My tv needs to be on channel 4 but I can't change the channel it's stuck on channel 3 what should I do
    Champion:
  • 209 Answers
Why can you not change the channel? The only way to change channels is either on the TV directly, or from the remote. If neither work then you may need to get a new remote, or a new TV.
Posted on Nov 24, 2014
tvtek
  • 1284 Answers
SOURCE: TV (RCA model F32705) stuck on one channel
Usually the fix for that on a RCA or GE TV is to go into the menu (the button in on the front of the TV) and find channel settings and let the TV autoprogram itself. This should fix the issue.
Posted on Apr 26, 2007
ThaMp3Doctor
  • 8596 Answers
SOURCE: magnavox with pic tube tv skips over channel 3..goes from 2 to 4
You are right about the auto-programming, but Magnavox no longer has the original remote.
For my answer to be right, you must have posted this question to the EXACT CORRECT model # of your Magnavox TV - 27ms343s:
Press TV on your Verizon remote, and then press "0" and "3"
If that fails:
Press MENU to see the TV’s on-screen
menu. In the menu, use VOL.+/_ and
CH.+/_ to make adjustments or selections.
You can press MENU on either the
remote control or the front of the TV to
access or remove the menu.
Posted on Jun 14, 2008
jerryg50
  • 1689 Answers
SOURCE: TV stuck on Channel Fixed;6
Go in to the user menu and find where the Auto Channel Setup is located. You can consult the instruction booklet for your TV set. Try this and see if it works. If it does not then there are a number of areas in the set where there can be some defective components.
The tuner is controled by the uPC system. There are a number of interface circuits involved for the channel control. Problems in these areas can cause the channels to not be able to be changed.
Jerry G.
Posted on Jan 17, 2009
bschilz
  • 2049 Answers
SOURCE: how do i change my tv to channel 3? It is skipping
Instead of pushing the channel up or down button, manually input either 3 or 03 or 003 to get to ch. 3.
Posted on Oct 06, 2009
  • 10865 Answers
SOURCE: My Jensen TV is stuck and will only switch between
You will have to go to walmart and get a universal remote to change the channel. About ten dollars.
Posted on Dec 05, 2009
My 27 inch rca truflat is stuck on channel 13 on the cable setting and 41-1 on the ant setting wont change to any other channel, can someone help me
try to preset the channels bec,it is not on the tv button memory but only on remote.go to channel settings and preset cable channels
May 23, 2016 | RCA TruFlat 27F520T 27" TV
My Magnavox TV 27 model 27MDTR10S is stuck on channel 1. it will not change by the channel buttons or by the cable box.
Rick, TV should be set on channel 3 or 4, when using a box.
Unplug TV for 10 min.s to reset, and try.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Feb 25, 2016 | Televison & Video
Can't change channels stuck on 4 tried scanning it but it goes back to 4
There could be a few possibilities for this .:
  • Change the "Input" setting on the TV to "AV" or "VIDEO". There is probably an "INPUT" button on the remote.
  • Find the TV/VIDEO mode on your tv or check the back of the cable box where your cables screw into the unit. There is normally a switch to select an output for channel 3 or channel 4. Your's would be on 3. It's just a matter of switching to 4 to make it work on your tv. More info on this here:
  • https://www.google.com/search?q=tv+channel+stuck+on+4&ie=UTF-8&oe=UTF-8&hl=en-us&client=safari
Jan 28, 2016 | Televison & Video
My LG LCD TV cant stop changing channels on it own . I ve removed the batteries from the remote but still its changing them on its own
Is it going one way - channel 1-2-3-4-5 bottom to up or any way at random. Find out which way and check the channel button on the TV to see if it is stuck.
Mar 17, 2011 | LG 37LD450 37 in. TV
Can't get the channel to change so that the cable works, it's stuck on Channel 4 and needs to be Channel 3
i take it you dont have a remote and your control panel is not working the best fix for this is to go and purchase a cheap universal remote control and program it to your tv this will allow you to change channels
Jan 02, 2011 | Toshiba MD20FL1 20 in. TV/DVD Combo
Stuck on 3 channels, no remote.
U can't get to channels 3 or 4 without a remote.Ur getting stuck on these particular channels 26,35 and 19 mean the last owner put these channels on the tv memory.Try website like Remotes.com to buy an exact remote or very close to the original,if u want make use of this tv.
Jun 15, 2010 | Sylvania 6420FB 20" TV
Channel stuck problem
How long does it take (in seconds) before it changes teh channel? Because some TV's, if you have more than 10 channels, have to wait before they change because you might want to change to a higher channel Example:
suppose your TV has 99 channels but your remote has only buttons from 0 to 9. So if you want to switch to channel 7 the TV waits a little before it actually switch to 7 because there might come another nuber after the 7 as the TV doesnot know what channel you wants. 2 to 3 seconds should be the maximum delay.
If it takes more time, check if this can be changed in the menu, often there is a delay possibility in the setup menu.
If teh delay is over 4 seconds and you still have warranty on it, just return it to the vendor.
Jan 16, 2009 | Samsung 21" FLAT CRT COLOR MONITOR
go to setup in menu from fromt of set. do 1st time setup ...tell it you do NOT have a cable box. if it thinks you have one it deletes all channels but 3.
Jan 04, 2008 | RCA P46924 46" Rear Projection Television
Apr 25, 2007 | RCA F32705 32" TV
Televison & Video Logo
88 people viewed this question
Top Televison & Video Experts
