Question about Hotpoint Dryers
Can i bypass the timer on my hotpoint aqurius dryer
My timer on the model has broken so can i bypass the timer
    Sergeant:
  • Hotpoint Expert
  • 448 Answers
No timer controls everything turns it off on and controls heat to turn on and off stats are there for temp reading and cycling
guess if you want to burn your house down it can be done but why
buy the timer
Posted on Mar 24, 2015
Healeyman
  • 1198 Answers
SOURCE: Hotpoint Dryer belt broken
http://www.pcappliancerepair.com/model-display.php From what I see, you have to remove the front, and maybe the drum to get at the belt. See what instructions come with a new belt.
Posted on May 12, 2009
dniro592006
  • 121 Answers
SOURCE: Timer doesn't move, otherwise dryer is fine.
Timer needs replaced
Posted on Jun 12, 2009
apart4u
  • 213 Answers
SOURCE: No hot air blowing - cold air only. Hotpoint
We have a full video library on appliance repair video’s
Common faults -
1 The heating elements can fail (meaning open circuit)
2 There are cut-outs (T.O.C's) that might need resetting
3 The thermostats (stats) can trip out or burn out (meaning open circuit)
4 Modern tumble dryers also have sensors and pcb's (Printed circuit boards) these have programs that can fail and circuitry although most should produce an error code showing you were the fault is.
5 Faulty connections and burned wires may also be the fault.
You-Tube video "sfGInKA3yp8" placeholder (do not delete)
Posted on Jan 08, 2010
barkencoa
  • 3463 Answers
SOURCE: can't work out how to fit new belt to my tumble
You need to remove the rear panel the top console panel,,and then remove the whole cabinet to gain access to the drum and belt.
Then you need to release the front panel at the top to enable you to fit the belt.
Hope this helps.
Posted on Jan 19, 2010
thompsonfix
  • 37 Answers
SOURCE: THE WIRES MIXED UP ON MY TUMBLE DRYER HOTPOINT VTDOO TIMER
In most appliances I've had apart there is a stick plasic envelope stuck somewhere inside the cabinet or the control panel that contains the wiring diagram.
Posted on Nov 24, 2013
Is there a way to bypass timer?
Sure, but why? The timer is hooked up to a cam(s) that sets up the different operations of unit. Without the cam working about all you will do is maybe get a spinning motor at best.
Replace the messed up timer assembly.
Nov 26, 2015 | Hotpoint Dryers
Bypass the timer switch
Fit new timer switch to avoid heating if you bypass it it will go flat out and burn out the element.
Nov 15, 2014 | Hotpoint Aquarius WD640 Front Load...
Hotpoint TVM572 timer is faulty
It is important not to open the door of the dryer if it is still running. The timer controls the cooling cycle otherwise the clothes will get damaged if kept on hot.
It is very likely the timer contacts are frozen at some point and the timer will need some attention.
It is not hard to locate it. I cannot find the actual parts drawing for your model (it is good you have provided the full model details). But to help you locate the part I have found another Hotpoint model that may be similar to yours. Check this drawing to see if the front panel is similar.
Item 100 is the timer.
HOTPOINT Electric Dryer Backsplash blower moto Parts Model NWSR483EB1WW
The actual timer for your model looks like this.
Hotpoint TVM572P Timer
As the clothes are not getting burnt or singed I will assume the thermostat is ok and keeping the temperature within the range.
Aug 07, 2014 | Hotpoint Dryers
Hot point dryer drum does not turn, but the dryer will heat?
That might be bad glides on the front. Newer models have glides on top of the drum while older models have glides on the bottom. Both are easily replaceable. The belt might be broken because of the glides.
Not all hotpoint dryers are built the same but I made a few videos of these dryers to give an idea how to get into them:
More from my blog: Hotpoint dryer repair
Oct 26, 2012 | Dryers
Need to know how to reconnect the timer on a hotpoint dryer
As you do not state the model number of dryer, it is virtually impossible to be of any help here, as there are literally hundreds of different models of Hotpoint dryers produced over the years.
I suggest you go to the Hotpoint web site and see if they can help.
Feb 02, 2010 | Hotpoint Dryers
Can't work out how to fit new belt to my tumble dryer it's a hotpoint aqurius dryer duluxe TL22.
Hope this helps.
Jan 19, 2010 | Hotpoint Dryers
My aqurius WD420 shows that the door is locked. So i can't open it........
If the door will not open normally, then the only solution is to remove the top cover, and force the door open from inside the washer at the front
Jan 17, 2010 | Hotpoint Ariston Aquarius WD420 Front Load...
No hot air blowing - cold air only. Hotpoint Aqurius condenser dryer.
Common faults -
Jan 02, 2010 | Hotpoint Dryers
Hotpoint aquarius ctd00 condensor dryer drum not turning in reverse direction, belt seems to be ok
The reversing tumble action is controllerd by the timer, so it could be contacts in timer.
It is useable running in one direction.
Check for loose or broken wires to motor as well.
Hope this is off some help to you.
Dec 07, 2009 | Hotpoint Dryers
How do I remove/clean the filter on my Hotpoint Aqurius condenser drier?
There are 2 filters to clean on this dryer.
1 is at the bottom front left, pull all the way out, and wash clean under running water, quite in order to do this.
The second one is at bottom front right, again pull out to clean, but do not use water on this one.
Some dryers also have one located inside the door opening, pull out to clean if yours has one.
Please leave feedback.
Thanks
Nov 13, 2009 | Hotpoint TDC32 Electric Dryer
Dryers Logo
99 people viewed this question
Top Hotpoint Dryers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Dan Webster
Dan Webster
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
