Have a 2006 cougar travel trailer with a 13,500 btu dometic duo therm (dometic part # 59516.531) I am currently living in the trailer and using ac all the time..About two months after i bought it ( ju
Thats about all i can think of, im not sure how to test the capacitor, any help with that would be great..
  • 30 Answers
To check capacitor, take it off and male a assembly with a 100W lamp in series with the capacittor, if the lamp turns on good, it means you have good chances that the capacitor is faily good condition
Or use this test circuit. Don´t forget security procedures!!
Have a 2006 cougar travel trailer with a 13,500 bt - 25284951-hmnvhhaf51b5bt1holaf200l-1-0.jpg
Posted on Nov 15, 2014
4 Suggested Answers
  • 17 Answers
SOURCE: Duo Therm AC/Heating not working at all after tripped breaker.
I had to get on the roof of mine, remove the cover and manually spin the fan. Add a little oil to the shaft where it goes thru the bearing. All of this is done on the roof side. Mine required this procedure every spring. Duotherm realizes they had a problem and have since corrected it but they don't deal with all of their customers that had the original problem.
Posted on Jul 20, 2009
  • 69 Answers
SOURCE: Dometic Duo-Therm air conditioner: keeps tripping
First clean the condensor with air blower or water pump and clean the filters.If the same problem persists there is a choke up in the refrigeration piping, cut from the discharge side and suction side flush the system with nitrogen, replace the filter drier and choked capillary if it is a capillary system, brace back the discharge and suction piping to the compressor again, leak test with nitrogen, evacuate the system charge refrigerant and start the system.
Posted on Aug 15, 2009
motor1258
  • 6674 Answers
SOURCE: My unit was working fine until 3 days ago when the
High amp draw can be caused by a few different things, so first check that incoming voltage to trailer is sufficient. (115 volts) Not unusual for some parks to install more hydro hook-ups on a feed line, and when all are up and running, your incoming voltage could be decreased. If your o.k. that way, then I'd start looking at the compressor circuit of your ac, in particular, the compressor start-up capacitor. The capacitor basically stores electricity and boosts it to higher voltage for compressor and fan start-ups to reduce current draw that will trip the breaker. Please have a knowledgeable electrician, or RV tech check this for you, as a capacitor can give a real good high voltage (possible fatal) shock, even when power is off to unit. I also suspect that the start relay has shorted (welded) itself due to high amp draw situation, and that is reason it comes on by itself.
Posted on Jul 10, 2010
Fan run compressor run but no cold air
DuoTherm by Domestic-Fan runs, no cold air - iRV2 Forums
www.irv2.com > ... > RV Systems & Appliances
Jan 22, 2012 - 12 posts - ‎4 authors Duo Therm by Dometic 13500 BTU air conditioning with ducting, furnace. I. ... If the fan runs but no cold air and the compressor feels like it is ...
A/C just stopped blowing cold.....any ideas??! - RV Forum
www.rvforum.net > ... > RVing message boards > Trailers & Fifthwheels
Jul 27, 2008 - 23 posts - ‎6 authors We have run it continuos like this before without any troubles. Thanks for the help! ....When you switch the AC unit on, the fan runs, but the compressor doesnt fire up. You used to be able ... You can find Dometic here. Logged. Dometic Duo Them Air Conditioner Cycles
Jul 21, 2015
Dometic SL-135 A/C problem
May 29, 2012
Dometic ac compressor runs but fan does not on auto
Jun 5, 2011
AC blower runs full time w/ AC on
Sep 2, 2009
More results from www.rvforum.net
Nov 18, 2015 | Dometic 705600009 A-284, SMX II Retrofit...
Ac compressor runs but will not cool
check thermostat, replace capacitors amp compressor to be sure its running if not relay module issue.
Aug 08, 2015 | Dometic 651815 Duo Therm 13,500 BTU...
Heating & Cooling Logo
121 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
