Question about Lennox Comfortsense 5000 L5711U 1H/1C Touch Thermostat
I cant get the thermostat to go up past 70. How do I fix this?
    Sergeant:
  • 352 Answers
BUY A NEW THERMOSTAT
Posted on Nov 15, 2014
My furnace runs to operating temp on thermostat shuts down then within 30 seconds try's to cycle back on three to four times. What would cause this.
Some thermostats have a swing setting that can be adjusted. A swing is the setting when you want the furnace to stop or start from the desired set point. For example, you set your thermostat at 70 and the swing is set at 10 degrees. Then the furnace will turn on 5 degrees below 70 and shut off 5 degrees above 70. Check you thermostats manual if it has this option.
Mar 15, 2016 | Heating & Cooling
My robertshaw 9620 thermostat is stuck on 70 and i can not change setting frim temp or time.
Here's how I fixed my Robertshaw thermostat that was stuck at a 70 degree reading for almost 2 monthes. When I turned on the air conditioner or heater it wouldn't stay on. I removed the cover panel and dusted off the inside which the guy at local hardware store suggested. That didn't work. Then I noticed the words "reset" right on the green circuit board on the left side. There's a very small silver button. I pressed on it and everything reset. Less than a minute later the thermostat is reading the correct room temperature. Now my air conditioner and heater are working properly.
Mar 16, 2014 | Robertshaw 9620 digital...
Amana Furnace
The furnace may have a cracked heat exchanger.
Dec 19, 2013 | Heating & Cooling
It is increasing temp 2 hours before scheduled
Most programmable thermostats are "smart stats" which use a programmed algorithm base on a preprogrammed P (proportional) I (Integral) D (derivative) Loop. To make a long story short, the programmed temperature will make the room that temperature by the programmed time. This is based on how long it has taken it in the past to bring the room up or down to temperature. So if your setpoint is 70, and your set time is 7 AM, then the furnace or AC will bring the room to that temperature by the set time...not start at the set time.
Dec 04, 2013 | Heating & Cooling
I cant get my thermostat to go on from 40 degree--to 69,but it will go on from 70 -- to 80
mcdevito75 here, If this is at an initial Start up it"s normal, if the unit thermo will not kick in at 65--69 after the unit has been running a while, you may need a re-charge of freon.
Aug 19, 2010 | Honeywell Programmable Thermostat Heater
The car over heats when get past 70 keep having to fill radiator up every morning and cant see a leek any where
Im afraid you have a blown head gasket,for a quick fix you might add some copper seal with water glass in your radiator,and that might help you for a while,
Jul 04, 2010 | Cars & Trucks
Cant get the settings to go past 70
Set the time and day and make sure you are in the "F" range.
Dec 30, 2009 | Honeywell Electronic Programmable...
I CANT OPEN MY SENTRY FIRE-SAFE MODEL:DS3431 SAFE. I KEEP TRYING TO DO WHAT THEY SAY DO TURN DIAL TO ZERO, TURN KEY ETC; NUTHING IS WORKING. CAN U HELP?
Make sure that the key barrel is all the way out. Then replace this example code with your factory code and try it
Example combination: 70-55-05
  1. Do two rotations to the left stopping at 0.
  1. Do two rotations to the left (Anti-clockwise) on the third time past 0 go to your first number.
So – 0 to 0, 0 to 0, 0 to 70
  1. Do one rotation to the right (clockwise) on the second time round stop at your second number.
So – 70 to 70, 70 to 55
  1. Turn directly from your second number to your third number heading to the left.
So – 55 to 05
  1. Push down the handle.
Dec 13, 2009 | Sentry Fireproof Safe
Temperature gauge going to the red when driving
put some water in , find out if you have a leak , ie, leaking water pump or pipe , is it overheating , is the oil got white sludge under the cap , a sign water is getting past the head gaskett , check out these items first
Nov 20, 2009 | 1998 Ford Escort
Lennox Comfortsense 5000 L5711U 1H/1C Touch Thermostat Logo
Top Lennox Heating & Cooling Experts
Lawrence Oravetz
jeff5may32
tractorman44
tractorman44
Are you a Lennox Heating and Cooling Expert? Answer questions, earn points and help others
