Question about Goldline Solar Pool Control Package Gl-235 Glc-2p-a
Why is my GL235 solar heater control panel not heating the pool. The heating light is on and the power light is on. What should we do.
Our temperature control panel is lit as if it's working but water is not getting hot. Light is on solid, it is not blinking.
  • Goldline Master
  • 1,631 Answers
If water is flowing thru the panels/collectors, (look to see if the valves are opened to allow water to the collectors) if the water is flowing and it is flowing through the collectors/panels, then the water is being heated!
If you are saying the controller is set for solar operation and the sun is shining, and there is a "Demand" for heat or a "Call" for heat, and the Valve is NOT turning to allow the water to the panels, then you have a problem with either the Hayward/Goldline Controller or the Valve Actuator.
Good Luck
Posted on Nov 27, 2014
How do I get my GL235 Solar Heating Panel (Goldline Controls) to heat. It is not heating the pool even though the control lights indicate that the heater is on.
Good Luck
Nov 15, 2014 | Pool & Spa
Need to replace gas spa heater. Is there a combination gas and solar spaheater
You may actually use any pool heater with a solar water heating array. I do not however know about any that come as a package deal. You will need a solar array, a solar controller, a actuating valve to hook to the solar controller, and a new bypass assembley for the plumbing system. All of this is made by manufacturers such as : Jandy, Pentair, Raypak, Lasco, Buderus, Hayward, etc....
Feb 16, 2011 | Solar Rheem Gas Fired Pool & Spa Heater...
Pool heater recommendation
they make heat pump pool heaters. it works like an a/c but it heats. only uses electric. http://www.solardirect.com/pool_heaters/heat_pump_pool_heater/hpph.htm
also they have solar panels for pools. another good thing for a pool is a solar cover you just cover it when you are not using your pool.
May 29, 2010 | Jandy Lite2 LG400 Ceramic Compact Heater
How to setup a diverter valve for above ground
If you want all your water going thru the solar heater before re-entering the pool, you'll need to plumb the end of your filter to the solar heater, then the water exiting from the solar heater would go where the filter hose did go back into the pool. Hope this helps.
May 25, 2010 | Fafco Deluxe Solar Panel Heating System 1...
My pool isn't heating much even in extreme heat.
if you pump is dual speed,try turning to lower speed and water will stay in solar system longer,thus having a higher heat gain
Sep 02, 2009 | Solar 2 PANEL DELUXE SOLAR HEATING SYSTEM-
Filter clicks, but won't turn on. Pool lights
put your aqualink into service mode. then select components manually this will override any pre-programmed options
Jul 21, 2009 | Jandy Aqualink Rs4 One Touch Control...
Same Issue
the pump stop so will not drain spa dip # 4 may turn off for the delay but not sure if the pump will still turn off since this is new tech. good luck
Jul 05, 2009 | Jandy Aqualink Rs4 One Touch Control...
Goldline Solar Pool Control Package Gl-235 Glc-2p-a Logo
235 people viewed this question
Top Goldline Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Goldline Pool and Spa Expert? Answer questions, earn points and help others
