Question about Kitchen Appliances - Others
What can i do if my element has burnt and because of it the whole delonghi fryer is not working. I have also pressed the reset button but no luck?
    Problem Solver:
  • 29 Answers
Do you have the model number?
Posted on Nov 27, 2014
SOURCE: adcraft double deep fryer
its safety switch not functioning
Posted on Jan 27, 2009
kachbibi1
  • 979 Answers
SOURCE: Euro-Pro fryer doesn't return to temp after cold food drop.
If your timer is connected to the t'stat, you may have an expensive project on your hands. However, in the meantime, I would just get an egg timer or a digital countdown timer and use it since it seems to operate fine without the timer.
Posted on Feb 17, 2009
  • 125 Answers
SOURCE: Heating element burnt out
Hello. Here is a link to the manufacture:
http://www.cecilware.com/replacement_parts.aspx
It looks like they have files with the parts listed, but are broken down by model #. To fully insure you are getting the correct part, you may want to call them.
Hope that helped, and thank you.
If you need more help, "ask me".
Posted on Apr 13, 2009
  • 125 Answers
SOURCE: fryer isn't turning on. tried reseting. still no luck
Hello. Here is a wiring diagram for your unit:
http://www.wells-mfg.com/~WELLS/WELLS%20LIBRARY/Wells%20Wir%20Diag/307298.pdf
Check to see that the thermostat clicks at or about just above on, try again the reset, sometimes it is hard to push in all the way. If that does not correct the problem, make sure your power is on, do any indicators light? It could be as simple as a burnt of wire, you will need to check the resistance of the parts to tell any more, thermostat, and hi-limit should read closed (zero). The element should read 4 to 15 ohms each, there are 3 in the tube. The relay coil should be anywhere from 200 to 1200 ohms, the contacts open. I have seen broken wires in the pivot elbow where power comes up the the element head.
Posted on Apr 19, 2009
  • 24 Answers
SOURCE: Wells 3 element commercial deep fryer. One element
Sounds like you may have a 3 phase fryer, or it is wired wrong. If you only have single phase power, it might be able to be rewired so that all three heaters are on the two main leads, this is often done at the power relay with a strap. Note the current will be much higher this way.
Posted on Jul 25, 2014
How can i fix my savourex pro line deep fryer?
If the reset button is not tripped, it is likely that a wiring connector has failed or the on-off button is defective.
Aug 18, 2014 | Kitchen Appliances - Others
Fryer heated up, then went off and want come back on. Reset button will not do anything..
You burnt the wire , check continuity with voltmetre . Replace burnt wire and or fuse .
Oct 21, 2013 | Star Manufacturing International Star...
It will not turn on
Hi Woodman22191,
I suggest that you do a couple of visual inspections first before doing anything drastic. Here's a list of things that you should check :
- Is the magnetic cord assembly properly attached to fryer socket ? - Is the electrical cord assembly plugged into electrical outlet? - Is the Power ON/OFF Switch is set to ON? - Is the Heating Element Assembly correctly assembled? Make sure Heating Element Assembly is properly installed on base. - Are you using too much or too little oil in the pot? Make sure that you use the recommended amount of oil in the oil pot.
If these things above does not fix the problem, you may need to Reset the Fryer. - Press Reset on Heating Element/Control Panel by inserting a paper clip or any small pointed object into the opening labeled RESET.
I hope this solves the problem. All the best to you. Good luck.
Dec 06, 2010 | Hamilton Beach 35030 Deep Fryer
My fryer just stopped working after frequent use, i tried replacing the cord but it is still not even responding, even to being reset via the reset button is there anything i can do, or is all hope lost...
it sounds as if the element may have burned out. here is a link to the model and manual and phone number of Euro-Pro. It would be worth your while to call them and ask their advise. Good luck
http://www.euro-pro.com/europro/faqdetail.aspx?modelno=F2015L
Nov 27, 2009 | Euro-Pro F2015L Deep Fryer
Emerilware fryer wont power up FR7009001
You can go to T-Fal website they have replacement parts the new element is $101.99. i need a new element also but thinking of buying a whole new unit and keep old one for parts
Jun 11, 2009 | Emerilware FR7009001 Deep Fryer
Fryer isn't turning on. tried reseting. still no luck
Apr 14, 2009 | Wells F-49 21148 Deep Fryer
Feb 06, 2009 | Euro-Pro F1066 Deep Fryer
Adcraft double deep fryer
Jul 03, 2008 | Adcraft DF-6L/2 Deep Fryer
Model 1068 fryer - euro-pro
You have to make sure that the control panel slide rails are correctly inserted.
I was very frustrated, and considering I did not have the packaging/receipt, was ready to toss. My Wife slid the control panel/elements out off the pan, then back in, voila!
Mar 27, 2007 | Euro-Pro F1066 Deep Fryer
Kitchen Appliances - Others Logo
41 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
