Question about Building Materials
My liftmaster formula1 opens everytime but only the wall button will close it. Once in a while a remote will work but rarely. I have one remote, one vehicle oem remote and a wall mounted remote outsid
My liftmaster formula1 opens everytime but only the wall button will close it. Once in a while a remote will work but rarely. I have one remote, one vehicle oem remote and a wall mounted remote outside. All 3 are sporadic when closing, all 3 will open the door no problem. Only the wall mount inside the garage will close the door everytime.
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 45 Answers
Does it attempt to close. stop go back up and the lights flash....if so check the safety eyes, check for boken spring/ springs using the wall mount button circumvents the safety system. check the down pressure setting.
Posted on Nov 30, 2014
  • 476 Answers
SOURCE: Liftmaster 1280 LMC Motion Detector Garage Opener Push Button Pad Not Working
Have you tried to reprogram the chanel again?
Changed the battery?
Posted on Aug 02, 2008
  • 6 Answers
SOURCE: Chamberlain Liftmaster Pro. Garage door Problems closing
The sensor eye - or more likely, the other end, the sensor light - probably got knocked out of alignment. The eye should have an LED on it - possibly one that glows green when it's ready to close or red when it's obstructed or out of alignment. Try adjusting the light until the LED on the receiver glows green.
Posted on Dec 07, 2008
  • 244 Answers
SOURCE: liftmaster garage door opener will only work at wall unit
check electric saftey beams. shovel blocking them. dirty. aligned (LED on in each unit)
Posted on Jan 15, 2009
Doorguy27
  • 30 Answers
SOURCE: Keypad outside not working Properly
Have you replaced the battery in your keypad? That should take care of the trick.
Posted on Feb 10, 2009
  • 3197 Answers
SOURCE: Sear garage door wall mount contol light keeps blinking
Hold the button with the lock icon in for 3 seconds. This should toggle the unit off vacation mode and your remotes will work.
Posted on Jun 01, 2009
With my door closed, i push door button to open and the chain and opener continues inthe closing mode. any help?
Shop for sears craftsman liftmaste... on Google
Garage Door Opener Gear...
$31.45
Sears Parts D... Liftmaster 41C4220A Ge...
$21.75
Preferred Do... Chamberlain/l... Sprocket, Gea...
$17.95
eBay Direct Replacement f...
$20.95
Moving Up G... Liftmaster 41c4220a gea...
$31.67
North Shore... Search Results
    Liftmaster Gear And Sprocket Kit 41c4220a Chamberlain ...
    www.sears.com/search=liftmaster%20gear%20and%20sprocket%20...
    Searsmore info. + -. Chamberlain LiftMaster 41C4220A Gear & Sprocket Assembly Kit. $31.40 ... Chamberlain Sears Craftsman Liftmaster 41A2817 Gear Kit. $27.65 ...
Jan 10, 2016 | Sears Craftsman LiftMaster Chamberlain...
Can the code bechanged on a Liftmaster Formula1 opener, just divorced and husband isn't nice
I have to assume a couple things here. First - I assume he still has a remote. Second - You want to change the opener so that his remote will not work and not just the keypad outside the garage. So.
To change the opener so that none of the existing remotes and the keypad will work just locate the smart/learn button on the rear of the motor unit near where all those white wires go. You may have to remove a light lens to get to it. Press and hold this button for 6 seconds. That erases the memory. Now you need to program your remotes. Hold the button down on the remote and then press and immediately release the smart/learn button. Do this for each remote you have.
Now the keypad. Press and immediately release the smart/learn button. Walk over to the keypad and key in any 4 digit code you want and press enter.
That's it.
May 17, 2012 | Sears Craftsman LiftMaster Chamberlain...
My Lift Master remote does not work. The wall mounted unit will open and close the door, but the remote control does not. I've changed the battery with a 1a battery from Radio Shack- but it still won't...
Check the wall console. If it has a lock button and the LED is flashing, the GDO is locked. None of the remotes will work, only the wall button. If it is locked, press the lock button and hold for a couple seconds and release. The LED should stop flashing, and the remotes should start to work.
If the door will open but not close, and the lights flash 5 times, check the door sensors. Make sure the sensors are aligned with each other, and the LEDs are both on.
Jan 11, 2011 | liftmaster 373lm Liftmaster Craftsman...
I have a Liftmaster garage door opener & remote. The remote began to work only intermittently. I replaced the battery (I didn't reprogram remote when battery was changed & remote worked for a...
COULD BE A BAD REMOTE, I WOULD TRY ANOTHER ONE FIRST.
COULD BE A FREEZER ETC. PUTTING OUT INTERFERENCE.
OR
Anytime a door opens and/or closes randomly or doesn't work consistently I look for a smashed wire between the motor unit and the wall button.
If the wire is smashed the insulation becomes so thin that power will leak thru the insulation and activate the door or interfere with the remote signal.
Loosen the staples with a small screwdriver and slide the wire about ½ inch to move any areas of thin insulation away from the staples.
The second thing would be a bad wall button or a remote with a sticking button.
Or a remote in someone
Nov 10, 2010 | liftmaster Chamberlain Garage Door Opener...
Intermittent remote trouble
Your wall control is hard wired and doesn't use the receiver portion of the logic board. The remotes do. Your receiver is going bad.
Jan 12, 2010 | Sears Craftsman LiftMaster Chamberlain...
Garage door will not open close with remote
Press and hold for 3 seconds the button on the wall control with the lock icon.
Aug 29, 2009 | Sears Craftsman LiftMaster Chamberlain...
I have 2 liftmaster 3245. The hand held remotes were working fine then stopped. I replaced the batteries and turned of all electrical/RIF close by. Still not working. Both cars operate the doors with no...
You need to reprogram the remotes by briefly pushing the learn button on the garage door opener until it flashes once, then release the button on the garage door opener.
Now press the remote button once until you hear the garage door opener click, now press the remote button once again and the remote should be programmed to work for that garage door opener.
DO NOT press and hold the garage door opener learn button for more than 10 seconds or you'll erase all programs and have to relearn all the remotes, including your car ones.
Hope you found this very helpful and best regards.
Aug 06, 2009 | liftmaster Chamberlain Garage Door Opener...
Garage door opener remte built in in my van suddenly stopped
TRY DISCONNECTING THE WIRE TO THE WALL BUTTON. IF THE VISOR REMOTE NOW WORKS YOU HAVE A BAD BUTTON.
HOPE THIS HELPS
Jul 30, 2009 | liftmaster Chamberlain Garage Door Opener...
Liftmaster 971LM opens but won't close correctly
Check the wiring going to the sensors to make sure it is not broken or disconnected. You have a problem with the sensors themselves or the logic board. Unfortunately the only way to be sure is to replace.
Jul 14, 2009 | Sears Craftsman LiftMaster Chamberlain...
Liftmaster garage door opener will only work at wall unit
Jan 12, 2009 | Sears Craftsman LiftMaster Chamberlain...
Building Materials Logo
127 people viewed this question
Top Building Materials Experts
hpgwva
Tom Chichester
ray gallant
Are you a Building Material Expert? Answer questions, earn points and help others
