Question about Singer Seqs-6000 4-In-1 Machine With Value Package
I have a singer SEQS-6000, everytime I turn it on..all lights start flashing red and it doesnt do anything. I have tried unplugging..starting it up again and it beeps for a few seconds and then all li
At one point I moved the needle position by hand and it cleared and I was able to sew for a little while, I turned it back off and when I turned it on again, it did the same with the beeping and red flashing lights, moving the needle didnt help the second time...
SOURCE: The Machine Lights are Beeping and Flashing
after i looked over the machines thred routing i found a pice of thred jamed in under the top clear plastic panel i took thihs panel off and removed the thred ,cleaned in there put it back togather and it now works fine just what i found hope it works for others
Posted on Nov 12, 2008
  • 27 Answers
SOURCE: Wont Start (brand new) Just Beeps!
make sure the bobbin winder is not engaged and thread the machine over ,also check that the buttonhole switch is not down
Posted on Jan 10, 2009
  • 136 Answers
SOURCE: Singer 7422 beeps and all lights come on when peddle is pressed.
There are several sensors on this machine that just start causing the machine to malfunction for no apparent reason. One is one the bobbin winder, one on the buttonholer, and one under the machine which workd with the feed. It is far from an exact thing. If you can get to them, sometimes loosening them, moving them about then tightening them seems to 'fix' them. Sometimes not. Wish we could be more exact in explaination but sometimes we will move them repeatedly then they start working. It is hit and miss.
Posted on Sep 08, 2009
SOURCE: flashing lights/ no functioning of machine
When we had the same problem as you, we called the helpline and they walked us through the basic reset process. We turned it on and had the same problem. We then raised the presserfoot, turned the wheel on the side of the machine, put down the presserfoot, and then unplugged the power cord from the side of the machine. We then turned it on, and it was fixed! Hope this helps!
Posted on Sep 15, 2010
SOURCE: singer curvy beeps 4 times and stops sewing
when you thread the machine make sure to use every thread guide
check to see if the bobbin is in correctly
try changing the needle--normally flat side goes to the back
the needle that your sewing with is it the right one for the thread & fabric
clean under the needle plate & bobbin area for lint or loose threads
Posted on Apr 01, 2012
Singer futura quartet seqs 6000 keeps giving me a broken thread error. Thread is not broken and I have done tried the unwaxed dental floss and canned air, Please help
Hello
Embroidery sewing machines will often give this error message due to low "drag" on the thread. Try placing the spool of thread upright into a cup on the floor and lead-up the thread as normal for threading. Make sure that the thread does not catch on the thread lock on the spool.
Happy stitching
Sewingirl/
Apr 20, 2017 | Singer Sewing Machines
I need singer repair manual for singer seqs 6000
Try going to the Singer website and type in your model number in the search bar. This should bring up parts and supplies for your model that you can order.
Dec 10, 2016 | Singer Sewing Machines
Two questions i own a futura embroidiery sewing machine. I need to purchase a beading foot where can i purchase it 2) My bobbin casing keeps loosing I have to constantly stop sewing and tighten it
First, look for a replacement bobbin case for your machine. And while you doing that, also look for a beading foot.
Try some of the online sewing vendors:
Bobbin Case Singer 416444401
Singer SEQS 6000 Futura Quartet Par
Finding a beading foot make be difficult, but you may be able to find a snap-on adapter and a snap-on beading foot for your machine.
Oct 25, 2016 | Sewing Machines
Hand wheel moving needle moving but will not sew cannot release hand wheel to turn in opposite direction
Do NOT turn the handwheel the reverse direction.
If your machine is mechanical, most likely it hasn't been cleaned and oiled for a long time. Old sewing machine dries out and turns to glue which then prevents parts from moving like they should.
This web site may be helpful:
How to Oil Vintage Sewing Machine
Tri-Flow Synthetic Lube is very good because it has little teflon beads. It also does not dry out like sewing machine oil will. Then applying heated air from a handheld hairdryer will help loosen it.
Do NOT oil plastic/nylon, cams, or belts.
Aug 20, 2016 | Sewing Machines
Which one is the best for Embroidery Singer XL 420 or Singer SEQs 6000?
Difficult to advise since we really don't know your criteria.
SEQS 6000 FUTURA QUARTET
FWIW, I would be hesitant to purchase a machine with so many functions, ie sewing, embroidery, serging. Seems like a lot of things to go wrong.
XL 420 FUTURA
Your best bet is to do a lot of research on the internet. Read the reviews from people who have purchased these machines. Then go talk to a Singer specialist. Only when you have gathered as much information as you can are you able to make an educated decision.
