<!-- from fixya rte -->How do I take the your story laminator apart - Office Equipment & Supplies
I have a GBC Ultima 65 Laminator and the lamination is not adhering. The materials I am laminating are coming apart.
Are you letting the laminator reach operating temperature? If the ready light is on and it is not getting hot then you may have a problem with the temp. sensor. Put your hand near, but not on, the top roller to feel if it is getting hot. Don't touch the roller in case it is hot. If it is getting hot then wait for the ready light to illuminate(about 10 minutes).
Feb 14, 2017 | Gbc Office Equipment & Supplies
How do I get laminating pouch out that has rolled up inside the machine?
pull the machine apart and remove the melted plastic from the roller
basically laminators are so cheap the it is quicker to junk it and get a new one
Feb 23, 2016 | Office Equipment & Supplies
Reassemble after having to take apart?
did you get it fixed, I had the same problem but with a different part , I know where your part go's
1st without screw holes go's in the Rear where the laminate comes out and the next one goes on top email me if you didnt fix it yet , I can open mine and get pictures Email me here
scolt@tampabay.rr.com Subject Laminator APL-330U
Oct 22, 2014 | Royal Sovereign 13" APL-330U Hot & Cold...
Scotch Thermal Laminator not heating up.
well it sounds like you may have cut a wire or pull one somewhere. i would go ahead and take it apart carefully and check everything. may have unplugged something hopfully! let me know whwat happens!
Jan 31, 2014 | 3M TL902VP Scotch 9" Thermal Laminator...
Laminator 17466 I need to take my laminator apart.
Can you please provide a model and brand for the device in question?
Oct 22, 2013 | Tools & Hardware - Others
What are the advantages of laminate flooring over hardwood flooring?
First, you can get the exact visual design that you wanted and it will cost you considerably less. Second, laminate flooring can be installed above and below the grade unlike hardwood flooring. Moreover, the laminate flooring is installed without using any nails or glue which make it much easier to it yourself. Furthermore, laminate flooring is extremely durable, easy to maintain and can be replaced easily.
Feb 06, 2013 | Building Materials
I have a xerox laminator and it will not feed
Unplug the machine. Then try to look, using a flashlight, if there are any obstacles that may interfere with the feeding. try to gently tilt the machine and try to remove any obstructions. If you can't see anything, try to force something through the feeding path and see if something is stuck in there.
If this doesn't work, them you might want to take it apart.
Nov 16, 2012 | Xerox Staples XRX-LM1910 Laminating...
69 people viewed this question
k24674
