Question about Maytag MFD2561HE Stainless Steel Bottom Freezer French Door Refrigerator
No water from dispenser Matag New filter solenoid valve working, tube to dispenser seems to be blocked
  • Maytag Master
  • 744 Answers
Hello Hans;
My name is Peter. I am a retired field service refrigeration technician.
There could be several areas that would effect your water dispenser not working:
1.) When you depress the water dispenser do you hear a 'Click'? If not you have a bad water dispenser contact switch.
I would send you a diagram but I do not have your model number.
2.) In the lower back of your fresh food section is your water dispenser water tank. At times this can freeze near the freezer section. Look in the lower corner of the freezer & your fresh food section for ice build-up.
3.) You could have a bad water filter. This does happen often. Remove the water filter and test you water dispenser.
4.) Do you have water leaking out of the bottom of your dispenser door? If so you have a split in the tubing in your water dispenser door.
5.) Is your ice maker working? Often the water valve to your refrigerator becomes plugged up and you do not get sufficient water pressure 60 PSI to operate your water dispenser solenoid valve.
Posted on Nov 16, 2014
4 Suggested Answers
SOURCE: Where do I find the ice maker inlet water valve or solenoid? The valve on the back of my fridge has only one hose going to both the water dispenser and ice maker and the water dispenser works fine.
Since there is water that flows to the water dispenser, the water valve is working. Now, there's a spout that water flows from to the icemaker tray. Look for it. It's located on the back wall inside the freezer and maybe behind the icemaker tray. Check and see if it's frozen. If so, defrost your freezer by turning the temperature gauge to off position. Wait a while until it's defrosted, then turn it back on.
Next, make sure that the metal wire is in down position.
If that doesn't work, your icemaker maybe defective and needs replacement.
Posted on Nov 02, 2014
  • 66 Answers
SOURCE: Ice maker not making ice, water dispenser makes a loud clicking sound when filter is in.I already replaced the dual water valve and tried a new water filter.
The gear that drives the mechanism that moves the ice out and allows fresh water to come in is damaged. In some cases the ice tray needs to come out so the ice cubes in the system can be removed by letting them actually turn back to water. Once you have cleaned it of old ice, try it again. Most likely a waste of time though.
What I have done to save money is find an old refrigerator someone wants to toss and pull the ice maker out. Chances are they have the same plug and wiring. Better if you just go get a new ice maker unit from where they sell parts for your refrigerator. It is easy to remove. usually about three screws or so. about two on top and one or more on the bottom side.
Posted on Jul 09, 2012
  • 105 Answers
SOURCE: water dispenser won't dispense. Keeps trying to
Best of to call a certified repair company such as Sears.
Posted on Mar 20, 2010
Everything normal on my GE Profile Model PFSF6PKWBBB French door bottom freezer refridgerator except the water dispenser just quit dispensing water. Is it frozen? How do I fix it?
The paddle that you push the glass against to dispense water activates a microswitch. Sometimes this switch can break off it's mount and drop away from it's intended position. The microswitch operates a solenoid valve near where the water line enters the back of the fridge. Then there's the wiring in between them. The water line doesn't go through the freezer. It runs through the refrigerator in a coil of tubing then into the door of the dispenser. Check the paddle switch, the water solenoid and the wiring and you'll find the reason it doesn't work
Mar 05, 2016 | GE Refrigerators
How to know the water pressure is wright for Samsung ice maker imc701
Used machine? If new seller needs to help. If under warranty check the MFG customer service number.
If used this may be the reason it was sold. If Used there is a possibility the water filter needs to be replaced. Yes they'[re expensive, but they can interfere with the process. Does the Cold water device work? Is there plenty of flow? If so it's not filter or pressure. If it barely comes out, then it's probably filter and may be the ice maker issue.
Feb 27, 2015 | GE GFSS6KKXSS Bottom Freezer French Door...
