Question about Husqvarna 350 18 Inch Gas Chainsaw 52CC Fully Assembled Brand New 18"
<!-- from fixya rte -->What is the gap setting on the coil - Husqvarna 350 18 Inch Gas Chainsaw 52CC Fully Assembled Brand New 18"
  • 695 Answers
The gap setting is .010 or if you don't have a feeler gauge you can use a business card. GOO LUCK FRIEND.
Posted on Nov 16, 2014
Air gap for coil
Assume you are asking for the air gap between the flywheel and the ignition coil?
Obtaining the correct gap from the manufacturer's specifications is best because although in theory a close gap is desirable for efficiency, flywheels grow as the engine heats up and a large flywheel can grow quite a lot.
Brass feeler gauges are best for setting air gaps as they are none-magnetic. A typical air gap would be in the region of 10 to 14 thou.
Mar 16, 2016 | Garden
What is the gap between coil and magneto
I use a piece of A4 copy paper to set the gap.
Apr 05, 2015 | Garden
Coil air gap setting on stihl BG 85 C blower
The box the coil came in should have a paper card for setting the gap. It isnt written on the paper....it is the paper! Put it between the coil and the flywheel and bolt it up! If there isnt a gap paper in the box use a paper business card in its place. The stock gap size of 0.0125 inches is virtually the same as the 12 point paper used for a business cards in the US. I would recommend checking spark before reassembly just to be sure everything is right. Be safe and good luck!
Mar 08, 2015 | Stihl Garden
What gap on flywheel and coil on briggs and stratton 20 hp intek v ?
rule of thumb for setting the gap between the coil and the flywheel is to place a standard business card between the two and tighten the coil mount bolts, then remove the card. This leaves a small gap between the two.
Jul 26, 2014 | Mtd Garden
Air gap setting ignition coil
if you didnt adjust it you dont need to know
it is the gap between the rotor for the pickup coil and the coil pickup face
the ignition coil makes energy from the rotator to feed the spark plug
you need to tell us what is up
your question is incomplete and lacks details
Dec 05, 2013 | Stihl Bg 55
Ignition coil testing
Try using a 3 x 5 index card for the gap. After setting the ignition coil gap to the proper setting, disconnect the wire to the coil and see if it starts. If it doesn't you have a bad coil. If it does start, kill the engine by choking it and take a look at the saefty switches on the unit. Good Luck and Thanks;
George
Oct 12, 2013 | Coleman Garden
What should the clearance be betwwen mag and fly wheel toro
The gap should be about .010 (Ten Thousandths of an inch), but truthfully, the way I set it is to loosen the coil bolts and place a shiny business card in between the coil and flywheel. Tighten the coil up snug against the business card and then remove it. This should set the gap close enough to the correct setting for you; done. Hope this helps and best of luck to you.
James
Nov 11, 2011 | Toro Lawnmower 20099 Mower Mowers Lawn
No spark what is air gap between coil &
Hi, gap is 8 thou. If this gap setting has not been altered from the factory it should be ok. Try a new sparkplug if you hav'nt already done so. Also try temporarily disconnecting the stop wire off the coil. If none of this works
May 02, 2011 | Ryobi 30cc 17" String Trimmer Zrry30530...
Model TB320BV 2-cycle blower.
there is no set gap realy what i do is put a thin bit of carbord inbetween the coil and fly wheel so there is say 25th of an inch of gap dont set it so tight that the fly wheel hit's the coil or it will distroy it there needs to be a very small gap and it will work just fine,,ok?
Jul 27, 2010 | Troy-Bilt 31cc 2-Cycle Gas Powered...
I need coil and spark plug gap settings for echo hc 1500 type E2 hedge trimmer.
0.026 inch, or 6-8 mm is the plug gap.
The ignition coil air gap range is 0.012 - .016"" or .3 - .4 mm. This is the gap between the flywheel and the ignition coil.
An easy way to gap your coil is use a normal business card between the coil and flywheel, tighten the screws and remove the card.
Oct 23, 2009 | Echo Garden
Husqvarna 350 18 Inch Gas Chainsaw 52CC Fully Assembled Brand New 18" Logo
59 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
