Question about NetGear N600 Wireless Dual Band Router
We had a power outage and now my netgear router is not working exede said my firm wear needs updated how do i do that have called net gear 5 times and keep getting the runaround. i bought the router l
We had a power outage and now my netgear router is not working exede said my firm wear needs updated how do i do that have called net gear 5 times and keep getting the runaround. i bought the router less than 2 months ago can you help me?
  • 3 Answers
Hi
Do you mean it doesn't power on or won't connect to the internet?
If it powers on OK do the lights flash as described in the manual
If the router worked before why should you need new firmware, doesn't make sense.
Posted on Nov 16, 2014
  • 53 Answers
SOURCE: xbox 360 netgear router
that happens alot when one or more device (for instance, the xbox 360 and a cpu) are trying to use the same ip address make sure you have the xbox 360 and all other devices (cpu's/printers) that are connected to the router set to aquire ip address automatically
Posted on Feb 05, 2009
  • 9 Answers
SOURCE: light keeps flashing orange on
all i can think of is reconfigure
Posted on Mar 11, 2009
redhaze89
  • 854 Answers
SOURCE: Cannot get my Netgear WNR834B router to see the 'net
Here are some troubleshooting steps that I suggest you try:
1. Check physical connections.
a. Connect the modem to the Internet port of the router. The Internet “i” LED on the front of the router should light up.
b. Connect the computer to one of the four LAN ports (i.e port 1, 2, 3 or 4) on the back of the router. The corresponding port light where you connected the computer should be lit up.
2. Access the router's web-based utility.
a. Please open any web browser like Internet Explorer or Netscape Navigator.
b. Connect to the router by typing http://routerlogin.com/basicsetting.htm or http://192.168.1.1 in the address field and click Enter or Return key.
c. A window will prompt for a user name and password. By default, the user name is "admin" and the password is "password".
Note: If you were unable to access the router's web-based utility, you may reset the router to restore the settings to factory default.
To reset the router:
a. Please push the reset button at the back of the router and release after 30 seconds.
b. Unplug the power adapter for 10 seconds and then plug it back in.
3. Configure the router.
Since your Internet Service Provider is using a cable connection, please follow the steps below:
a. Click on Basic Settings under Setup tab.
b. Select No for Does Your Internet Connection Require A Login?.
c. Scroll down on the center page and look for the Router MAC Address section. Set it to Use computer MAC address and click on the Apply button.
4. Configure the wireless settings.
a. Click on the Wireless Settings under Setup.
b. Change the SSID to any unique name.
c. Scroll down, look for the Security Options settings and select WEP (Wired Equivalent Privacy).
d. Set the Authentication type to "Automatic" and the Encryption Strength to "64bit".
e. Leave the Passphrase field blank, select Key 1 and enter a 10-digit number.
Note: The 10-digit number you typed in the key 1 will be the password or network key for the wireless connection.
f. Click Apply button to save the changes.
g. Go to Router Status under Maintenance tab and check if there is an IP address under Internet port. If it's 0.0.0.0, do a power cycle.
5. Power cycle.
a. Power off the modem, router and computers.
b. Turn on the power of the modem first and wait for it to initialize, the lights to stop blinking.
c. Power back the router and the computers. Check if it will be able to get online.
If you have wireless computers, you can connect them wireless to the router. Kindly follow the instructions below:
6. Connect wireless computer to the router.
If you are using Windows XP with Service Pack 1, please follow the steps below:
a. Please right click on the Wireless icon on the right lower end portion of your computer.
b. Then click on View Available Wireless Networks.
c. Click on the Advanced tab.
d. Please delete all the preferred networks then click on OK.
e. Right click on the Wireless icon again and click on View Available Wireless Network. Please select your network and click on Connect. It will ask you for the network key.
f. Please type in the network key and then confirm it. Network key is the password you type on the key 1 of the wireless settings of the router.
g. Make sure not to enable IEEE and then click on Connect.
If you are using Windows XP with Service Pack 2, please follow the steps below:
c. Click on the Change Advanced Settings.
d. Click on the Wireless Networks tab remove all the preferred networks then click on OK.
e. Right click on the Wireless icon then click on View Available Wireless Networks.
f. Select your network and click on Connect.
g. It will ask you for the network key. Type in the network key and confirm it. Then click on Connect. Network key is the password you type on the key 1 of the wireless settings of the router.
If you are using Windows Vista, please follow the steps below:
a. Click Start then select Connect To.
b. Connect to a network window will show up.
c. Select your wireless network and click Connect.
d. It will ask you for a network key. Type in the network key and confirm it. Then click on Connect.
From the above configuration, please check if you can now access the Internet.