Jul 22, 2016 | Singer Sewing Machines
Sewing machine
remove the cover over the bobbin section so that you can see the needle bobbin carrier interaction
now turn the machine over by hand and watch the needle go down and start to come up
at this point the hook of the bobbin carrier should be very close to the needle just above the eye of the needle
It is at this point the the needle thread is picked up and run around the bobbin carrier to link up with the bobbin thread
if it is not there then take it in for an adjustment as the adjustment is done by loosening off the clamp on the vertical bar at the end of the machine that moves the needle up and down and positioning the needle in the position described
if the needle is hitting the bobbin and the timing is correct , replace the needle as it may be bent or not in properly
Jun 24, 2016 | White Sewing 2037 Mechanical Sewing...
The usb port on my wife singer seqs6000 is broken what do i need to do
You may need a new motherboard or just the port. Contact Singer direct or one of the spares dealers.
  • SEQS-6000 ' SINGER Futura Support www.futura-support.com/products/seqs-6000 The SINGER® FUTURA™ SEQS-6000 is ONE machine with four functions-sewing, embroidery, quilting and serging.
  • Singer SEQS-6000 sewing machine parts www.discountsewingmachineparts.com/machine-brand/singer/seqs-6000 An online Singer SEQS-6000 sewing machine parts store. We supply belts, bobbin cases, bobbins, feed dogs, foot controls, gears, light bulbs, needles, needle plates ...
  • SINGER Model SEQS-6700 Parts www.singeronline.com/seqs6700.html SINGER Model SEQS-6700. Motor Drive Belt #416433501. $9.99. ... Serger Parts; Singer Free Motion Feet ; Sewing Machine Repair Training; Stitch N' Ditch Foot ; ...
  • singer futura seqs-6000 ' eBay www.ebay.com > Search > singer futura seqs-6000 Find great deals on eBay for singer futura seqs-6000 . Shop with confidence.
  • SEWING & EMBROIDERY MACHINES - SINGER Sewing Co. www.singerco.com/products/2209/futura-quartet-seqs-6000/reviews buyers of this SEQS6000 sewing machine should buy spare bobbin cases. ... The Singer Futura Quartet SEQS-6000, is truly the Cadillac of sewing machines.
  • Singer Sewing Machine Parts & Singer Serger Parts www.sewingpartsonline.com/singer
    • 4.8/5
    • 68K RATINGS
    An Online Singer Parts Superstore, We also supply Singer Parts manuals, presser feet and accessories. Fast, free shipping over $75.
  • wa+cwowlplelaaaaaasuvork5cyii=
  • http://www.bing.com/search?q=+singer+seqs6000+spares&qs=n&form=QBRE&pq=singer+seqs6000+&sc=0-16&sp=-1&sk=&cvid=11D94CE364FA41EB951C6FE56CDCDDB0
    Jun 11, 2016 | Singer Seqs-6000 4-In-1 Machine With Value...
    Why does it make a knocking noise as it sews?
    the needle position is up tight in the holder and no where else
    the cut away bit of the needle faces the bobbin case hook and the groove in the needle faces the end of the machine and gives clearance for the thread to pass through the material
    from your description and what you did, the needle /hook timing needs adjusting as it is out
    turn the machine over by hand as in sewing and watch the position of the eye of the needle and the bobbin case hook
    just as the needle starts to move up, the hook should be just above the eye of the needle at the edge of the needle
    The adjustment is by loosing off the screw on the vertical shaft at the end of the machine that is attached to an arm that moves the needle up and down and move that bit up or down until the needle is positioned correctly to the hook
    tighten up the screw
    next is to check the needle tension is not too tight
    workshop manuals are available on line in pdf version or take it to a sewing machine repair shop for a proper diagnosis
    May 12, 2016 | Singer Stylist 7258 Electric Sewing...
    Jammed and needle bar will not move.no thread wrapped anywhere,hand wheel won't raise the bar either
    1. Remove the needle and bobbin assemble completely.
    2 Try to move the hand wheel - forcefully if necessary.
    3. Place one drop of oil on race. That is the little dip that has been circled. The hook (pointed thing) must ride on this smoothly.
    4. Try to move the hand wheel again. Back and forth until it will move without resistance.
    5. Oil parts that move with metal against metal.
    6. Replace the bobbin assembly. Try to rotate the hand wheel again. If it is ok you can replace the needle.
    7. Try to rotate again. If it rotates smoothly you shouldn't have any further problems. If the needle strikes something under the throat plate you will need to get the sewing machine timed.
    Jun 28, 2015 | Juki DDL-8700
    Singer Seqs-6000 4-In-1 Machine With Value Package Logo
    709 people viewed this question
    Top Singer Sport & Outdoor - Others Experts
    Are you a Singer Sport and Outdoor - Other Expert? Answer questions, earn points and help others
