Question about Plumbing
On a Water Ridge Kitchen Faucet model 826703/FP4A4006 I need to replace the base plate and gasket. Item 23 & 24 on vendor parts list the WaterRidge help line is disconnected. Can I get this re
I need to replace the cover plate and gasket items 23 & 24. Where can I find replacement parts
  • 659 Answers
SOURCE: Moen 7065 leaking at base of lever control in kitchen faucet
Yes, a cartridge will probably solve it. There are two different Moen cartridges so be sure to take the old one with you so you get the correct one.
Posted on Apr 05, 2009
  • 3600 Answers
SOURCE: I have a moen pull out kitchen faucet that leaks
You have a bad internal o-ring or the sprayer o-ring is leaking, if you look under the sink turn it off and then turn it back on, if you see it leaking out the center shft where the water pipes go into then the faucet may have a broken pipe or loose pipe. check and tell me where it's leaking at. You can buy kits to repiar them they are inexpensive.
Posted on Aug 30, 2009
  • 127 Answers
SOURCE: Hi Guys. My single spout kitchen faucet leaks when
spout seal kit , from what you described.
Posted on Oct 18, 2009
  • 127 Answers
SOURCE: Moen kitchen faucet model 7430 leak
cartridge does not stop that type of leak. If it is leaking from around the base of the spout it is o-rings that are the problem that are onthe valve after you pull the spout all the way off.
SOURCE: kitchen faucet single handle pull-out. The base of
I have the same problem with an American Standard Reliant Kitchen Faucet that wont swivel anymore. I called American Standard and they are sending me the replacement parts to fix it free of charge, I have had mine 6-7 years and they said it was under warranty. Call 800-442-1902. Good Luck
Posted on Apr 05, 2010
Wateridge Olivia. Where can I get a manual?
Customer Reviews: Water Ridge Pull Out Kitchen Faucet
www.amazon.com/Water-Ridge.../B00O2AGROM
Amazon.com, Inc.The older Water Ridge faucet had a 6 page manual; it seems the company .... me a new Olivia Pullout Kitchen Faucet by WaterRidge' Dual Function Spray Head ...
REVIEW: Costco WR Water Ridge Pull Out Faucet Brushed ...
? 3:21
https://www.youtube.com/watch?v=wsreMTL_whc
Apr 19, 2013 - Uploaded by HillBrosReviews
REVIEW: Costco WR Water Ridge Pull Out Faucet Brushed Nickel .... gave me a new Olivia Pullout Kitchen Faucet byWaterRidge' Dual Function Spray ... They sent a hose... with nodirections how to replace the defective one.
Dec 18, 2015 | Plumbing
Water Ridge kitchen faucet model FP4A4107NP does not swivel between sinks. I thought they all could be directed into either side of a double sink?
Did you install the faucet without using the top mounting plate? This could cause no spout swivel.
Dec 26, 2014 | Plumbing
How to repair a constant drip on Hansgrohe Talia (hot water handle)
Most likely you will need a replacement cartridge to resolve a constant drip. This model uses the M2/M3 cartridge part number 92730000. It is available through your local dealer or online dealer. If you need further help feel free to contact me at Hansgrohe. 1-800-334-0455. Press 2 for tech and ask for David Scarborough. I'd be happy to help.
Dec 04, 2012 | Hansgrohe 06649860 Solaris Single Hole...
Water Ridge Nannini series pull out kitchen faucet rotating at base instead of where it should.
I just fixed our Nannini from Costco. The screens were plugged with plastic filings coming from our water lines. On our faucet there is more than one screen.
The pull out faucet has the basic screen like 99% of the taps out, right on the end. It comes apart by first unscrewing it from the handle and gently (gently) nudging the screen out with a sharp object such as a pairing knife.
Then in the handle was where the problem lay with mine. There was a plastic knob which is recessed in the handle. Leave the hose connected and pull it out until it is stretched or have a helper, then press on that small knob, pull and the whole inside will pull out. There is another filter in there. I was able to take mine apart and clean it, yes it does pop apart but be careful. In assembling mine I just left out the second filter totally.
I guess in hindsite you wouldn't have to actually take the whole handle apart if one has a 90 degree tool to pull out the yellow plastic piece. I used an allen wrench and pulled. Cleaned it with a small needle.
Works better than new!
Nov 24, 2011 | Moen Plumbing
I have a kitchen faucet that is leaking at the base where the faucet connects to the base. It leaks all the time. Do I need to replace the O rings in the stem of the faucet? Or do I need to replace all...
hi! if tightening the knob(s), (or if you apply pressure on the knob of the faucet,for the models with no thread for open/close), modify the amount of water leaking ,you need to replace the seats in the faucet. if not ,just replacing the o rings should fix your problem.
Feb 20, 2011 | American Standard Kitchen Faucet 6310 020...
Solaris Model #06544860 leaking under the sink. How do I remove and how do I figure out exactly what is leaking?
