shape. preferrably aftermarket coil at least or ign box set up.
Aug 20, 2014 | Motorcraft 1990 Ford Bronco II Fuel...
How to replace the coil
G13, engine?
its in the FSM and its free.
you unbolt it and put it back. its like very old school.
ah the pick up coil , the VR sensor and ignitor assembly
but that costs 2 times a rebult dizzy? why do that.>??????
there is a gap setting on the VR pickup.
http://www.fixkick.com/sammi-stuff/index.html
its in the chapter under spark ignition.
Cardone sells cheap rebuilt whole dizzy's
sold on rockauto.com
see em?
Jul 04, 2014 | 1990 Suzuki Samurai
John deere 110 engine cranks but no spark
Check that the ignition coil kill wire is not shorted to the frame.
Check coil to flywheel gap. A business card between coil and flywheel will set correct gap.
Coil could be bad or ignition switch is not releasing the kill wire in Run/Start positions.
Nov 03, 2013 | John Deere Garden
Ignition coil testing
Try using a 3 x 5 index card for the gap. After setting the ignition coil gap to the proper setting, disconnect the wire to the coil and see if it starts. If it doesn't you have a bad coil. If it does start, kill the engine by choking it and take a look at the saefty switches on the unit. Good Luck and Thanks;
George
Oct 12, 2013 | Coleman Garden
HI, I HAVE A 350 SMALL BLOCK CHEV CRATE MOTOR
I'd go with .35 for starters. Gaps shouldn't vary by plug maker.
Sep 25, 2013 | Spark Plugs BR4HS Plug 10/BX #3322
B&S 3.5hp rotorvator. No Spark
I would first change it over to electronic ignition, you can purchase a kit online.
You did not tell me you changed the spark plug, have you ? Please let me know.
www.smallenginewarehouse.com
Feb 07, 2010 | Briggs & Stratton Ignition Kit 2-8 HP...
Need point gap setting for 8 hp Briggs and Stratton gas engine
If it is an older BS it will be .015 That was standard. In fact an old match box cover would work to set them if you could not find a guage
Oct 07, 2009 | Briggs & Stratton Ignition Kit 2-8 HP...
How to replace sparl plugs on a Jeep Cherokee?
Hello, I hope this info helps...(subytech1)...REMOVAL
In this engine, each individual spark plug is located under each ignition coil.
  1. Prior to removing spark plug, spray compressed air around base ofignition coil at cylinder head. This will help prevent foreign materialfrom entering combustion chamber.
  2. On this engine each individual ignition coil must be removedto gain access to each spark plug. Refer to Ignition CoilRemoval/Installation.
  3. Check condition of coil O-ring and replace as necessary.
  1. Inspect spark plug condition. Refer to Spark Plug Conditions.
CLEANING
Theplugs may be cleaned using commercially available spark plug cleaningequipment. After cleaning, file center electrode flat with a smallpoint file or jewelers file before adjusting gap.
CAUTION: Never use a motorized wire wheel brush to clean sparkplugs. Metallic deposits will remain on spark plug insulator and willcause plug misfire.
ADJUSTMENT
Setting Spark Plug Gap - Typical
Check spark plug gap with a gap gauge tool. If the gap is not correct,adjust it by bending ground electrode. Never attempt to adjust gap bybending center electrode.
INSTALLATION
CAUTION: This engine is equipped with copper core groundelectrode spark plugs. They must be replaced with the same type/numberspark plug as the original. If another spark plug is substituted,pre-ignition will result.
Special care should be taken when installing spark plugs into cylinderhead spark plug wells. Be sure plugs do not drop into plug wells asground straps may be bent resulting in a change in plug gap, orelectrodes can be damaged.
Always tighten spark plugs to specified torque. Over tightening cancause distortion resulting in a change in spark plug gap or a crackedporcelain insulator.
  1. Start spark plug into cylinder head by hand to avoid cross threading.
  2. Tighten spark plugs to 27 Nm (20 ft. lbs.) torque.
  3. Before installing coil(s), check condition of coil O-ring andreplace as necessary. To aid in coil installation, apply silicone tocoil O-ring.
  4. Install ignition coil(s). Refer to Ignition Coil Removal/Installation.
Aug 07, 2009 | 2000 Jeep Grand Cherokee
Cant get a spark on my briggs and stratton 4hp engine, trying to
gap from coil to flywheel is .010. if you've replaced coil, points and condenser with no spark i would try replacing the coil and points with an magnetron kit or a coil that allows for the elimination of points.
Mar 21, 2009 | Briggs & Stratton Ignition Kit 2-8 HP...
Husqvarna 350 18 Inch Gas Chainsaw 52CC Fully Assembled Brand New 18" Logo
82 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
