Question about Rainbow Vacuums
The red light on the front of my rainbow dies not come on. Is it supposed to or is something wrong. The machine is only 3 months old.
    Sergeant:
  • 272 Answers
Something's wrong. If the light's not on, how would you know if it's running??
Heh, Heh..... :o)
Seriously, it is a slight problem. A minor one, but a problem.
Posted on Feb 06, 2015
2 Suggested Answers
  • 41 Answers
SOURCE: red light flashing on rainbow
The red flashing light is normal, as long as it does not give an error code, and is a steady flashing, when it is running.
Thank you,
Ralph
Posted on Jan 12, 2011
My rainbow stop working.no red lights.3 times try to start and then switch off by itself.what should I do?
PDF]3 - Rainbow
rainbowsystem.com/.../Rainbow_e2_2011_R14449A-1_English_P...
RexairAs part of Rexair's Customer Care program, each Rainbow and Power Nozzle receives a ... If the Rainbow is not working ... Do not clean the unit or unclog the hose until theRainbow is switched off and the plug is removed from the wall ..... alone or with the Jet Brush attached. ..... The Power Nozzle brush is stopped and.
My Rainbow Vacuum Cleaner Won't Turn On ' eHow
Rainbow keeps shutting off Vacuums Questions & Answers ...www.fixya.com > Forum > Tags > keeps shutting off > VacuumsRainbow vacuums keeps shutting off related questions and answers. ... My Rainbowstopped running I was using the Rainbow and it stopped running. ... the switch . my electrolux has the same problem but wont always turn on.so it probably is ...Three common problems with Power Nozzles and how to fix ...
Dec 03, 2015 | Rainbow Vacuums
My rainbow was working, now the rug cleaner quit.
Does your power nozzle have a red power light? Your Circuit Breaker PN2E PN2 could be defective. Also check the hose connection to the front of the Rainbow. Be sure that it has both latches secure. This can cause power nozzle to not run.
You can also contact our technical support team at Contact Us
RainVac
Sep 16, 2015 | Rainbow E series Canister Wet/Dry Vacuum
Flashing red light on Morphy Richards 732000 Supervac
If it is supposed to go green then the battery is not being fully charged. Unit is under warranty and now is the time to have matter addressed.
Aug 20, 2015 | Vacuums
Is the red light supposed to be on when using the beater bar? or is that a re-set light?
Yes it is supposed to be on. Is a indicator light and the little red button is the re-set button for the circuit breaker
Jan 05, 2015 | Rainbow Vacuums
Rainbow riches machine not working
If you just brought it return it and your money back.
Mar 01, 2012 | Vacuums
Rainbow E2 2 speed vacuum motor whines at startup
I used to sell rainbow vacuums and this latest 2 speed model does whine when it is first turned on. So you definately have nothing to worry about. I believe this is due to the fact that this motor is much more powerful than in the previous 1 speed E series model. I finally just purchased a 2 speed model after many many years of wanting one. Good luck to ya and enjoy your clean house!
Feb 18, 2010 | Rainbow E series Canister Wet/Dry Vacuum
There is a flashing red light on my rainbow e2 machine?
There is a flashing red light on my rainbow e2 and little smells bad
Dec 27, 2009 | Rainbow E series Canister Wet/Dry Vacuum
Rainbow stops shortly after starting to vacuum
There is a thermal fuse on the motor field that sometimes fails. Sometimes the fuse does what it is supposed to do - prevents motor from overheating.
Causes:
a) Improperly worn motor brushes
b) bad motor bearings (that usually leads to uneven motor brush wear)
c) very dirty cooling air filter
To access filter and the motor - use small flat screwdriver to remove clear side panels. You will see 4 or 6 Phillips screws. Remove screws - cap will come off.
Good Luck,
Rocky
Mar 17, 2009 | Rainbow E series Canister Wet/Dry Vacuum
Rainbow E Series
You are supposed to use the hard surface cleaner solution and mix with water. Vaccum the hard surface first, then dip the hard surface attachement in the mixture (while machine is off. otherwise you will just **** up all the mixture! :) ) turn on the machine and "mop" away!! I love it!!
Jun 23, 2008 | Rainbow E series Canister Wet/Dry Vacuum
Vacuums Logo
134 people viewed this question
Top Rainbow Vacuums Experts
Joseph Hoffmann
Jax Planet
Jax Planet
Are you a Rainbow Vacuum Expert? Answer questions, earn points and help others