The first thing I would do is to locate source of the leak. Look carefully at faucet when it is on and see if you have any water leaking from areator and running back down the underside of spout and leaking around base of faucet, also see if you have any leaks around handle. If the leak is from the areator you can just replace it and not have to remove the faucet. when you check under sink on faucet supply lines make sure they aren't leaking at that point. I would use paper towels or rags to wipe everything dry under faucet and let it set for 1/2 hour then check again. If it.s still dry run some water and use both hot and cold water seperatly,checking underside in between. If you determine that leak is coming from top side and leaking thru. Shut off water supply valves if available if not shut off supply to house, make sure water is off before proceeding. Disconnect supply lines from faucet,Remove retaing nuts on either side of base,and remove washers. Remove faucet and check for any obvious faults. If you think it was leaking around base get a small tub of plumbers putty. Most hardware stores stock it. Remove a golf ball sized portion or larger and knead in your hands until it is warm and pliable. Press into place in faucet base. Continue doing this until it's full. Reinstall plastic or rubber base gasket and put faucet back in place Put washers and retaing nuts back on a tighten till snug. Center faucet where you want it and tighten securely. Scrape off excess putty with knife point and wipe with paper towels till clean. Hook up supply lines and turn water back on. Check for leaks and good luck. Thank you
Nov 27, 2010 | Hansgrohe 06649860 Solaris Single Hole...
We do not have book on the kitchen faucet which was purchased by a previous owner. Looks just like the Danze D306357BN. It is leaking from the first joint above the base. A plumber could only tell us that...
there are several O-rings inside the spout assembly. 3 that I know of from memory.<br /> <br /> here is a link to the PDF parts breakdown to show your plumber. also that faucet is for the bathroom sink.<br /> <a href="http://www.danze.com/product_details.asp?g=2&amp;mg=5&amp;id=D306357BN">http://www.danze.com/product_details.asp?g=2&amp;mg=5&amp;id=D306357BN</a><br /> the link to the PDF is at the bottom of the page "illistrated parts list" <br /> <br /> here is the link to the kitchen faucet. just click on the "illistrated parts list" to get the breakdown.<br /> <a href="http://www.danze.com/product_details.asp?g=1&amp;mg=1&amp;id=D414357">http://www.danze.com/product_details.asp?g=1&amp;mg=1&amp;id=D414357</a><br /> <br /> if neither one of these is your faucet, just continue looking through till you find yours, and call a different plumber.<br /> <br /> hope that helps<br />
Aug 31, 2010 | Danze Plumbing
My Kohler single lever pull-out faucet stopped working. Raising up does not start water flow. Turning left sometimes starts some hot water, but raisinglever up and down does not start or stop water flow as...
Fix a kohler faucet
most likely the gasket broke inside the lever, you have to replace it.
shut the water off from the angle stop (valve under the sink) both hot and cold.
use an allen wrench ("L" wrench) to remove the tiny screw around the lever, >>>>before you do that place a rag covering the drain for if you drop it<<<< after that pull the lever out, that will show the inside of the faucet. use an adjustable wrench to remove the actuator from the base. when you get that part out you should be able to see the damage to the gasket. At that point you need a phillips screwdriver to get the gasket out and back in >>>>take the damaged gasket to the hardware store<<<< and get a replacement you may have to change more than one. after you get all the gaskets in place, reinsert the actuator and don't forget to tight it up with the adjustable wrench. center it so it would dispense the same amount of hot and cold water, replace the lever reinsert the tiny screw with the "L" wrench. turn on water from angle valves and test faucet.
that should do it and save you about 300 bucks
if it works for you don't forget to rate me
Apr 28, 2010 | Kohler Model 10433: FortĀ® Single-control...
My kitchen aid mixer model k45 will only operate at high speed.
Hi REINO66, I suspect you (speed) Control Plate Assembly has gone bad and needs to be replaced.
The good news is that this can be fixed quite easily (OK, maybe with a little effort) by yourself if you are a DITY type person, feel adventurous, and your mixer is not under warranty. However, before you start to disassemble your mixer, be sure you have the Parts List manual on hand. If you're lacking one, you can download a PDF version from the KA website: http://www.kitchenaid.com/flash.cmd?/#/page/home.
Click on Customer Care>Locate Manuals & Guides> Enter the 6 character model number, in your case use K45SSW, and select the file listed under Parts List (1), K45SSWH0.pdf (341.41 KB). Check to ensure it matches your mixer model.
Turn to pages 6 & 7, titled: Motor And Control Parts, which provides an exploded view for the disassembly and reassembly of your mixer’s electrical components, along with all the parts. Find Illus. No. 25, Control Plate Assembly, Part No. 240904-2, which is the part that needs to be replaced.
As far as parts go, here are four potential vendors in no particular order: RepairClinic.com; mendingshed.com; searspartsdirect.com; partstore.com. Prices for the same part can vary widely between vendors, so do your comparison shopping.
Here are some links to several excellent websites that detail the disassembling/reassembly of a KA Mixer.
Between these three websites and their excellent pictures and descriptions and your Parts List manual, you should now be able replace your Control Plate Assembly.
Good luck and have fun. I hope this helps. Howard, Burke, VA
If this solution has helped you, please rate it, thanks! - hslincoln
Dec 22, 2009 | Magic Mill DLX 2000 Stand Mixer
Plumbing Logo
503 people viewed this question
Top Plumbing Experts
Andrew Bugbee
Tom Chichester
Gil Shultz
Are you a Plumbing Expert? Answer questions, earn points and help others
