Question about Refrigerators
Hotpoint refridgeerator not cooling HSS251FMD
Freezer nor fidge are keeping things cold
  • EVALINA
    EVALINA Nov 16, 2014
    Thank You So Much, I did just change the switch board and the thermostat about 3 months ago. Im hoping its a condensor blade stuck. I did the repairs myself last time so i hope i can figure out how to check for a blade stuck , thanks again..
  • Refrigerators Master
  • 744 Answers
Hello Evalina;
My name is Peter. I am a retired field service refrigeration technician.
There are several areas that affect your cooling problems:
1) Dirty condensing coil or condenser fan motor bad, or condenser fan blade stuck. The cleaning of the condenser cooling coil shown on the following diagram #730 can affect your cooling by as much as 40 Degrees F. But, I do not think that is your problem. Your cooling fan blade may be stuck or your cooling fan motor may be bad. Item 650 on the following Diagram.
2.) You could have a bad thermostat which controls the cooling and activates the compressor and your evaporator cooling coil fan. This is item 730 on the following diagram, or you could have a bad cooling coil fan motor item 610 on the following diagram.
3.) I do not believe you have a main control board problem.
You may have a restriction in your refrigerant seal system. If you pull off the back cover on your freezer and there is ice build-up in the upper right hand corner, then you have a restriction. If you pull off the back cover in your freezer and all of the evaporator coils do not have a nice frost pattern, then you have a refrigerant leak. This repair would require replacing the evaporator coil and refrigerant dryer the dryer. This repair would be about $600.00 USD.
I am sorry that I am not there to help you.
Your friend,
Peter, Baltimore, Maryland, USA
Posted on Nov 16, 2014
  • EVALINA
    Hi Peter where would i be able to find the diagram you posted for some reason they dont alow me to see them? thanks
  • Peter Goodwin
    Peter Goodwin Nov 16, 2014
    Go into the following website I give you. Find your model on the left, then on the far right click on Parts. http://www.searspartsdirect.com/partsdir...
  • 695 Answers
Sounds like a Freon leak. How old is the unit? You will have to decide if it's worth fixing or to replace. GOOD LUCK FRIEND.
Testimonial: "Its about 10 yrs old and I just changes the switch board and the thermostat about 2-3 months ago, they told me to check the condenser blade to see if its stuck? I hope that's something I can do . I did the work myself last time...thank you so much .."
    Director Badge:
    Uploaded 100 video answers.
  • 488 Answers
leaking evaporator coil on ge side by side.
Posted on Jun 27, 2015
mumma_1
  • 903 Answers
SOURCE: Freezer is completely covered with white ice
sometimes a faulty door rubber can make the freezer work overtime. Does the door close firmly?
Posted on Oct 25, 2008
SOURCE: hotpoint future RFA60 Fidge Freezer
I have lost the instruction booklet for my Fridge Freezer RFA60. How do I defrost the freezer?
Posted on Nov 08, 2008
  • 5 Answers
SOURCE: freezer fan not running
Often times the defrost termination switch (which opens when it gets warm enough) will hold the fan off until it closes again when the freezer runs. It is possible that the switch is not closing, but be sure the freezer is getting cold enough for it to close.
You know the freezer is likely cold enough when you see frost covering the entire evaporator coil after a few hours of operation. A partial frost pattern could indicate low refrigerant, or a restriction of refrigerant.
Posted on May 29, 2009
jumptrout51
  • 3361 Answers
SOURCE: Refrigerator side doesn't keep things cold, just
Look on the back wall of the freezer for a ice buildup. If there is ice you have a defrost problem. The defrost timer is in the fresh food section inside the control panel.The defrost heater and defrost thermostat are behind the freezer back panel inside the freezer.
Also check the freezer fan. If there is no ice buildup in the freezer the freezer fan motor could be bad.
Posted on Nov 21, 2009
heatman101
  • 43501 Answers
SOURCE: Hotpoint htr17bb Top Freezer Refrigerator Freezer working, but refrigerator not cooling
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Posted on May 25, 2010
Hotpoint refridgeerator side by side fan not working nor does the compressor?
First thing I'd do is defrost it completely, that means turning it off for a few hours with door open & letting the ice melt, you could be getting a buildup of ice in your freezer jamming the fan before the automatic defrost has time to clear it. Also check that the seals are sealing completely, (that can allow frost to form in freezer), if not use a hair dryer to soften them (gently) & mould them back into line.
Nov 19, 2014 | Hotpoint HSS25GFP Side by Side...
Fidge and freezer not keeping things cold
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Aug 03, 2011 | Refrigerators
Freezer temperature waring light on high,freezer door is shut correctly . light has now been on over 24hrs ,all frozen foods have been removed now . fidge is approx 9yrs old ,first time anything has gone...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
heatman101
Jan 05, 2011 | Hotpoint FFA70 Bottom Freezer Refrigerator
After a moving to a new city, we had our Hotpoint model HSS251FMD WW refrig in storage for 4 months. When I installed it in our new house it will not cool. Is there a reset button?
flush the refrigerant by nitrogen & refile new refrigerant.every work doing by qualified technician.my be some compressor oil over com in freezer
Jan 03, 2011 | Hotpoint Refrigerators
My hotpoint quadrio amber lights at the top of the fridge door are flashing is this anything to worry about - they are indicated with the words ''super cool'' and ''super freeze'' (sorry but cant find...
my hotpoint quadrio is causing problems the fidge part is no longer cooling the light is coming on but thast is all what can cause this. can anyone help
Feb 20, 2010 | Refrigerators
The temperature is set on high in both the refridgeerator and the freezer but it will not freeze things like ice cream its not cold enough and in the fridge things are not as cold as they used to get. Is...
Make sure the compressor fan is not rubbing against anything and there is proper air flow to cool the compressor. Remove all dust. Also make sure you don't keep too much food in the freezer to inhibit the circulation of cold air.
Jul 13, 2009 | Frigidaire FRT17G4B Top Freezer...
Fidge freezer is not working properly
Get british gas homecare cover for heating and appliances, don't tell 'em the freezer isn't working, then a month later report it as a fault, they'll fix it. Unscrupulous i know but what can ya do? Otherwise get a hotpoint engineer, sign up for their maintenance plan.
Apr 04, 2009 | Hotpoint FFA70 Bottom Freezer Refrigerator
Oct 25, 2008 | Refrigerators
Hotpoint future RFA60 Fidge Freezer
Nov 04, 2007 | Hotpoint FFA60 Bottom Freezer Refrigerator
Refrigerators Logo
394 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
