Question about Hotpoint Aquarius WD640 Front Load Washer/Dryer
Bypass the timer switch - Hotpoint Aquarius WD640 Front Load Washer/Dryer
    Genius:
  • Hotpoint Master
  • 2,494 Answers
Fit new timer switch to avoid heating if you bypass it it will go flat out and burn out the element.
Posted on Nov 15, 2014
Can I bypass the power switch on a Devilke YL 2120 dehumidifier as I am putting it on a boat for the winter and it need to activate via a timer plug
leave it switched on and use a timer at the power point to switch it on or off according to the times you set
Oct 18, 2015 | Dehumidifiers
Legrand Circuit Breaker Wiring
When fixya appears on 1st page of search for product, then either the product number is not right or product is older or product number is not exact.
What voltage are you using?
What is a Legrand 060-12?
What is a C2 Rcd?
What controls the auto function overnight... a timer?
Which timer...?
Probably a change in wiring at timer will work, but then the timer buttons might not have any affect for override on-off.
You could put in a DPDT bypass switch or bypass timer... that connects to incoming wires before the auto timer and then connects to wires after timer.
Nov 17, 2013 | Electrical Supplies
How do you wire the ecm 175 bypass timer
http://www.icmcontrols.com/Prodimages/ig_LII271-1.pdf
The power to the equipment that will be running goes onto terminals 2 & 3.
Come off terminal 1 to bypass the switch (such as a pressure switch).
Use the time setting from the old timer.
When equipment is turned on, the Icm allows power to go around the (pressure) switch for the set period of time. After the timer times out, power goes back to the pressure switch and by now the the pressure switch controls.
Gary
Sep 02, 2011 | Icm 175 Bypass Timer
Whirlpool washer lsq9010pw -Timer not advancing
you can also check to see if the timer motor is good. not a good idea to bypass. if the presure switch was bad it would not stop filling up.
Aug 22, 2009 | Whirlpool Washing Machines
Maytag has a recall for compressor relay update possible fire hazard stated on notice,tech comes out and does update,now fridge wont cool. tech states that adaptive defrost timer is bad,he jumped wires...
Check the cold control thermostat for continuity.(off/on switch)
When he bypasses the wires at the board ,he also bypasses the thermostat control.
Apr 08, 2009 | Refrigerators
Tryin to bypass electronic timer on inglis oven
you have to find the main live going into the timer, and the live from the timer to the oven switch, and firmly, and safely connect then together..
Jan 31, 2009 | Jenn-Air JJW8527C Expressions Collection...
Maytag performa dryer quit working
Check your breaker first and then the wiring. Check power coming from the timer next. With a load and resistance that you had, you could have tripped one of the breakers.Since you have bypassed the thermal fuse, it probably is the timer switch.
Jan 26, 2009 | Maytag PYE2300AY Electric Dryer
WON'T COME ON AT ALL.
you have not said anuthing about ohming out the start knob,and have you checked both legs on the power cord are getting 120 volts each?let me know what you find-mike
Sep 09, 2008 | Whirlpool LER4634J Electric Dryer
Hotpoint Aquarius WD640 Front Load Washer/Dryer Logo
124 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
