SOURCE: water filter replacement
I have the same problem. I did change the filter located on the bottom front panel of the refrigerator, but the red light is still on and NO ice. I can't figure it out and I know if I call a tech, its a 300.00 bill. Frustrated.
SOURCE: I need to bypass a filter in RS267LASH Samsung refrigerator
From the Samsung Online FAQ for my RF266AASH
Can I Use the Water Dispenser Without a Water Filter?
The water and ice dispensers will work without an AquaPure water filter installed.
The water filter housings are designed as rotary valves that allow the water
to bypass the water filter whenever there is no filter or the filter is not
in the lock position.
Models designed for use with the AquaPure water filter are shipped
with a cap in place to cover the opening and keep it free of debris prior to
the installation of the water filter. It is not necessary to have this
cap in place for the unit to bypass the water nor is it intended to plug the
housing to prevent leaks.
Note: This does not apply to the Quatro Convertible models. The filter
must be installed on this model.
SOURCE: location ofwater filter(s) whirlpool modeled22dq
Hi, The filter is located behind the kickplate. You can see the handle for the filter in the kick plate. I believe you turn the filter handle Counter clock wise to remove it. It will tke a little bit of force. Yes this filters the water in the door.
Let me know If I canassist you further. Thanks
Vic
SOURCE: Change water filter on Whirlpool side by side Refrigerator
Jill, download the instructions here:
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Use%20and%20Care%20Guide%20-%202205958.pdf.
SOURCE: water leak at filter
I had this with a Kitchenaid Superba and wanted to get rid of the filter holder assembly entirely as I have an undersink unit which serves the fridge. I removed the plastic line (nut) at the back of the fridge (which led to the filter holder at the front) where the flexible copper tubing inserted (this was a 3/8' compression fitting-plastic) and also the returning line (1/4" copper compression nut on a plastic line) at the manifold (again in the back of the fridge) where it gets split between the water line and the ice line. I then just connected the 1/4" flexible copper directly to the manifold (1/4" nut, compression sleeve, male-male connector) using a pre-made 1/4" flexible compression line. Sounds complicated but after seeing how the water routes it was fairly quick work.
