<!-- from fixya rte -->The drum does not rotate smoothly - Washing Machines
  • 25 Answers
You may have bad bearings in the drum
Posted on Nov 26, 2014
How do I change the drum in my HL-5240
First check whether it is possible to buy a new drum for your model, if possible buy a new drum then remove the toner from your printer, separate the drum unit from the toner, if you check thoroughly the left and right sides of the drum unit how the drum has been fixed in to it you will be able to find the way remove drum from the unit, then replace the new drum and fix it. Don not tough the edge wiper blade, rotate the drum and check whether it rotating smoothly in both direction.
Mar 03, 2012 | Brother HL-5240 Laser Printer
Tip
LG Washing Machine UE Error Code Solutions
An UE Error Code is indicative of a "Unbalanced Error". This indicates that the drum is not spinning in a smooth rotation. It may be necessary to rearrange the load in the drum. gcs_la.jpg
on Jun 02, 2011 | Washing Machines
My maytag dryer,model no.DE303 makes a loude clank-a-d-clank noise as the barrel rotates. Sometimes the sound will change and smooth out, only to get lound again. How do I fix this? It still turns and drys...
This is likely caused by a worn-out drum roller. There are two of these which support the back of the drum and allow it to turn smoothly. Replacing these involves taking the front panels off and removing the drum.
Dec 15, 2011 | Maytag Dryers
What does UE mean on a 4kg LG washer drier??
Hi!! UE Error Code is indicative of a "Unbalanced Error". This indicates that the drum is not spinning in a smooth rotation. It may be necessary to rearrange the load in the drum.
Don't forget to rate this post!!
Sep 15, 2010 | Washing Machines
Goes Through Wash Cycles Empty Or Full Stops At Spin And Says UE About 4 Minutes Before End
An UE Error Code is indicative of a “Unbalanced Error”.
Thank You
Sep 08, 2010 | LG WM1814CW Front Load Washer
Kenmore dryer Drum not rotating
check the belt,it might have slid off of pulley,make sure smooth side of belt is facing up,ridges should be touching drum
Nov 25, 2009 | Kenmore Dryers
LG Tromm dryer has a crack in the drum. Can this be self repaired and if so how?
I'm a mechanical engineer and improvised a repair as follows: rotated drum so that the weld crack was not displaced; roughened surfaces and fitted a small Stanley steel mending plate across crack (shaped plate to match inside drum surface); used PC brand "Fahrenheit" high-temp epoxy putty to bed the plate in place; covered the repair with another thin epoxy layer to provide a smooth surface which would not catch on clothes; further smoothed repair with quick wipe of solvent; most likely a temp fix but working well so far (1 month).
Nov 03, 2009 | LG Dryers
KYOCERA KM2020 erreur C-4000
cause
Defective harness between drum motor and engine PWB (YC11), or
improper connector insertion.
solution
Reinsert the connector. Also check for continuity within the connector harness. If none,remedy or replace the harness.
cause
Defective drum motor drive transmission system.
solution
Check if the gears rotate smoothly. If not,grease the bushings and gears. Check for broken gears and replace if any.
cause
Defective drum motor.
solution
Replace the drum motor.
cause
Defective engine
PWB.
solution
Replace the engine PWB
Oct 26, 2009 | Kyocera Mita KYOCERA/MITA - FS-4000DN Mono...
LG WM 14316FD washing machine
An UE Error Code is indicative of a “Unbalanced Error”. This indicates that the drum is not spinning in a smooth rotation. It may be necessary to rearrange the load in the drum. I found this answer on the lg web site.
Dec 01, 2007 | LG Washing Machines
Washing Machines Logo
24 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
