Hello.... and H-E-L-P please ! 11 month old Samsung ua60f8000 connected via coax to antenna, suddenly "no signal".... have reset, retuned (now no channels) and tried all except a new coax (waiting for
> 11 month old Samsung ua60f8000 YES, only 11 MONTHS OLD/NEW :( > connected via coax to antenna, > suddenly "no signal" > have reset, retuned (now no channels) and tried all except a new coax (waiting for stores to open) ....any ideas anyone ??? > yet to contact retailer re warranty also (again, waiting for stores to open)
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 99 Answers
It is possible that the cable to your antenna is broken somewhere. You have the right idea to start there.
It is also possible that your TV is looking at CABLE instead of AIR, or visa versa.
Posted on Nov 15, 2014
Testimonial: "Thanks Soccoachr... I'm hoping it is just a coax cable - despite the warranty on the tv still valid - it's a 60" and wall mounted - not something easily moved. Air/Cable option not available, no cable connected, just DVD rec & surround sound. I must head out to get a new coax soon.... here's hoping ! Cheers."
Highdefjeff
  • 124 Answers
SOURCE: Visco LCD TV VSC-32V3 32
After connecting the cable to the TV, you should scan for channels. With the built-in cable QAM tuner, you should be fine with a scan for channels.
Try another TV to make sure that cable broadcasting is coming in...is there a set-top cable box involved?
Posted on Apr 08, 2008
SOURCE: Complete black screen on samsung 46 inches
Thats Samsung for you. They are designed to last just right outside the warranty then fail. Typically the LCD panels are bad, and they are the most expensive part on that Korean unit.
Posted on Oct 07, 2008
SOURCE: RCA Colortrak 2000 remote control
I called RCA's 800 number on the back of the owner manual--got a response that said to replace the unit since only the up-down channel changer buttons were not working. Using another remote (universal) now--cost only $5.
Posted on Dec 15, 2008
SOURCE: digital - Weak or no signal digital coax when hdmi dvd player on
if u have placed your DVD next to your tv ... just maintain distance between then and check out
Posted on Apr 01, 2009
  • 10 Answers
SOURCE: LCD TV SCREEN PROBLEM RED HORIZONTAL LINES OF DOTS ALL OVER SCREEN PLEASE HELP
This should be repairable. It may be the LVDS Cable or the Main board problem. The only other problem is the T-Con Board.
Posted on May 23, 2009
Home stereo with outside antenna, when I insert the coax cable into the stereo the radio plays fine until the type f connector touches the radio and that is when the static starts, please help
Hello, Try terminating the other end of the coax cable with a 50 ohm resister. Also .this could happen due to overloading the input with strong signals. If you know some electronics, you could connect two back to back connected diodes(in 4148) at the radio input end to limit the signal level.
Feb 28, 2018 | Radio Communications
I have reprogramed a LG tv and it keeps says no signal after receiving 5 to 11 stations
Sounds like you need a better antenna or an amplifier for you antenna. But check first you antenna coax connection to make sure the electrical connections are tight. Also check your coax for breaks in continuity. You can do this with an Ohm meter. You should have near zero resistance center to center of the coax and same for the out shield. More likely the problem is not your coax but a weak signal from over the air. Also check to see that your antenna selector on your TV menu is not set to Cable but rather Air assuming your are wanting to pick up free over the air signals and not cable.
Feb 12, 2015 | LG 32LG30 32 in. LCD HDTV
How to connect a rabbit ears antenna,samsung plasma tv ppm42s2
If it has no coax fitting it is a monitor--no tuner of its own--signal would have to be connected via one of the sets of rear audio and video jacks with a box having the same jacks.
Apr 23, 2012 | Televison & Video
Tmy tevion tv needs retuning every few days, what is the proplem?
First check the aerial's cable coaxial(coax) plug/s is/are ok. Poor signal strength can cause this problem - all bad coax connections drop signal strength.
Dec 19, 2011 | Tevion Televison & Video
Hello, I need help with a cb problem. My radio isn't reaching or receiving any thing farther than 100 feet. I just rewired it directly to the battery and I have a fire stick antennae.
Having that short a range would give me the indication that there is a disconnect in the antenna system. Here's a couple of clues: Is the connector on the back of the radio connected to the coaxial cable?
If it is not factory installed connector, is it possible that the solder job on that connector was bad? If the cable is old, it could have a crack in the coax.
Is it the RIGHT kind of coax? It should be an RG-8, and RG-58, or a variation of those types of cable. It would likely be marked with "50 Ohm" somewhere along it's length.
Is the connection at the antenna solid? A firestick antenna for CB looks like this:
You must make a good connection at the base of the antenna from the center coax conductor that does NOT short it to ground, and the ground conductor should attach to the antenna mount frame.
With your symptoms, it is very likely that either the center conductor has worked loose, has become unsoldered from the terminal lug, or your coax has come unsoldered from the center pin. All of these things would really honk up your SWR, or Standing Wave Ratio, which is sort of like a string on a guitar that is tuned to a specific frequency for a specific note. The center freq of the CB band is 27.155 Mhz, so you would typically "tune" your antenna for that to be the lowest. A firestick KW is not tunable, so that should not be an issue. Look to your coax at both ends, and the coax itself to find your problem. If you have a simple ohm meter it would help to locate the short circuit. Good luck, write back if you need some assistance in further troubleshooting.
Apr 02, 2010 | Radio Communications
Most of the channels breaking up despite auto retuning
could be one of a few things,
low signal strength, aerial out of line with transmitter.
bad coax connections losing signal strength.
coax broken inside, or old and not low loss.
Get the aerial checked for direction, half a degree out of line over a few miles and you will lose a lot of signal strength, as will old coax (aerial cable) and if you are using an unshielded coax you could be losing signal strength through the cable itself. Replace the connecters and try to use a straight run of cable instead of having joins in it as these joins, even if using connecters, will cause a weak signal. If yiu are running more than one tv off your aerial, invest in a booster.
Feb 06, 2010 | LG 32LG30 32 in. LCD HDTV
I have my cable coax connected to the UHF, VHF, CATV input. If I connect cable to Digital Antenna In input and do channel search will I receive local digiatal broadcasts or do I need to split the coax to...
You need to put a compatible cable decoder box between the cable and TV as the sanyo will only decode analogue cable signals via the catv UHF vhf input
the digital antenna in is for digital air broadcasting signals only
Jul 25, 2017 | Sanyo HT27546 TV
Digital - Weak or no signal digital coax when hdmi dvd player on
Apr 01, 2009 | Samsung LE40R74BDX 40 in. LCD Television
Remote Antenna
I suggest LMR-400 cable, but generally most any coax cable will do. As far as your connectors, I suggest visiting RadioShack or The Source for these, remove your existing antenna and bring it with you to determine what N-Connectors you will need.
Jan 30, 2008 | Actiontec (5GE583000-01) Router
Televison & Video Logo
75 people viewed this question
Top Televison & Video Experts