Posted on May 02, 2009
SOURCE: Can't obtain IP - Net Gear WNR2000 router
Try to open the Router page using "ROUTERLOGIN.COM" in IE and go to WAN Setup option in which u can see Disable SPI Firewall (check the box), also reduce the MTU Size to 1400 or 1390
Posted on Sep 16, 2009
Danny1006
  • 136 Answers
SOURCE: I have a Netgear router, net light stays orange can't get online
I understand that you were not able to get help with the previous solution.
Here is a way to reset the router
Look behind the router where the cables are connected
You will find a hidden button which is the reset button
Push and hold it for 1min using a paper clip
Then follow this link to get help to update the settings on the router
http://kbserver.netgear.com/pdf/wgr614v6_ref_man_20Apr05.pdf
NOTE: Have all details related to your ISP.
Since you have a PPPoE connection you will definitely have a username and password
Have these details and follow the instructions in the file form the link
Please Rate
Thanks
Posted on Jan 27, 2010
Testimonial: "Great help!! Fixed my problem with exactly what to do & what to read. I'm very happy and thankful!"
I have a Netgear WNR2000 v4 router. We recently had a power outage.Power came back on in 5 seconds.The cable modem is fine,however the router ONLY shows me a solid green light for power, nothing else.
I would just do the reset, this should allow you to access at factory defaults. (I hold button in for 10 sec).
A solid green (power?) light is good
LAN ports should only light if connected
WiFi port should light if set to active
Mar 02, 2015 | NetGear Computers & Internet
My estar beauty tablel will not login
Sir
You need to update your framework from cruztablet. com . Because some time different version of framework cause trouble. so I suggest you updated it that it powered your Cruz T410 back up it connected to my router automatically.
i Hope Your Netgear Router issue Resolve By Now,
In Case You Still Need Online Netgear Router assistance Then call follow Us On for:
Netgear Support
Apr 02, 2014 | Computers & Internet
Router not working, blinking wireless light, no internet light
Probably, this is because of Firmware Issue, There are firmware updates for most of netGear routers and they have to be done.
If you do these updates, you will have to write down all details of you networ/router manually and once the update is complete, you will be manually setting up the router,
IF you have the netgear support no. and your router is still in warranty, contact netgear and ask them help you do these updates..
the website with the updates are
http://kb.netgear.com/app/products/family/a_id/1297
Jul 03, 2010 | NetGear WGT624 Wireless Router
Wireless light out after long power outage,
router might have taken a pwr surge when electric was restored.
Oct 17, 2009 | NetGear WGR614 Wireless Router
Wndr 3300 net gear router wont work with hn 9000 hughes net modem
I went to the Hughes web site to check out the modem. They say it is also a router. I think you will have to disable the router abilities of your WNDR 3300 Net Gear Router.
Get into the Netgear setup by loging on to it.In its WAN setup select Static IP Address and set the Static IP Address to the same as the hughes modem, except for the last number which should be about 50 greater. IE: Hughes 192.168.12.1 and Netgear 192.168.12.55.
In the DHCP setup, disable the DHCP Server
In the Wireless setup, Give your network a name is SSID. You should also set up security to keep others off you internet connection with a WEP key.
I hope this helps.
May 30, 2009 | NetGear WNDR3300 - RangeMax Dual Band...
My Net Gear WGR614V6
IF the router stop working the first thing that you can do is to reset the router by pressing the reset button for 15 seconds while the power is ON then after that unplug the power for 5 seconds and then Run the Installation for the router to reconfigure it back but if you don't have the CD you can contact Netgear support for that so they can walk you through with the process....
Sep 28, 2008 | NetGear WGR614 Router
Constant Loss Of Broadband Link And Internet
do one thing update your firmware of your device and upload in the device after then you change your power adapter. after then you have same problem then you call the isp people.
Jul 02, 2008 | 2wire 2700HG-B Router (2700HGB)
Netgear614 to compac pc laptop
hello!
-- who is your internet service provider
-- what is the operating system of your computer?
-- is this working fine before or is this a brand new router
you may try this and see if this help solve your problem
Step 1: Shutdown the computer.
Step 2: reset the router while power on then Unplug the router’s power cable.
Step 3: Unplug the Broadband modem’s power cable and wait for 30 seconds.
Step 4: Plug in the Broadband modem’s power cable and wait for its lights to appear stable.
Step 5: Plug in the router's power cable once the modem’s lights appear stable.
Step 6: Power on the computer on and configure the router settings Step 7: test the Internet connection.
May 04, 2008 | NetGear WGR614 Wireless Router
I like to sset up net gear router
If you see two computers, that means your computer is accessing the internet. Give it more time, and if the problem continues, call your ISP.
Feb 02, 2008 | NetGear DG834G Router
NetGear N600 Wireless Dual Band Router Logo
88 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