My whirlpool side by side ff water dispenser water not recieving water to ice or water dispenser .i think it's frozen
Check to see if there is a filter in the water supply line, if there is it may need service, if no filter then the solenoid valve may be clogged with sand or other material, unless you are handy about this kind of stuff, i suggest you have a professional look at it. have him/her check the supply lines they have been known to break and cause all sorts of trouble.
Dec 21, 2014 | Whirlpool Refrigerators
Water dispenser on Frigidaire FRS6R5E refrigerator is not working but ice maker is working fine.when i open the filter area & press the water dispenser button water comes out from that area & when i put in...
At the back cover of the fridge you will find a double electric valve. The easy way to find valve is to follow water supply tube to your fridge
Unplug fridge and check with multimeter if one of the coils burned out and should be replaced. Make sure you close water shut off valve before removing solenoid. Good luck
Nov 14, 2013 | Frigidaire FRS6R5E Stainless Steel Side by...
My Amana french door/bottom freezer is leaking water. Did the procedure with hot water the drain in back of the freezer, although it seemed clear of ice. That didn't help. The leaking stops when I...
Two possibilities:
1. A cracked plastic tube. These will leak whenever there's a call for water - either the chilled water dispenser, or re-filling the icemaker tray (two seperate tubes). Pay particular attention to anywhere the tubes are clamped to the chassis; anywhere they're routed near or under the refrigeration unit; and near the solenoid valve - especially if there's a tight loop in the tube there.
2. A bad (leaking) connection where one of the tubes exits the water valve. Again, these will leak whenever the valve is activated.
Those plastic tubes don't last forever. I've replaced many of them for the same symptoms. They're known to simply deteriorate with age.
Manuf's make good money selling replacement tubing kits.
Aug 15, 2011 | Amana AFB2534DE Bottom Freezer French Door...
We own a Kenmore Side by side refrigerator, model #253.54622406. The water has stopped coming out of the water dispenser in the door. What could cause this?
if the ice is opperating normaly listen for a click or humm from the water valve if nothing it may be the switch first check for power at the valve when switch depressed if present replace the valve if valve has power and you hear it oppening and closing it or the line to the dispenser may be plugged. if no ice either check the water supply to the fridge and the filter in the fridge if there is one.
Mar 08, 2011 | Kenmore Refrigerators
How do you clear a solenoid valve blockage? Our Oscar pumps water without a problem and the steam works. As soon as I put coffee in the holder and tamp, even a little, nothing is dispensed and the water...
  • be sure from where it leaks? 1> solenoid valve the discharge way 2 > security valve of system.
  1. if it leaks from solenoid valve you must change the mechanical part of valve
  2. security valve of system may need to be repaired , after repair you must set the valve to start leaking at 11bar.
if it is solenoid it can be from the un-cleaning with detergent&blind filter, to provide longer life of new valve you should purchase them and clean with them periodicaly.
Feb 12, 2011 | Nuova Simonelli Oscar Coffee Maker,...
Water dispenser and ice maker don't work
You have a bad water filter housing. Be sure to turn of the water to the refrigerator before replacing this part. Replace the filter at the same time.
Apr 30, 2017 | Whirlpool GS6NBEXR Side by Side...
Water dispenser suddenly stoped working. Ice dispenser working
check the water line fron filter that continues on to water dispfrom icemaker, also a bad water disp solenoid or no pwr to water valve disp solenoid could be a problem,when you try to disp water can you hear a click from the solenoid operating to let water out?
Aug 16, 2009 | Frigidaire FRS23KF7AB Side by Side...
Water does not dispense from the door but there is water to the filter fitting
connect the water line in to the solenoid [with out the filter] to see if u dispensing water
Dec 01, 2007 | GE Monogram ZISx420DR 42-inch Side by Side...
Maytag MFD2561HE Stainless Steel Bottom Freezer French Door Refrigerator Logo
316 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
