Question about Thermador Ovens
Thermadore WO-16A electric oven but the thermocouple has gone out.does anyone know of a replacement part?or at least part #?
Cannot control temperature,working electric oven.thermocoupler has gone out and looking for replacement part or at lease part number.
    Champion:
  • Thermador Expert
  • 323 Answers
I believe you mean a thermostat. Contact a distributor such as Automatic Appliance Parts at 800.323.0270
Posted on Feb 03, 2015
Amigaman
  • 248 Answers
SOURCE: Oven does not maintain temperature while cooking.
Is this a gas unit? If so you might have a weak oven igniter.
Posted on Nov 24, 2007
tborn6
  • 700 Answers
SOURCE: Replacing thermocouple on smeg oven
Look at the bottom of the oven and see if you can remove the panel, if its all one piece then take out broiler pan and look inside to see if you acan get to the pilot burner. Good Luck
Posted on Jan 11, 2009
  • 8 Answers
SOURCE: Lighting panel in my electric Thermadore double oven is dim.
The cap replacement worked....saving $250 (every 2 years !!!) I posted it on another site...now its making its way around the web....its the only value added thing I've done on the web (sadly!).
Posted on Feb 06, 2009
SOURCE: Is replacing a thermocouple in an oven difficult?
My Kenmore electric wall oven will not increase the heat to the desired setting. The electronic display holds at 100 degrees. Could the problem be the thermocouple or the electronic range control. The range control is hard to find, which is part # 318010701, made by Fridgidaire.
Posted on Jan 23, 2010
  • 106 Answers
SOURCE: Oven no gas
pilote tube could be blocked or pilot orifice set too small. check that the gas pressure is ok
Posted on Jun 15, 2010
Oven element good but does not heat even though broil workes with temp sensor
Hello Billy;
My name is Peter. I am a retired field service appliance technician.
First, your broiler is not connected to your oven thermocouple (Temperature sensor). When you turn on your broiler full load amps go into the broiler element with no adjustment.
There are only three components that control your oven operation:
1.) Heater Element - Inspect your heating element for cracks, sparking or corrosion on the two contacts on the back wall.
2.) Thermocouple - This is a temperature sensor inside your oven. It is about the diameter of a coat hanger wire. Either it comes straight out of the back upper wall or is mounted on the back wall.
It is disconnected and removed from the upper back of the oven.
You should get a meter reading of 1000-1100 Ohms if the component is good.
3.) Oven Control - The control communicates with the thermocouple and increases or decreases the amps to the oven heating element. If the thermocouple is good then the oven control needs to be replaced.
If in unsure, replace them both.
Recently, I replace a digital oven control for a friend. Sears wanted $256.00 for the control. I purchased a remanufactured oven control over the internet for $30.00.
Get the oven model number off your oven. It is on a metal tag on the face of the oven after you open the door.
Go into the following website. Put in your oven model number (on the left). You will get diagrams and parts part numbers. Record these numbers for the above components. Put the part number in your computer search engine and search best price.
CAUTION: If you replace a electrical control board GROUND YOURSELF by touching something that is bare metal. Static electricity will knock out a control board.
Water Filters Lawn Garden Appliance Parts
Jun 06, 2015 | Ovens
Find that the oven is so much hotter than the temp. says
The oven temperature can be adjusted so that the dial and true temp are the closely the same. But I need the make, model number and serial number of your stove / oven to tell you how. The number are usually on the door side. J
My oven gets warm but will not reach set temperature. Is this the element
Hello Peter;
I recently repaired a oven that would be off as much as 200 degrees. The normal operation of your oven is to rise 20-40 degrees above set temperature and shut down until it drops 20-40 degrees below set temperature, turns back on and repeats the cycle again.
Generally, there are only three components that control your oven temperature:
1.) The Heating Element - If you are getting heat your heating element may be good. To be on the safe side inspect the two connections on the back wall to ensure they are not corroded.
2.) The Thermocouple - There are several different thermocouples depending on your model and if your have gas or electric. These are easily replaced.
3.) Oven Control - Here again there are several different controls, both mechanical or digital.
I just purchased a oven thermocouple and a reconditioned digital control over the internet for under $75.00.
IF YOU HAVE A DITIGAL CONTROL - GROUND YOURSELF BY TOUCHING BARE METAL. STATIC ELECTRICITY WILL KNOCK OUT A BOARD.
So, go into the following website put in your model number and select parts. Several diagrams with part numbers will appear. Your model number is on a metal plate on the face of your oven after you open the door.
Fine your thermocouple and oven control. Copy these part numbers and search the internet for best price.
First, replace the thermocouple. If this solves your problem then return the control for credit if not install the oven control. The highest probably is you have a bad thermocouple
May 07, 2015 | Ovens
Tornado ngc oven has an F6 code. IR heats up to 1160 degrees but never says ready
unplug oven. Discharge Caps- if you don't know how to do this stop here and call a professional.
push the small red reset switch rear lower corner of oven. IR is a little higher than i like to see.
Test electrical compartment thermal-couple. located under top cover about 2 inches from the rear in center.
Test Electrical compartment cooling fan.
EC Thermocouple (P/N 700-1199)
Type K Thermocouple. Thermocouple measures the
temperature of the electrical compartment. If the
temperature within the electrical compartment is
above 158?F (70?C), the control displays F6: EC
TEMP. The control board checks the EC temperature
every 60 seconds.
Oct 26, 2010 | TurboChef TORNADO Electric Oven
How to fix F7 in turbochef
F7: Thermocouple Open
CC Thermocouple
Reads 999?F/C or
IR Thermocouple
Reads 1999?F/C
1. Check the connection of open thermocouple on the I/O control board.
If the connection is OK, verify thermocouple is not an open circuit
by using your ohm meter. The cook cavity thermocouple should
measure approximately 4-5 ohms and the IR thermocouple should
measure approximately 30-40 ohms. Measure at the I/O control board
40-pin connector.
o Thermocouple indicates open circuit: Replace defective thermocouple.
o Thermocouple OK: Replace the I/O control board.
Oct 04, 2010 | TurboChef TORNADO Electric Oven
Top oven glass in door is broken (thermadore).
Your oven model number is usually located on the rim of one of the oven doors or on the frame oaround a door. Some ranges with bottom drawers have the model number on the frame behind the drawer.
Here is a tip that I wrote about replaceing your glass....
http://www.fixya.com/support/r4391163-range_stove_oven_door_glass_replacement
heatman101
Mar 31, 2010 | Thermador C302U Electric Double Oven
Older Thermadore) fan is ALWAYS on.
check inside for the techsheet on top panel. your thermistat of fan if faulty
Feb 11, 2010 | Thermador SMW272 Electric Double Oven
Nov 14, 2008 | Thermador SC302T Electric Double Oven
THERMADORE DOUBLE OVEN NEW OLD STOCK
Thermador SCD302 upper oven preheat does not work; the heat temperature goes up very slow.
Sep 03, 2008 | Thermador SC302T Electric Double Oven
Ovens Logo
112 people viewed this question
Top Thermador Ovens Experts
Dan Webster
Dan Webster
Oloyede Monsuru
Are you a Thermador Oven Expert? Answer questions, earn points and help others
